Panasonic TCL32C12 13 blinks on red light
  • Thomas Capper
    • May 2013
    • 19
    • usa
    I picked up a Panasonic TCL32C12 which has power but no picture. My research led me to discussions that the blinking red light is for diagnostic purposes.
    My tv blinks 13 times which is a A board issue. Does anyone else have this model OR has anyone fixed this board without buying a new one?
    I uploaded a picture an A board for reference.
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    Re: Panasonic TCL32C12 13 blinks on red light
    Post hi Rez picture of the power board.
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
    • Thomas Capper
      • May 2013
      • 19
      • usa
      I didn't post that picture of the power supply because what I found pointed to the A board. I'll post a picture If it will help.
      • R_J
        • Jun 2012
        • 9535
        I just repaired a Panasonic that had 13 blinks, what I found was 2 pennys stuck into the SD card slot, i unplug the cable going to the sd card and the tv came on. this was on a th-42px75u
        I have replaced these A boards in the past under warranty but never repaired them, if I recall panasonic did'nt even want the old boards back because they were'nt repairable.
        here is the error code for a tcl32c22
        Blinking times Contents BOARD
        1 BACK LIGHT_SOS P BOARD
        3 PANEL POWER_SOS A BOARD
        4 DTV12V_SOS P/A BOARD
        7 SUB 3.3V_SENSE A BOARD
        9 SOUND SOS A BOARD
        13 EMERGENCY_SOS A BOARD
        • Thomas Capper
          • May 2013
          • 19
          • usa
          Darn. I'll try my multimeter on various components and take a chance. Purchasing a new board will be my last resort.
          • Thomas Capper
            • May 2013
            • 19
            • usa
            The diagnostic blinks for this model tv is great. The 13 blink code for the A Board is absolutely correct. It gave me a starting point of where to start looking.
            I opened up the tv and went straight to the A board. Within a few seconds I found my problem. The solder joints on what looks like a fuse were broken.
            I resoldered it and that fixed the problem. The repair was done in minutes. I may not be as tech savvy as some of the vets here but I'm trying to contribute and share my experience with the site.
            In the pic I circled the fuse in red.
            THANKS AGAIN TO THE PEOPLE OF BADCAP.
            • DjKrish
              • Oct 2012
              • 354
              • SG
              Theres a reason why fuse blows. On a common case, Something else is faulty then for safety reason these fuse blows. U might have jump cable these fuses and the set works but im afraid something else might blow straight since the fuse is directly shorted. U might wanna double check the circuits and the voltages if all is in correct order.
                Great job locating the problem, that component looks like an inductor. That section with 3 round inductors are for switching power supplies. That inductor looks like is for feeding B+ to the three 8-pin MOSFETs.
                • Thomas Capper
                  • May 2013
                  • 19
                  • usa
                  That little component didn't blow, it was a bad solder joint that broke. The tv is fine. In fact I just connected it to my pc and its working great.
                  I'm using it now as I type this.
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                    Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                    by sam_sam_sam
                    I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                    This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                    After all of...
                    07-13-2024, 08:14 PM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • Alicat
                    Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                    by Alicat
                    Stopped by this site trying to fix my parents Panasonic Plasma TV.
                    Model number is TH-50PZ85U
                    Power comes on and the red power light stays on solid.
                    Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                    I also hear a few clicks.
                    I also think my parents said there was a thunderstorm and the TV failed after that.
                    Section 6 in the service manual talks about power and no screen,...
                    10-30-2024, 10:09 AM
                  • Biruslapio
                    Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
                    by Biruslapio
                    Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
                    It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
                    It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
                    02-16-2021, 09:44 PM
