Sceptre X505BV-FMDR
  • BadGoo
    • Dec 2014
    • 22
    Re: Sceptre X505BV-FMDR
    Alright. I've discovered something odd in my opinion. I was testing the connections here from the LED driver board to where it connects at the bottom of the TV. I'll try to explain it clearly.
    When I disconnect FIG B. and test continuity of each wire, they all have continuity with ground and/or each other.
    When I disconnect FIG. A (from the bottom of the TV), there is no continuity between the wires except similar (red, black).
    FIG B. pins all test fine (no continuity except similar)
    FIG A. pins all have continuity.
    Is this normal?
    In the 3rd photo, I'm getting 6.6v from that connector which leads into the back of the chassis.
    • BadGoo
      • Dec 2014
      • 22
      bump.
      • BadGoo
        • Dec 2014
        • 22
        Well, I replaced the PSU board with no result. At the connection that goes to the LED back-light, I'm only getting 7v.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8352
          what do you get if you unplug that cable? Does the voltage ramp up and then fall down or what? Also measure the BLon pin against chassis GND.
          • BadGoo
            • Dec 2014
            • 22
            If the Back-light cable is unplugged, I get ramp up to about 300v then falls down to 7v in about 10 seconds and the same if it is plugged in.
            As far as the BLon pin, I get nothing if the harness isn't connected to the main board. If it is, it's 3v at the PS and 4.5v at the main board.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8352
              So you got a bad backlight led, as there is an open. Nothing wrong with the PSU.
              • BadGoo
                • Dec 2014
                • 22
                Alright. Is it worth trying to replace the LED strips? At first look, I can't seem to find any LED strips online with the part number that's on them. Each one has 7 LEDs and a total of 10 strips.
                2 LEDs are bad. The rest light up when tested. I highlighted them in the photo.
                Thanks for the help!
                • BadGoo
                  • Dec 2014
                  • 22
                  I've searched and searched for the LEDs and have come up empty. Does anyone have any other resources or a connection to get these? If I could figure out what LED is being used, I'd just rework it onto the strip.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5095
                    • New Zealand
                    #29
                    Perhaps if you can figure out the package type and then search for LEDs in that package type at Digikey or eBay etc.
                    -David VanHorn
                    • BadGoo
                      • Dec 2014
                      • 22
                      I believe the package is PLCC-2. I grabbed a few to test out and they are close but not nearly as bright at the same voltage. Does anyone know what a typical LED rating is for LED Back lit TVs?
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5095
                        • New Zealand
                        #31
                        I'd not be surprised if they overdrive them somehow. It would explain why the die all the time.
                        -David VanHorn
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8352
                          Take an old working led and fire it up with a variable power supply. Measure voltage and current with a lab PSU. It should get you in the ball park anyway. Since the new ones are darker than the old ones, that means the voltage rating on the new ones are higher than the old.
                          • Peter Chiu
                            Banned
                            • Dec 2012
                            • 145
                            Highly recommend for every Tech : LED SOLDER PASTE (Lead-free SMT Low temperature solder paste) Sn42 bi58 138°C. Ebay has it.
                              Most LED backlights for TV are driven over 100 mA,
                              • Peter Chiu
                                Banned
                                • Dec 2012
                                • 145
                                I am so cheap ! I used Rose's metal to desolder the IC (Melting point is 95 °C),after that collect all the desolder beads then use for low-temperature soldering (like led, now the melting point may be 120°C-140°C). The secret is Bismuth.
                                Rose's metal. It is a eutectic alloy of ~ 32 % lead, ~ 50 % bismuth, ~ 18 % tin by weight. Melting point is 95 °C Applications: low-melting solder
                                • Alastair E
                                  Chief Womble
                                  • Mar 2013
                                  • 1963
                                  • U.K.
                                  #36
                                  Originally posted by Peter Chiu
                                  I am so cheap ! I used Rose's metal to desolder the IC (Melting point is 95 °C),after that collect all the desolder beads then use for low-temperature soldering (like led, now the melting point may be 120c-140c). The secret is Bismuth.
                                  Nothing wrong with Cheap!--I Like Cheap.....
                                  What you basically made is 'Chipquick' that low-temp de-soldering aid--thats hideously expensive for what it is!
                                  TELEFIX
                                  • BadGoo
                                    • Dec 2014
                                    • 22
                                    I tested them out of the unit. Even @ 3.3v the original LED is much brighter than the ones I bought @ 3.3v. What directly affects this? mcd rating etc.? I don't mind buying LEDs to test, I'd just rather not have 100s of LEDs.
                                    These are the two I tried first.
                                    ASMT-UWB1-NX3B2
                                    ASMT-UWB1-NX302
                                    • Peter Chiu
                                      Banned
                                      • Dec 2012
                                      • 145
                                      I did fix two of the LED screens, I am so cheap ...All I do just shorted the LED (by copper thin wire). It work Ok. You won't notice if u don't pay attention to it. .It's a 32 inch cheap TV anyway. I may not do it to the 50 inch TV.
                                      P.S:
                                      If not bright enough just put series or parallel two leds together.
                                      If too bright put some resisters will work.
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5095
                                        • New Zealand
                                        #39
                                        The problem with that is the voltage across the remaining LEDs will now be slightly higher, so they will die quicker.
                                        -David VanHorn
                                        • Peter Chiu
                                          Banned
                                          • Dec 2012
                                          • 145
                                          Willyam1: {The power supply is AY160D-4HF01. an ic BD9211F that drive the leds section. pin 1 vcc=11.8v pin 2 stby on /off 4.65v ther no pulses in the output pin 18+17 could be the bad ic?}
                                          I think IC is in protection mode! Pin 13(Error Indication signal Output) is FAIL...... Normal : L Error : open
                                          CapLeaker:{So you got a bad backlight led, as there is an open. Nothing wrong with the PSU.}
                                          Wow !!!!!You're GOOD !!!!!!
                                          I am more interested to know, how to troubleshooting next LED TV
                                          There are ways to test the LED light.
                                          1. use dumping-load to test the power supply see if output are DC 190v - 400v
                                          2. Use the out side power supply give LED the right testing voltage and constant current( may blow all the LEDs).
                                          3.unprotected the IC BD9211, Maybe Pin 5 (FB) to ground. Force the LED screen to light up. Anybody! Please, Let me know?
                                          Last edited by Peter Chiu; 03-25-2015, 03:18 PM. Reason: can't not up load a picture
                                          • howardc64
                                            Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                            by howardc64
                                            Problem
                                            Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                            Model & Board Pics
                                            Conflicting Spec
                                            Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                            https://www.shopjimmy.com/vizio-gj-2k1...
                                            10-10-2024, 01:16 PM
                                          • eccerr0r
                                            inverter H tree driver imbalance in an AC inverter
                                            by eccerr0r
                                            My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                                            11-16-2025, 12:34 PM
                                          • x_orange90_x
                                            Vizio E55-E1 bad backlights or bad inverter?
                                            by x_orange90_x
                                            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                            I don't know how exactly to test the inverter itself. Is it...
                                            01-29-2025, 09:24 PM
                                          • Gentian
                                            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                            by Gentian
                                            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                            03-06-2023, 07:07 AM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
