Lenovo V130-15IKB bios dump
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    #61
    Re: Lenovo V130-15IKB bios dump
    Originally posted by magictouch
    I have downloaded the file from the lenovo website and trying to convert it via innoextract but its not converting the file. the cmd open and closeses after 1 second whereas no file is produced.
    Drag and drop bios.exe file to innoextract.exe
    • magictouch
      • Apr 2021
      • 108
      • united kingdom
      #62
      This is what exactly I did but no joy.
      i using windows 10 64 bit.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12441
        #63
        V130-15IKB Laptop (Lenovo) - Type 81HN
        • harold2022
          • Nov 2022
          • 1
          • Bolivia
          #64
          Thank you very much I had the same problem when updating the bios I almost had a heart attack but I followed the steps when reading this publication and everything went well thank you very much God bless you.
          • Sergii
            • Nov 2022
            • 4
            • Deutschland
            #65
            Hello everybody!
            There is BIOS in the attachment, which don't work (only CapsLock LED after power on).
            I've tried to use BIOS from this thread (Orig+8VCN29WW+outimage+DMI) with my DMI, but my laptop was without pre-installed Windows and binary data at the offset 0x27D5D0 is very different from the sample file.
            Could somebody help me with this BIOS?
            Thank you in advance!
            • hardware1
              • Sep 2021
              • 2949
              • N/A
              #66
              Originally posted by Sergii
              Hello everybody!
              Try this file and let me know.
              all donations are welcome,
              • Sergii
                • Nov 2022
                • 4
                • Deutschland
                #67
                Unfortunately, now even Caps Lock does not light up when you turn it on.
                The notebook does not respond at all
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12441
                  #68
                  Try this file
                  • Sergii
                    • Nov 2022
                    • 4
                    • Deutschland
                    #69
                    Try this file
                    The same: laptop does not start at all.
                    If I press power button for more than ~5 s, then LED near power cable switched off and on again (it was also with firmware from previous message).
                    Is it possible, that my DMI section is broken (see selected 000..00 in attached file) and I should use image with empty DMI?
                    • hardware1
                      • Sep 2021
                      • 2949
                      • N/A
                      #70
                      Program back your original backup and see if the caps lock blinking as before or the device still dead.
                      • Ivandj983
                        • Dec 2016
                        • 16
                        • Pozarevac
                        #71
                        Hello friends , I also need to repair this file, and it is corrupted , Lenovo V130-15IKB, motherboard lv315kb mb 17807-3m, there is corrupted file attached
                        • hardware1
                          • Sep 2021
                          • 2949
                          • N/A
                          #72
                          Here's your New BIOS, try it and let me know.
                          Serial Number: R90SJ98W.
                          • Ivandj983
                            • Dec 2016
                            • 16
                            • Pozarevac
                            #73
                            thanks HARDWARE1, but it won't work, the button light caps lock, up and the fan turns at full speed without a screen, hardware problem…
                            • Simon16
                              • Sep 2017
                              • 102
                              • España
                              #74
                              Bios need for LENOVO V130-15IKB 81HN
                              Please, bios need for LENOVO V130-15IKB 81HN
                              Motherboard is:
                              LV315KB MB
                              17807-3M
                              448.0DC05.003M
                              I attach original bios bin file
                                • 22293
                                Re: Bios need for LENOVO V130-15IKB 81HN
                                Motherboard is:
                                LV315KB MB
                                17807-3M
                                448.0DC05.003M
                                You can use the bios from post #11 .If you want to copy the serial number etc (DMI) from your bios to the new one you can use the attached macro script Read the README.txt file for the instructions
                                • Simon16
                                  • Sep 2017
                                  • 102
                                  • España
                                  #76
                                  Originally posted by SMDFlea
                                  You can use the bios from post #11 .If you want to copy the serial number etc (DMI) from your bios to the new one you can use the attached CopyDMI script ,and some software from this guide ---> Copy DMI info easily with Hex editing software and Macro script - https://www.badcaps.net/forum/showthread.php?p=1214739
                                  Follow the Easy guide and everything should be ok.
                                  I have already downloaded the bios from post 11
                                  Could you tell me the hexadecimal address of the DMI region in this file?
                                  I would then use HxD Hex editor to copy and paste from the original to the one downloaded from post 11
                                  Thank you very much for the help.
                                  • hardware1
                                    • Sep 2021
                                    • 2949
                                    • N/A
                                    #77
                                    DMI from (201000) till (2011ff), Windows Key from (270000) till (27D60F).
                                    • Simon16
                                      • Sep 2017
                                      • 102
                                      • España
                                      #78
                                      Thank you so much
                                      I will do the reprogramming and I will say the result
                                      • Simon16
                                        • Sep 2017
                                        • 102
                                        • España
                                        #79
                                        Thank you very much to both.
                                        The laptop is working
                                          • 22293
                                          Good to know .By the way,the script uses exactly the same offsets
                                          • AHmad_Salal
                                            Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                            by AHmad_Salal
                                            Hello all,
                                            I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                            11-28-2023, 05:28 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            Hi everyone,
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            ✅ What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
                                          • mkdj
                                            ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                                            by mkdj
                                            Dear all,
                                            I have a ASUS ZenBook UX480F with the following symptoms:
                                            I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                                            I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                                            10-19-2025, 04:41 AM
                                          • Habble7
                                            I need a BIOS dump for the Samsung S49CG934SU monitor
                                            by Habble7
                                            The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                            Suspected Cause:
                                            I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
