Lenovo V130-15IKB bios dump
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ---------------------------------------------------------------------------------------------------------------------------------------------------------------- -
Re: Lenovo V130-15IKB bios dump
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Thank you very much I had the same problem when updating the bios I almost had a heart attack but I followed the steps when reading this publication and everything went well thank you very much God bless you.Comment
Hello everybody!
There is BIOS in the attachment, which don't work (only CapsLock LED after power on).
I've tried to use BIOS from this thread (Orig+8VCN29WW+outimage+DMI) with my DMI, but my laptop was without pre-installed Windows and binary data at the offset 0x27D5D0 is very different from the sample file.
Could somebody help me with this BIOS?
Thank you in advance!Attached FilesComment
Hello everybody!
Thank you in advance!Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
The same: laptop does not start at all.
If I press power button for more than ~5 s, then LED near power cable switched off and on again (it was also with firmware from previous message).
Is it possible, that my DMI section is broken (see selected 000..00 in attached file) and I should use image with empty DMI?Comment
Is it possible, that my DMI section is broken (see selected 000..00 in attached file) and I should use image with empty DMI?----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Hello friends , I also need to repair this file, and it is corrupted , Lenovo V130-15IKB, motherboard lv315kb mb 17807-3m, there is corrupted file attachedAttached FilesComment
Serial Number: R90SJ98W.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Bios need for LENOVO V130-15IKB 81HN
Please, bios need for LENOVO V130-15IKB 81HN
Motherboard is:
LV315KB MB
17807-3M
448.0DC05.003M
I attach original bios bin file
ThanksAttached FilesComment
Re: Bios need for LENOVO V130-15IKB 81HN
You can use the bios from post #11 .If you want to copy the serial number etc (DMI) from your bios to the new one you can use the attached CopyDMI script ,and some software from this guide ---> Copy DMI info easily with Hex editing software and Macro script - https://www.badcaps.net/forum/showthread.php?p=1214739
Follow the Easy guide and everything should be ok.
Could you tell me the hexadecimal address of the DMI region in this file?
I would then use HxD Hex editor to copy and paste from the original to the one downloaded from post 11
Thank you very much for the help.Comment
DMI from (201000) till (2011ff), Windows Key from (270000) till (27D60F).----------------------------------------------------------------------------------------------------------------------------------------------------------------------
by AHmad_SalalHello all,
I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....-
by AhariHi all,
I...-
by hyperwoodHi everyone,
I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
✅ What I need:- A working 2MB BIOS dump
- Matching NM-E471 Rev. 2.0, e.g. JY575
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by JoluvillasHi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
- Loading...
