Hisense 50k23dg with power issues?
  • nomoresonys
    • 12328
    • U.S.
    Re: Hisense 50k23dg with power issues?
    https://www.youtube.com/watch?v=4v8DcqCNG4A
      Shopjimmy and norcal75 have better videos and better warning.
      • nomoresonys
        • 12328
        • U.S.
        There's one from sj, what's your highness's opinion of it?
          https://www.youtube.com/watch?v=oE6K4xBVweA
          Another Video on checking the Balancer board like the Samsung, I should have given you that norcal one instead.
          • nomoresonys
            • 12328
            • U.S.
            Originally posted by budm
            Well, when some one instruct you to out meter in DC AMP to measure the Voltage, do you think that is not a good instruction?
            Try that yourself and see what will happen! It is ego, it about proper instruction!
            Listen to what he said!
            "I re-read my thread, all you really did was insult me," https://www.badcaps.net/forum/showthread.php?t=67776
            It took 12 posts to get you to set the meter properly.
            And you told me my voltage on the connector couldn't be right, in fact you said it was impossible, BUT it was right. So I was measuring different parts of the board and forgot to adjust my meter, big deal.
              Read post 22.
                norcal75: look at the warning he provides.
                https://www.youtube.com/user/norcal7...w=0&shelf_id=0
                  Re: Samsung LN40C650L1FXZA Backlight flash no voltage on 450 v. filter caps
                  Lest see:
                  Post #5:
                  "I think having no voltage at the 450v filter caps is bad but don't know what the cause is."
                  Post #8:
                  "No both on and off while plugged in, read ol."
                  Post #12:
                  Originally Posted by budm View Post
                  OL on the DCV scale that means it is higher than the meter can display.
                  What scale on the meter did you set it to?
                  You should know how to read your meter by now.
                  As I indicated, now way you can have 0VDC on the main filter cap, operator error.
                  Lol, I forget things faster than I learn them, meter was at 20 will try higher setting. board is bn44-00340b.
                  • nomoresonys
                    • 12328
                    • U.S.
                    #29
                    So did you go and listen to the instruction? for the DIY that still learning and listen to the instructor on what to set the meter to can put themselves in worst situation due to improper instruction..
                    Same instruction as not to touch anything in the deadly hot side of the circuit with your hands or your body, proper instruction is important.
                    Yes I did he didn't make a mistake, he said dc, maybe YOU better look at it again, til YOU grasp it.
                    • nomoresonys
                      • 12328
                      • U.S.
                      #30
                      Read post 22.
                      That's your opinion, they are good Tampatec is just as good.
                        Let have someone listen and see what they hear, "DC Current"
                        • nomoresonys
                          • 12328
                          • U.S.
                          #32
                          Lest see:
                          Post #5:
                          Post #8:
                          Post #12:
                          n/a
                          • nomoresonys
                            • 12328
                            • U.S.
                            #33
                            At this point test the Voltages on that balancer board diode as shown in the Video, you will have to turn the TV off and on when you move to the each next diode.
                            " and 13.16 from pin 7" That MUST BE AN ERROR on your part because it only has 12V supply to run the comparator circuit on that balancer board so no way you can have 13.16V.
                            Look at your meter to see exactly what it is showing on your meter display, more likely it is 13.16mV, recheck your reading. It is VERY IMPORTANT to get correct data! V and mV are not the same.
                            • nomoresonys
                              • 12328
                              • U.S.
                              #34
                              That's YOU swearing up and down it was wrong BUT it was right so YOU were WRONG.
                              • nomoresonys
                                • 12328
                                • U.S.
                                #35
                                SO there you have it , "YOU" were wrong, I'm done with this, don't want to upset my little pal c hegge.
                                  Well, the 12 supply feeding the comparator circuit and you get 13V out off the circuit that has no Voltage booster but just a simple IC comparator circuit, then I do not know what to tell you.
                                  Do you know what LD pin is? that pin is normally HIGH >11VDC, it will go low when it detects bad lamp which what you have, that low is an error signal to tell the inverter circuit and the main board to shutdown the inverter circuit, that signal must have gone low otherwise your backlights would not have gone off due to error detect. That is the reason why i suspect it to be in mV range not in the V range as you report. You can also see the block diagram and explanation on how the comparator works in that Balancer board which is explain in that SONY trainning manual I provided.
                                  BTW, those Voltages you test on the those diodes are fed into the comparator circuit.
                                  • punkityn
                                    • Feb 2018
                                    • 6
                                    I need to get a new multimeter. Maybe you guys could argue in another thread?
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      @nomoresonys budm was pointing out an error in the video which could have bad consequences to anyone following his verbal instruction. Not sure how you could take that personally. My guess would be if you told tampatec about the error he would thank you for pointing it out and add a correction to the video.
                                      @OP, was this set wall mounted ? If the solder joints are ok at the ac power in then it's possible your power cable is needing to be replaced. I ask if it was wall mounted to see if it's possible the cable was kinked against the wall behind it.
                                      • nomoresonys
                                        • 12328
                                        • U.S.
                                        #39
                                        Originally posted by Andrew F. Ali
                                        +100
                                        -10000000000000000000000000 Tampatec did the procedure CORRECT NO MISTAKE THERE.
                                        • nomoresonys
                                          • 12328
                                          • U.S.
                                          #40
                                          Ok, it may have been a verbal error but he set his meter properly and it wasn't just one rude response. it's over now tho. everyone has their own style and good for them, I like to try to help without making people feel stupid or being OVERLY SARCASTIC but that's just me.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • DoubleBogey817
                                            HISENSE 65H6510G (13 AUG 2020) - POWER ISSUES
                                            by DoubleBogey817
                                            HISENSE 65H6510G (13 AUGUST 2020)
                                            When powered on, initial splash screen (HISENSE ANDROID TV) displays for a few seconds then power shuts off. Tried updating firmware with USB flash drive (can't find 4GB drive but did format larger drive in FAT32) with no luck. Flash drive would be accessed but would never get to the update process. I have ordered a board (RSAG7.820.7911/ROH, PART# 242585) from eBay which will arrive in a few days. Does anyone have any input of whether I am chasing down the right trail or should I be trying something else? I appreciate your time and wish to say thank...
                                            02-16-2024, 10:58 PM
                                          • zlr8r
                                            Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                            by zlr8r
                                            hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                            Ill try and give as much info as I can.
                                            Dell Inspiron 17 (7786) Laptop
                                            Service Tag: 5J0NHT2
                                            Bios: 1.9.0
                                            When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                            Then it started getting weirder!
                                            Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                            12-12-2023, 09:31 PM
                                          • sli4
                                            Original NES power issues
                                            by sli4
                                            I recently turned on my old NES to find the red light won't go on at all. When powered on it shows black bars on the tv and a loud buzz through the tv speakers. Powering it off, the buzz goes away and tv goes back to normal (white snow).
                                            I tested the power supply itself and it is outputting 9V as it should - first two solder joints on the board at the power port show the same.
                                            Here's where it starts getting funky - When powered on, one side of the 7805 voltage regulator is showing 18V and the other is about 8.7V (center 0).
                                            On the big blue connector I get...
                                            11-28-2024, 12:52 PM
