Analog ESR meter design
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Analog ESR meter design
    Ok, I built a ~50khz, ~50% duty cycle LM555 timer circuit. That drives a transformer via a coupling capacitor. The transformer takes in 5vac and puts out about 225mV open-circuit. I used this page and the diagram on it to get my ideas from.
    I can post some pics tomorrow, but so far I have only made the capacitor testing portion. I tested a 63v 330uF NCC LXZ -> 216mV. I tested a bulged capXon KF (1000uF 25v) ---> 43mV!!!
    The 555 has no problem powering the transformer, as its 200:15 ratio. As described on this page, the transformer takes the high-voltage, high-impedance, and makes it low-voltage, low-impedance.
    Muh-soggy-knee
    • vhr
      • Aug 2012
      • 21
      • Russia
      #42
      ESR meter for capacitor LOW ESR in circuit.
      http://radiokot.ru/konkurs/10/
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Wow, good link! Never seen that one before. Interesting how the circuits aren't even in a box xD
        Muh-soggy-knee
          Double WOW!, it can test any form factor CAPS, I like the way he made the testing pads for testing the surface mounted cap.
          • vhr
            • Aug 2012
            • 21
            • Russia
            #45
            ESR meter with indication of leakage and short circuit.
            ESR-0...75Ohm
            F-80kHz
            Vp-p<30mV
            HL1-leakage 0...100Ohm
            http://radiokot.ru/konkurs/21/
            • Agent24
              I see dead caps
              • Oct 2007
              • 5085
              • New Zealand
              #46
              I wonder how easy it would be to replace the analog meter with a digital readout using 7400\4000 series logic
              -David VanHorn
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                I think it would be quite complicated, using at least half a dozen IC's
                -Ben
                Muh-soggy-knee
                  Here's my stab at an ESR meter. It passes a constant current sine wave thru the cap (converts square wave to sine), picks up the voltage and outputs an AC (100kHz) voltage with an amplitude approximately equal to ESR. A scale factor control would allow for compensation for true-RMS or average-reading multimeters. May as well use the meter's conversion circuitry...
                  In theory, as it is all ac coupled, it can handle a fully charged capacitor with no problems. Maximum voltage would be 630V or 1000V depending on cap limits.
                  TODOs - think about AC-to-DC conversion, think about split supplies (try and avoid them.) Ideal meter would run off either 2pc or 3pc of 1.5V AA.
                    The circuit in post 45, the output is rectified to feed analog meter, you may be able to just use cheap DMM that can read low DC mV range.
                      This my experiment with ESR meter using some scrapped parts I have in my parts bin, LM555 and 2N3904. Works pretty well compared to my SECORE LC75 for the reading range I want.
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        #51
                        Cool.
                        Mind posting a schematic or link where you might have gotten the schematic? I need to build me one as well.
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          Good job!
                          Muh-soggy-knee
                            Thanks, here is the Diagram & BOM. I am going to make smaller board to fit into old RadiShack Analog meter, since proof of ciruit is verified and it works.
                              By the way, for more bias stability of Q1, you can add 100 Ohms between Emitter and Ground and bypass it with 0.47uF cap, and if you want adjustable gain, then put that 0.47uF cap in series with 500 Ohm trimpot for gain adjustment.
                                Rev2 with added Adj gain and bias stabilizer for Q1.
                                • sebr
                                  • Oct 2010
                                  • 79
                                  Thanks for the update, just what i was looking for
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    #57
                                    Thanks.
                                    I think I will be building one as well sometime this week.
                                    • sebr
                                      • Oct 2010
                                      • 79
                                      Just to make sure: this meter isn't capable of testing caps in circuit, or?
                                      Maybe in next revision you could add diodes + bleed resistor to protect the circuit if a charged cap is connected?
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5085
                                        • New Zealand
                                        #59
                                        Even the meters that can test in-circuit can still be fooled by paralleled capacitors or other components, as always, the best test for just about anything is out-of-circuit.
                                        I don't see a huge reason for testing in-circuit anyway. When doing a recap it's usually because you have crap brands and some have already failed.
                                        In such a case it's more sensible to replace the lot anyway for better reliability in the future. Testing their ESR becomes more of an informational postmortem exercise.
                                        Still, I guess it's better to have the feature and not want it than want it and not have it.
                                        -David VanHorn
                                          agent24 is correct, if you have a bunch of caps in parallel, the bad one will not show up as having the high ESR. I always test component out off the circuits.
                                          @sebr: I did add the 1N4007 Diodes to the test terminal, you can add it if you worry about accidentally attach a charged caps to the tester, and if you want more complex, you can add the cap and a bleeder resistor also.
                                          • eccerr0r
                                            lowest current galvanometer/analog meter (passively powered!)
                                            by eccerr0r
                                            Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                                            On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                                            04-16-2025, 12:41 AM
                                          • jorpec
                                            Changing the scale of an analog meter
                                            by jorpec
                                            Hi
                                            I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                            I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                          • jinu_j
                                            Dell 2209WA - power supply - Fusible Resistor replacement
                                            by jinu_j
                                            Hi
                                            I am trying to repair an ancient Dell 2209WA Monitor which suddenly shut off with a pop sound. On investigation found that one of the fusible resistors had blown. Further investigation identified multiple components as faulty because of which the fusible resistor blew. Please refer the attached circuit diagram showing the components that were found to be damaged.
                                            1. FR950 - blown fusible resistor - 0.2 Ohm 1W
                                            2. Q950 - shorted Q950 MOSFET - 650V 10A N Channel Mosfet
                                            3. R835 - Blown Resistor - 20KOhm SMD resistor
                                            4. D930 - Shorted Schottkey Diode...
                                            05-03-2025, 10:51 PM
                                          • Darren Hibbert
                                            Replacing a Current Sense Resistor
                                            by Darren Hibbert
                                            Hi.
                                            Quick question.
                                            I have a laptop that is completely dead. I opened it up and it looks like the current sense resistor is blown. However, because it's blown, the value printed on the top has disintegrated and there is no schematic available for this particular laptop (Dynabook Portege) so I'm not sure what to replace it with.
                                            04-08-2024, 08:36 PM
                                          • mikey5791
                                            Need help to replace burned resistor in 350w atx psu
                                            by mikey5791
                                            Hi to all forum members,
                                            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                            12-26-2024, 04:55 AM
