Sony KDL-40S504 6 blinks
  • kevinm34232
    • May 2012
    • 1884
    Re: Sony KDL-40S504 6 blinks
    On the white side of the board is where i measure the other transformers, I assuming they're the secondary pins.. This transformer is reverse and I when measure those same pins it is very low ohms and with ring tester, no lights so Im thinking winding may be shorted or something..
    • kevinm34232
      • May 2012
      • 1884
      Oh ok thanks that settles that.. time to open her up..
        That current sensing transformer is related to the FB pin, but I believe you are having OLP problem, so remove the board and inspect the fingers and the sockets first. In the service manual for this setup, it has big warning with regarding to how the lamps are put inplace and warning about breaking the lamps if not done properly. I cannot find that training manual yet. There may be SONY training manual for your chassis on Elektrotanya website.
          My ringer shows about 10~15 rings for the CT101 on my SENCORE 75 ring tester. About the same on the rest of other transformer as well.
          • kevinm34232
            • May 2012
            • 1884
            Are you talking about the between same the 2 pins I have marked? Because on CT101 those show no LED's indicating a short but the others show medium 4 LEDs rings on my blue ring tester..
            • truep
              • Aug 2010
              • 373
              I have a similar model. Does anyone know the procedure to disconnect the high voltage cable? I can unlock it but it doesn't want to come off. I don't want to break it.
              • kevinm34232
                • May 2012
                • 1884
                I see what you mean, but just pull the tab and wiggle it, it will come loose..
                • kevinm34232
                  • May 2012
                  • 1884
                  I cut OLP trace going to U1 that carries the 8.4V, backlight does not come on at all but tv still goes on then off with 6 blinks. DET has nothing. I am trying to bypass this error just to see a dark spot from a bulb out.. It seems to need this voltage..
                    Yes, they are the same test pins on my transformer.
                    Since we know that the LD signal goes low when the lights go out. Can you disconnect the LD line from the balancer to the power supply board to see what happen?
                    • kevinm34232
                      • May 2012
                      • 1884
                      Yea I will test if that's been done but I think that may have been done by cutting the OLP trace of U1. Well maybe not that was showing 12.4v the same as the DET.
                      Are schematics available for these balancer boards?
                      • kevinm34232
                        • May 2012
                        • 1884
                        Ok bud disco'd the 2 LD lines from inverter board to PS board... Tv backlight stayed on, seemed normal at first then this is what I got not sure what to make of it...
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #52
                          Originally posted by tom66
                          "Illogical"...
                          kevinm34232 is obviously not a Star Trek fan.
                          --- begin sig file ---
                          --- end sig file ---
                          • kevinm34232
                            • May 2012
                            • 1884
                            OMG lol I knew that was coming... now beam me up .. Scotty.. or Scottie before I hear it..
                            • kevinm34232
                              • May 2012
                              • 1884
                              So on a more "logical" note, I can get a picture and sound without LD connected, but video is not right.. not sure if you can see by picture but it's got that out of contrast/gamma look.. Is this a different issue? Don't see any dark bars on screen I suppose I should find a white source..
                                Yes, try white screen some how, then turn the backlights level (not brightness) up and down to see if you can see any dark band. It does look like you have other problem also.
                                  Looks like wrong LVDS mode/T-con type.
                                  Perhaps owner put wrong T-con in set?
                                  • kevinm34232
                                    • May 2012
                                    • 1884
                                    Here's a pic with the menu on also. It doesn't seem to affect the OSD at all.
                                    Is that streak in the background a type of Sony background?
                                    Also Im going to try to find a white screen on the DVR and see if I can see a bad bulb..
                                      It's not normal...
                                      • kevinm34232
                                        • May 2012
                                        • 1884
                                        Im wondering if this has anything to do with the firmware update I did before I was able to get a picture. I do not know how it looked before I updated it..
                                          Can you put the original firmware back on?
                                          • jason123
                                            Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                                            by jason123
                                            Hi there,
                                            I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                                            So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                                            I see 2 posts that are relevant:
                                            https://www.badcaps.net/forum/troubl...j-oled-5-blink
                                            https://www.badcaps.net/forum/troubl...g-hardware-dev...
                                            10-29-2025, 02:01 PM
                                          • matwan
                                            Sony XR-55X90J 5 blinks
                                            by matwan
                                            I have problem with SONY 55X90J. After several check status is as below;
                                            1. Running power board as stand alone:
                                            TCON_12V =~ 12.6V
                                            EVDD V On Max 24V= 19V.
                                            2.
                                            Running power board with TCON as stand alone:
                                            Effect as below, attched.
                                            3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                                            "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                                            Best regards....
                                            09-28-2025, 04:26 AM
                                          • GoodCapDude
                                            Sony XBR-75X940E intermittent 6 blinks error code
                                            by GoodCapDude
                                            Hi everyone. First post on Badcaps!
                                            I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                            09-20-2025, 06:07 AM
                                          • odie34
                                            Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                            by odie34
                                            I am a hobbyist (not a professional) so please be gentle...
                                            I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                            I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                            02-18-2024, 09:11 AM
                                          • reassor
                                            Sony kd70xf8305 very very slow android logo with sound
                                            by reassor
                                            Hi.
                                            Power is ok
                                            Tv turns on by it self when you turn IT off with button or pług.it shows sony logo the android logo but with like 1 frame every 10 sec. Music starts after like 1 min. After some time logo will Just hang. But i can turn volume up and down on a pilote but its very slow as well.
                                            Should i force update? If so how?
                                            I did reset.
                                            Mainboard Looks pristine.
                                            Very wierd.
                                            10-30-2023, 05:59 AM
