Samsung / Hansol BN44-00428b
    Re: Samsung / Hansol BN44-00428b
    It is edge lit LED backlights setup, 4 LED strings total per diagram (from looking at the A and the B version, the component designators are not the same but using the same setup).
    I still do not understand by the LED does not even flash on once before going into shutdown, it will have to detect that one or more of the LED strings are not working by trying to fire up the LED, if it detect shorts or open, then it will go into shutdown.
    You may have to remove the LED strings and check each LED, you should also check to see if any one of the wires leading to the LED strings are shorted to the chassis.
    • kenny1070
      • Oct 2013
      • 65
      " (from looking at the A and the B version, the component designators are not the same but using the same setup) "
      That was my assessment as well, which is why I was able to use this solely as a template and simply substitute the designators to match (I little extra work, but sometimes you just have to do).
      " I still do not understand by the LED does not even flash on once before going into shutdown, it will have to detect that one or more of the LED strings are not working by trying to fire up the LED, if it detect shorts or open, then it will go into shutdown. "
      And this has been confusing me all along (and still does).
      Is it really flashing and I just didn't see it ??? - I don't know.
      Now that the panel is dis-assembled and I can clearly see the Leds, I may try it again.
      My only other thought would be in the IF1 & IF2 (of the 22 pin conn.) that I have yet been able to decifer. Do they play into the shutdown (protection mode) ?? - If so, how ??
      " You may have to remove the LED strings and check each LED, you should also check to see if any one of the wires leading to the LED strings are shorted to the chassis. "
      Can positively say that all the wires are good. I have verified this not only visually, but ohm and induced amp testing (power probe).
      I already ordered a replacement Led Bar - but would still like to know the how and why.
      I have never actually tested an led before (and don't even know how).
      But if you would be willing to teach me, I'd be more than happy to learn - and appreciative.
        You can use three 1.5 batteries connected in series to get about 4.5VDC then put a 220~330 Ohms 1/4W in series with the + lead, Then you can probe each White LED to see if it will light up, the Anode will be connected to the output end of the resistor, the negative will hook up to the Cathode, if you are not sure which is Anode or Cathode, you can just reverse the wire, you cannot damage the LED since it has resistor to limit the current.
        I still have to find time to read the training manual, too busy right now.
          "Samsung UN55D6400U" I finally had the time top look through the service and the training manuals, they are nothing like your BN44-00428 board at all.
          UN55d7000 uses BN44-00428A per shopjimmy.
          What voltage does the chart shows for the LED? 176V?
          As you can see, the Cathode return of the LED string is connected to the MOSFET that is turn on by the PWM circuit to set the brightness, if you use small Ohm resistor on the Drain pin (I.E, PIN 7 of CN801A) and ground, the LED for string 1 will come on but you have to make sure that you do have VF1~4 present.
          • kenny1070
            • Oct 2013
            • 65
            I saw that on shop jimmy as well.
            I do know that this set has never been serviced - since the day it was brand new, so I can't explain why I have this particular board. Wish I had a better answer.
            Been over this 1000 times, Can't believe I missed that whole block (wow).
            I guess that would have to make this 197v as designated by the key on the top / left corner (marked).
            46" - PSLF151B03A = 176v
            55" - PSLF171B03A = 197v
            So are you thinking that there is just not enough voltage being supplied to the Leds ?
              So you were only gettinG about 125VDC? That is probably not enough the forward bias the LED strings, I see that the filter caps for the VF are rated at 400VDC which is high for 125Vdc supply.
              The VF power supply (4) is a booster circuit (two MOSFETs and inductor, IC 9151S)) that boost the VDRV to higher voltage (low current) for supplying the LED strings.
              So what dc Voltage do you have at VDRV output? See page 3 of SCH, since VDRV is generated by the same transformer that also generates B13V and other voltages, see what you get on those outputs.
              • kenny1070
                • Oct 2013
                • 65
                Won't be able to re-assemble and test that until Sat.
                Working 13 + hr. days today and tomorrow.
                If you could help me out with exactly where I should be testing - that would be great.
                  You have to look at page 3 to see the VDRV and the B13 test points, but since the designators of the the REV A board do not match the REV B, you have to do some work to locate the test points.
                  • kenny1070
                    • Oct 2013
                    • 65
                    Here is what I found in/out of the TM801S.
                    Had to repost whole PDF annotated (see pg 3).
                    My DMM registered the A/C input in high voltage (HV).
                    I had absolutely no other output voltages from the unit - including B13.
                    Which is a little weird, because I register 13v at the CN801 connector & elsewhere at various jumpers.
                    Confused.
                      OK, it seems to me that the Vdrv is about right at 124VDC (Filter caps are rated at 200VDC), it means that the voltage booster circuits are not working to boost that 124V to 197V.
                      The IC9151S/9251S are not running. I cannot find the spec sheets for the IC to understand how it works yet. You may want to check the voltage at the VCC pins.
                      • kenny1070
                        • Oct 2013
                        • 65
                        OK, here's what I am finding :
                        - Unlike "B" board, the B13 is utilizing Both Mosfets from TM801S
                        - Vamp (17v) has no Mosfet - direct feed to CN801
                        Working up a diagram & pictures to explain a little better.
                        Here's the puzzling part:
                        - No output voltage from TM801S at B13 or Vamp (all 4 = Ground )
                        - Backfeed voltage only at all --- terminated at Diodes & Mosfets.
                        - Found Burn marks on terms 4, 5, 6 of TM801S ( B13 & Vamp output)
                        Could the lack of supporting voltage be the failure in boost ???
                        • kenny1070
                          • Oct 2013
                          • 65
                          So it turns out that you were right all along.
                          This is the wrong board for this machine.
                          In my earnest to try and track down an actual scheme and possible parts list, I called Samsung (J&J International). I spoke with their tech guys and they insist that there is absolutely no way that this board should have been in this model. Their only hypothesis as to the how, is that it may have been mistaken for the UN55D6400UR model (which does accept it) instead of the 6400UF (which does not). Basically, a clerical error.
                          So, obviously this board had to have been changed.
                          Gonna have to talk to my neighbor again (who gave it to me).
                          So it looks like I'm buying a new board - BN44-00428b.
                          Don't want to risk moving forward and frying something else.
                          • mmartell
                            • Oct 2013
                            • 3189
                            Hi Kenny did the new board fix your issue ?
                            • mmartell
                              • Oct 2013
                              • 3189
                              • asmilie
                                • Mar 2014
                                • 1
                                I recently had the same issue with my UN55D6420 after 2 years and 3 months. The television would intermittently reboot while watching and symptoms progressively got worse over the course of 4 months until the television would not turn on at all. I did unplug the TV for about 2 days and after plugging it back in, it seemed to work for about a day.
                                After reading multiple forums, I decided to replace the SMPS, which seems to have fixed the problem. There were no visible signs the board failed. If I get some free time, I may try to diagnose what on the SMPS board failed.
                                • Knackster
                                  • May 2014
                                  • 1
                                  Guys,
                                  I'm looking for the same board to replace in my TV but everywhere I look the board is out of stock.
                                  Anyone know of a reputable place that I can get one from?
                                  Thanks,
                                  Chris
                                  • 737mechanic
                                    • Jul 2013
                                    • 1
                                    *****Fixed******
                                    I had the same exact problem as the OP and this is what fixed my problem.
                                    I found that the main transformer TM801S had a cold solder if you look at the 3 pictures I posted. The first shows the front of the board with a yellow arrow pointing at the joint that was bad. The 2nd and 3rd show the back of the board with a yellow arrow pointing at the bad joint. I hit it with my soldering iron and problem fixed.
                                    BTW I found this problem because I just happened to see that joint arcing every time the power relay would click.
                                      • 31289
                                      some of the other joints are visibly cracked too.
                                      that's why some of us tell people to re-solder transformers sometimes.
                                      • relaxteb
                                        • Aug 2014
                                        • 2
                                        • netherlands
                                        #39
                                        Originally posted by 737mechanic
                                        *****Fixed******
                                        Seems i had the same problem. Found a cracked solder and resoldered it. Seems like that solved my click issue.
                                        • JOSman
                                          • Jan 2014
                                          • 2
                                          • Ireland
                                          #40
                                          I have the same problem, must try this.
                                          • hasel17
                                            CH341a can erase and read but can't write and blank check
                                            by hasel17
                                            So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                                            Code:
                                            Checking for blank...
                                            (Press
                                            10-26-2023, 06:20 AM
                                          • kotel studios
                                            Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                                            by kotel studios
                                            Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                                            State I got it in:
                                            Squealing from the PSU
                                            After logo I get a blank screen
                                            After 10 seconds of having a blank display w/ backlight the TV dies
                                            Give it 7-10ish seconds again and it starts to bootloop.
                                            What I did so far:
                                            Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                                            Checked all voltage rails:
                                            5VSB - 4.8V
                                            AMP+13V - 14.4V
                                            13V - 12.98V (in manual 12V)...
                                            09-21-2025, 02:00 AM
                                          • RetroComputingGrotto
                                            Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
                                            by RetroComputingGrotto
                                            I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
                                            I've uploaded a video of it happening on YouTube:
                                            I've taken the monitor...
                                            01-11-2024, 05:37 AM
                                          • Chrissygizmo
                                            Panasonic TX-48CX350B backlights but white screen , blank screen
                                            by Chrissygizmo
                                            Hi all, I’ve got a problem I hope someone can help me fixi.
                                            I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                            01-11-2025, 03:18 PM
                                          • Spoonicks
                                            ASUS VH238T blank screen with backlight
                                            by Spoonicks
                                            I am having a problem with a ASUS VH238T.
                                            The monitor started by just going blank, but the integrated speakers, and the backlight worked. The OSD didn't pop up, neither did the messages of DVI No Signal, nor the Asus logo.
                                            Turning off the monitor, and turning it back on made no difference. But leaving the monitor off for a few hours returned the monitor back to normal. The problem will eventually return after a couple of hours.
                                            Today, it started exhibiting another symptom: the display started showing a white image, that didn't take the whole screen....
                                            07-04-2023, 01:29 PM
