Philips 42PFL9603D won't turn on. Need specs for Lelon capacitors.
  • Globulus
    • Sep 2013
    • 20
    • Denmark
    My 2008 Philips 42PFL9603D won't turn on.
    Blinks red three times. Pause. Blinks red three times. Pause. Etc.
    According to the service manual, the description for this error is "12V" and the fault is in the power supply board.
    I took this board out of the tv. Everything (everything!) is clean. No leaks or bulging caps. No cracked solder joints. Fuse is fine.
    Having nothing to measure this with, I bought the MESR-100 v2 + M6013 combo on eBay and started out using the MESR-100 to do in in-circuit test of the caps. I have not used the M6013 yet as I do not want to take anything out of the board unless I absolutely have to.
    Here are the ESR results:
    (Part number on PCB: Cap label: MESR-100 result)
    2041: 1000uF 25V Rubycon 105C: 0,021 Ohm
    2042: 1000uF 25V Rubycon 105C: 0,021 Ohm
    2119: 2200uF 35V Rubycon 105C: 0,010 Ohm
    2120: 2200uF 35V Rubycon 105C: 0,022 Ohm
    2111: 330uF 200V Lelon REA 85C: 0,127 Ohm ?
    2105: 47uF 50V Lelon REA 85C: 0,866 Ohm *
    2169: 100uF 50V Lelon REA 85C: 0,354 Ohm *
    2126: 3300uF 16V Lelon REA 85C: 0,022 Ohm
    2127: 3300uF 16V Lelon REA 85C: 0,033 Ohm
    2170: 470uF 6,3V Lelon RGA 105C: 0,300 Ohm *
    2151: 100uF 25V Lelon RGA 105C: 0,515 Ohm *
    ? = Probably within spec
    * = Probably bad
    That last one on the list, by the way, is sitting right between two large heatsinks with maybe a millimeter on each side to spare.
    I only have the rough guide on the sticker of my cheap MESR-100 to go by. Where can I find the more exact (100kOhm) numbers from the manufacturer? I looked at the REA and RGA pdfs at the Lelon site as well as on http://www.paullinebarger.net/DS/Lelon/ (probably the same documents), but I cannot find any useful numbers in those documents.
    What next step would you recommend? Should I just replace the Lelons marked with an *in the list above or all of the Lelons now that the board is out anyway?
    Also: I thought it was usually the high-capacitance caps that were prone fail, but it looks as if those are all fine, including the 3300uF Lelons, whereas the low-capacitance Lelons are the ones that appear to be going bad - if I am reading this right. Perhaps they are just in the process of drying out?
    Again: No leakage or bulging. The tv just stopped turning on from one day to the next. Though it did seem to take longer to turn on and had problems changing DVB-T channels the last couple of weeks before it reached that point.
    Is it normal to have a mix of capacitor brands on the same board? If the engineers thought highly of Rubycon, I can't think of any other reason for populating 2/3 of the board with Lelons other than cost-cutting, but this is a top-of-the-range set we are talking about. How much could they have saved on this? $2?
    Finally: The only soldering iron I've got at the moment is a cheap (fixed-temp) 30W one. Is this too hot for this kind of work? I probably won't be using a soldering iron again for several years so I do not want to spend money on a variable temp soldering station. Should I buy a 15W Weller instead?
    BTW: Before I started looking at this, I had actually bought a 2013 model Philips (6000-series) to replace it, but because of its glossy panel, its atrocius/buggy SmartTV functionality, its sluggish/buggy control system, etc, I returned it two days later. Sad to say, but I want my 5-year old, great-sounding, ambient-light-sucking tv back in working order more than I want anything currently on the market.
  • capkid
    • Oct 2010
    • 1339
    Re: Philips 42PFL9603D won't turn on. Need specs for Lelon capacitors.
    Please post pics of the back of the TV with the cover off. The ESR seems marginally high on a couple caps, but I'm not sure it's high enough to cause a failure with three blinks.
    LG Plasma Mal-Discharge Correction Service
    • Globulus
      • Sep 2013
      • 20
      • Denmark
      Here are some pictures of the power supply board (removed from the tv) as well as some pictures of the signal processing board (still on the tv).
      The first image is a full view of the power supply board.
      Let me know if you need (more) closeups of anything.
      • Globulus
        • Sep 2013
        • 20
        • Denmark
        By the way: My power supply looks exactly the same as the one seen in an attachment to last year's thread on Philips 42PFL7403D (same tv size, brand, and year, but lower series):
        https://www.badcaps.net/forum/showthread.php?t=21879
        I read through the thread but did not come to any definite conclusions as to what to do with my own. They seem to be discussing a different problem.
        I would - as a start - just replace all the Taiwanese caps on my board, but the nearest electronics store is 50 miles away and charges something like $10 for shipping anything unless you buy for at least a certain amount, so I want to make sure I get my order right if and when I need to order something.
        • Globulus
          • Sep 2013
          • 20
          • Denmark
          Another thread discussing the same power supply:
          https://www.badcaps.net/forum/showthread.php?t=27208
          This time 42PFL9703D. One comment included a service manual for the same chassis but with a picture that actually matched my power supply board at the beginning. Another comment included a reference to a document with suggested rework areas.
          • Globulus
            • Sep 2013
            • 20
            • Denmark
            Replaced all the Lelon caps with Panasonics. Some of the high-capacity ones were measuring 10-15% below (e.g. 2950 instead of 3300), but nothing catastrophic.
            Unfortunately, I am still not getting any 12V power. Only the three blinks.
            • Caleb
              Smokin IC's
              • Feb 2013
              • 645
              Have you checked the output diodes for shorts? From the pics none of the outputs are labeled, can you show which pins are the 12v and a pic of the back of the power board as well could be helpful.
              Liberating magic smoke one part at a time
              • Globulus
                • Sep 2013
                • 20
                • Denmark
                I don't have the board out at the moment, but here are some crops of the front and the back of the board as well as part of the block diagram from the service manual.
                12V is provided on pins 6 to 8 on the 1M95 connector.
                Can you tell from those images if there are any components I should pay special interest?
                I will remove the board and take some pictures of the back sometime but won't have time to do it today.
                Please let me know if there is anything I can test before I remove the board again (i.e. whilst all the leads are still plugged in).
                I have tested the main fuse on the front and the two SMD fuses on the back and they are all OK.
                I have also tested at least some of the diodes but probably not all of them.
                The bridge rectifier should be fine (but then again, if it was not, then I suppose I would not get the 3.3V standby power).
                • Caleb
                  Smokin IC's
                  • Feb 2013
                  • 645
                  Are you getting 24v? it looks like 12 and 24v are both derived from the same source. 3v3 is off another transformer. If no 24v either check resistor 3147 supposed to be 150K supplies vcc to pin 8 of driver ic, there should be at least a couple volts (3v3?) present to pin 8. If that is ok I would check the fet 7102 (carefully!! 160v present when energized)
                  • Globulus
                    • Sep 2013
                    • 20
                    • Denmark
                    If I probe the 9045 (ground) and 9048 (12V) jumpers with the power on, I am getting 12V (12.13V) if - and only if - the 1M95 cable is *not* attached. In this case the big transformer will give out an audible buzz all the time.
                    If I *do* attach the 1M95 cable, the big transformer will give out the same audible buzz but only for about a second, after which it turns into an almost inaudible buzz. At no time - not even during that first second - am I getting 12V on the 9048 jumper when the 1M95 cable is plugged in.
                    As for 1M90 (the 24V Ambilight connector), I am getting 24.something V if the 1M95 cable is unplugged. With the 1M95 cable plugged in, I am getting 2.4V.
                    Maybe I am not testing this right.
                    As for the 3147 resistor, it is located on the back and my problem with this is that I do not right now have a bunch of cables/wires that would allow me to test the board whilst removed from the back.
                    • Caleb
                      Smokin IC's
                      • Feb 2013
                      • 645
                      OK so it sounds as if there is a short present on the other end of that jumper, if you are getting some voltages its a good bet the resistor is fine. Can you measure in ohms the resistance between the 12v pin and ground? this would be on the 1m95 cable (pins 6,7 and 8 are all 12v) with it detached from the power supply.
                      Do you happen to have a standard brake light bulb for a car laying about? if so you can give the power supply a dummy load by connecting the bulb between 12v and ground
                      +12v------Bulb------ground
                      If it lights and stays lit chances are the power supply is ok, depending on your supply you may need to have a load on the 24v rail as well in which case you can do the same thing just add in another bulb
                      +24v-----bulb----bulb----ground
                      another thing to try out is freezing the components around that transformer and see if the buzz goes away you can do this with a can of compressed air held upside down.
                      • Globulus
                        • Sep 2013
                        • 20
                        • Denmark
                        With the 1M95 cable detached from the PSU and SSB (i.e. both ends):
                        1M95 PSU side: 1.62 *K*Ohm between ground and 12V (6/7/8).
                        1M95 SSB side: 42 Ohm between ground and 12V (6/7/8).
                        Measurements taken with a $20 multimeter with a 200 Ohm - 20 M Ohm range. Not exactly a precision instrument but it will have to do.
                        I think I do have a 12V bulb somewhere but I do not think I have any cables for hooking it up. I really should get onto eBay and order a set of test leads + alligator clips.
                        • Caleb
                          Smokin IC's
                          • Feb 2013
                          • 645
                          42 ohm is really low, you need to start looking at the ssb. If it was me I would hook up a 12v 500 milliamp power supply (wall wart) tied to 12v and ground and freeze spray the board, then see what melts the fastest. Generally it will be your short. However most of that board is fine pitch stuff, if you can prove the fault into the ssb you might be better off getting a replacement. I would bet its probably one of those tiny fets 7u05, 7u08, possibly driver chip 7uoa, or maybe 7u02 or 7u06. I suppose it could also be a short on 2u14 or 2u0y capacitors but pretty unlikely -schematic is on page 96 of the manual.
                          To test the power supply I usually just solder the bulb in wherever its convenient, but you can unclip the wires from the ssb side of the connector and hook to them with alligator clamps.
                          • Globulus
                            • Sep 2013
                            • 20
                            • Denmark
                            I have a 12v 500mA wall wart but would have to get some test leads and freeze spray for this.
                            You are right in saying that I will be better off replacing the SSB board, as it would be very difficult for me to replace anything on it without tearing it up.
                            As for replacing the SSB board, that is probably not going to happen. No such board for sale on eBay or the usual LCD scrap yards at the moment. The flea market at the www.repdata.de forum is littered with post from people looking for this board - not selling it. As one person wrote (in German): "Very difficult to find as nearly all of them have problems with the BGA chip".
                            It is possible that the tv has been having problems for a long time before it gave up. When it worked, it used to freeze the sound and/or picture whenever I used a switch (e.g. lights or just opening/closing my fridge) in my home. Any switch. It would also have great difficulty switching channels, i.e. it would appear to switch, then go black as it tried again, and eventually it would bring up the channel, after which there were no problems (other than being susceptible to interference from the rest of the house).
                            I just presumed that it was because my poor reception (DVB-T, aerial antenna in the attic), but when I briefly had another tv (2013 model) in my home, there were no problems at all.
                            I know that not all tv tuners are born equal, but in this case the problem got noticably worse the last few weeks before it died.
                            Anyway: I am starting to give up on this. It is probably better if I just buy a new tv and give the old one away to someone who can be bothered to fix it or go through the hassle of selling the working parts. Or buy an identical set used and use the old one as spare parts, if necessary. The problem is that there are hardly any of these sets around.
                            • Globulus
                              • Sep 2013
                              • 20
                              • Denmark
                              Actually, my parents have the exact same set. To be honest, the easiest thing would have been to start swapping out boards from the beginning, but I already know that as far as they are concerned, a tv is a black box which should not be opened by anyone but an authorized repairman, so I did not even ask them if I could use their perfectly working set for my experiments.
                              So come to think of it, maybe I should just keep my set and use it as spare parts for their set in case theirs exhibit a non-SSB problem some day.
                              • Caleb
                                Smokin IC's
                                • Feb 2013
                                • 645
                                If you get some chipquick you can remove the small components pretty easily. I would try out the freeze spray. I bet those little fets are less than 3 bucks each, and most of the pins are connected together so soldering doesn't have to be super accurate.
                                  You can try isolating the shorted circuit by lifting one end of these inductors (5u02, 06, 08, 09) one at a time to see if 42 Ohms resistance will go up.
                                  • Globulus
                                    • Sep 2013
                                    • 20
                                    • Denmark
                                    OK, I might try that, but I will probably have to put it on hold for a few days or a week. Other priorities right now (though 3+ weeks without a tv is starting to take its toll).
                                    I appreciate all of your suggestions.
                                    • Globulus
                                      • Sep 2013
                                      • 20
                                      • Denmark
                                      Another 101 question: What is the difference between "freeze spray" sold by electronics stores and "cold spray" sold by sporting goods stores?
                                      Can I just use the latter? The reason I am asking is that I do not have an electronics store nearby so I cannot simply pop by one of those in order to buy a single, cheap item, i.e. I either have to bundle my purchases in order to get free shipping or pay far too much (relatively speaking) for shipping when buying individual items.
                                      So "cold spray" (for treating injuries) is much more accessible to me, but would it work? I did notice that those selling "freeze spray" for electronics point out that it is not flammable whereas the "cold spray" for treating injuries is highly flammable, but maybe they are just talking about whatever comes out of the cans vs. throwing the can on the fire, i.e. different things.
                                      I have also read that a duster turned upside down can be used, though some warn that it might leave gunk on your PCB. I am a little curious as to whether a 400 ml duster used in that manner has a shorter life than a 400 ml ("proper") freeze/cold spray?!?
                                        I'd imagine unlike freeze spray, cold spray may or may not be conductive.
                                        I have had good luck using cans of compressed air. Inverting the can makes the refrigerant come out which acts as a good freeze spray analogue.
                                        • Sharpa
                                          Repair attempt Philips 55OLED804/12
                                          by Sharpa
                                          I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                                          The symptoms when bought: Philips logo appears then tv turns off
                                          Things tried so far:
                                          1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                                          2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                                          11-22-2025, 08:30 AM
                                        • alro7779
                                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                          by alro7779
                                          Hello, guys!
                                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                          09-14-2025, 12:25 AM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • double_DD
                                          Philips curling iron - is this a common AC cable?
                                          by double_DD
                                          Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                          As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                          Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                          08-18-2025, 10:04 AM
                                        • janos6662000
                                          Philips 47PFS7509/12 LCD TV problem
                                          by janos6662000
                                          Hi
                                          I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                          When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                          I downloaded original firmware and applied the update, but the problem remained.
                                          From a colleague i received a "factory package software" which is a lot bigger.
                                          I made another firmware update, but still did not solve the problem.
                                          Somewhere on the way the error got worse, because at the moment the...
                                          08-12-2025, 12:54 PM
