Olevia 265-t12 - no place to turn but the Internet
  • chcbearsfan
    • Oct 2011
    • 32
    Hello everyone. New to the forum here. Been loking for a solution but unable to find one. Someone sent me from rc forums and spoke highly of your community. I am really hoping someone can help me out.
    The backstory....
    I have an Olevia 265-t12 LCD that has been good for a few years. No known events but unexpectedly when I power on the TV, the Olevia splash screen comes on then the backlight goes out. Screen is dark.
    I called out the Geek Squad and they came in, looked at the problem, said it was the inverter board and that they couldnt source the parts. Left and didnt charge me. I talked to a couple of shops around and they dont seem interested in looking at it because they cannot get parts. I was surprised I was dissuaded from bringing in the unit even from my mom and pop tv repair shop. I dont have many options....
    So I have been searching the Internet and posting on forums and justanswer looking for some assistance. I check the Inverter and even replaced the master and the problem continues.
    I am not sure how to troubleshoot this. I am not an EE but a network engineer so I am adept at troubleshooting process but can recognize when I am in over my head. When we get to LCD components....well I am in over my head.
    Is there any kind soul out there that can help me isolate and ultimately fix the issue? It was a 2500 TV in 2008 and my wife will kill me if its dead already because getting this thing was a fight in the first place.
    Anyway....I am losing hope and was hoping someone out there can give me some help and get this sucker showing my movies again. Help please?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Olevia 265-t12 - no place to turn but the Internet
    The backstory....
    It's not surprising that you got little help from the regular TV service shops. For economic reasons most of them are little better than board swappers. Your problem is often referred to as 'two seconds to black'.
    Many manufacturers used different subassemblies in their TVs. The first thing I need is a picture of the back of your TV (with the back removed). If you can also provide a picture of the inverter, that will help.
    PlainBill
    • chcbearsfan
      • Oct 2011
      • 32
      PlainBill
      Fantastic. I am at work but will get those pictures this evening
      Thanks so much
      • chcbearsfan
        • Oct 2011
        • 32
        I attached the pictures of the back of the LCD and from what I can tell are the master and slave inverter boards. Each of these has an inverter board directly above and below.
        Is the 2 seconds to black a typical easy fix? What am I looking at?
        Thanks.
        • PlainBill
          • Feb 2009
          • 7034
          Thanks.
          Two seconds to black has several possible causes, including bad caps, bad transformer, bad CCFL, bad component in the protection circuit. The Cliffs Notes version - the inverter controller monitors the condition of the inverters. If any CCFL is drawing too much or too little current, it is shut down.
          On the lower end of the transformers are four pins. These are PROBABLY the ends of the secondaries. Since I don't see any numbers, I will arbitrarily number them 1 thru 4 from left to right. Set your DMM to the 2K range and measure the resistance between pin 1 and pin 2, then between pin 3 and pin 4. Record the numbers, and repeat for the other 17 transformers. The readings should match to within 3%. If any reads open, or too low or too high, you have a bad transformer
          PlainBill
          • retiredcaps
            • Apr 2010
            • 9271
            2 seconds to black can be
            a) bad caps
            b) bad inverter transformer
            c) bad ccfl and/or ccfl wiring
            a) The caps on the inverter board are Rubycon ZLH so they are quality caps and should be okay.
            b) Measure the resistance between the secondary inverter transformer pins on all your transformers. They should be within 3% of each other. On one 26 inch TV that I picked up, it has the same symptoms and one of the 4006A transformers has an open winding.
            c) This one is harder to deal with on a TV versus lcd monitor.
            More details about 2 seconds to black can be found in posts #13 and #14 at
            edit: As I was writing this, I didn't see that PlainBill had already responded. Oh well, you got the same info just different wording.
            Last edited by retiredcaps; 10-07-2011, 10:31 PM. Reason: PlainBill already answered the question
            --- begin sig file ---
            --- end sig file ---
            • chcbearsfan
              • Oct 2011
              • 32
              Thank you both for such great responses. I am new to component troubleshooting so I apologize if any of my questions are remedial. Please bear with me, I will pick this up quickly.
              Retiredcaps is correct. The capacitors say Rubycon ZLH and from my visual inspection I havent found any to be bulging or leaking. Although I know that may not be a tell all.
              The transformers each have 4 soldered pins on the side which provides the power to the backlights. On the other side there are 6 pins that are soldered to the board. There appear to be other pins that are not soldered.
              I am not sure which pins I should be testing. Can you help me clarify?
              Also the board is RDENC2243TPZZ IM3818-1 on the master. The slave and other boards are the same board with the ending number changing (IM3818-2, IM3818-3, etc.)
              The transformers themselves have a number stamped on them:
              NMB 0016
              L7717
              I'll be glad to take more pictures and try to get clearer closer pictures on the componenets themselves if it helps.
              Thanks alot for the help, its truly appreciated.
              • PlainBill
                • Feb 2009
                • 7034
                NMB 0016
                L7717
                Sorry for my lack of clarity. I failed to notice the two pictures were inverted with respect to one another.
                I've marked up the picture I was referring to, numbering the pins 1-4. Set your DMM to the 2000 (2K) ohms scale. Measure the resistance between pins 1 and 2 and also between pins 3 and 4 on every transformer (not just the two I marked), then report the readings. I note the transformers have identifying numbers (T21, T22, etc). Use the identifier when you report the resistances.
                If by some chance the meter reads open on 1-2 and 3-4, try reading 1-4, then 2-3. If that is also open on both transformers, report and I'll give further instructions.
                PlainBill
                • chcbearsfan
                  • Oct 2011
                  • 32
                  I wonder if I am doing something wrong or if there is a problem with my multimeter.
                  I set the DMM to 2K and touch the tips together to confirm function and it moves from 1. to .000. it seems to pause for a brief second on .001 or .002 before zeroing out. If I set the DMM to 200 it gives me a reading of .4. The DMM I am using is a SPERRY DM-350A. Tests voltage fine. I have the red lead in the ohm out (looks like a horseshoe) and the black in the COM port.
                  If I try to set any combination of pins 1-4 the meter does not move at the 2K or the 200. If I check the fuses (thats what they look like anyway) I receive a consistent reading of .5 on all three on the board I tested (the master).
                  I checked both a mounted and unmounted inverter boards but not with power on it. Do I need to have it powered up?
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    It looks like your multimeter is working fine and you are doing the measurements correctly.
                    Resistance is always measured with power off and device unplugged.
                    If you are getting "1" on the left hand side, it means we have not identified the correct secondary pins. What we are trying to do is identify the secondary pins as per (this isn't your transformer, but just an example)
                    http://lcdparts.net/TransformerDetai...ProductID=3191
                    What is the writing on the transformer?
                    • chcbearsfan
                      • Oct 2011
                      • 32
                      Thanks, I figured the power is supposed to be off but I dont want to make any assumptions. The markings on the transformer is "NMB 0016 L7717" and it has NMB stamped on the end of each coil. I feel like I have tried every combination on the thing but still not getting any readings other than the 1.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Okay, let's try brute force. Report all readings for all combinations by following section 4 at
                        https://www.badcaps.net/forum/showpo...1&postcount=14
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          To be crystal clear, you now have 10 pins to measures for each transformer. The 4 PlainBill numbered and the "top" 6. So you need to measure
                          1-2, 1-3, 1-4, 1-5, 1-6, 1-7, 1-8, 1-9, 1-10
                          2-3, 2-4, etc, 2-10
                          3-4
                          9-10
                          edit: and you want your multimeter set on 2,000 (2K) ohms for all these tests.
                          • PlainBill
                            • Feb 2009
                            • 7034
                            And reexamining the picture, the pin in the upper right corner is clearly marked 1. By the usual convention, numbering is counter-clockwise, so the pin I called 1 is actually 7.
                            PlainBill
                            • alexanna
                              • Mar 2010
                              • 1346
                              If the pins on the transformer have any kind of 'crap' on them you may need to scrape it off,It will give you a better shot at getting a reading.
                              • chcbearsfan
                                • Oct 2011
                                • 32
                                So measuring just pin one against all I get the following in sequence I get the following. The first number is red probe, the second is black probe and the output after the equal.
                                Capacitor T5 on the master board 3818-1
                                1-2 = 1.
                                1-3 = .001
                                1-4 = .000
                                1-5 = 1.
                                1-6 = .001
                                1-7 = 1.
                                1-8 = 1.
                                1-9 = 1.
                                1-10 = 1.
                                2-1 = 1.
                                2-3 = 1.
                                2-4 = 1.
                                2-5 = .598
                                2-6 = 1.
                                2-7 = 1.
                                2-8 = 1.
                                2-9 = 1.
                                2-10 = 1.
                                3-1 = .001
                                3-2 = 1.
                                3-4 = .001
                                3-5 = 1.
                                3-6 = .000
                                3-7 = 1.
                                3-8 = 1.
                                3-9 = 1.
                                3-10 = 1.
                                4-1 = .000
                                4-2 = 1.
                                4-3 = .001
                                4-5 = 1.
                                4-6 = .001
                                4-7 = 1.
                                4-8 = 1.
                                4-9 = 1.
                                4-10 = 1.
                                5-1 = .1
                                5-2 = .598
                                5-3 = 1.
                                5-4 = 1.
                                5-6 = 1.
                                5-7 = 1.
                                5-8 = 1.
                                5-9 = 1.
                                5-10 = 1.
                                6-1 = .001
                                6-2 = 1.
                                6-3 = .000
                                6-4 = .001
                                6-5 = 1.
                                6-7 = 1.
                                6-8 = 1.
                                6-9 = 1.
                                6-10 = 1.
                                7-1 = 1.
                                7-2 = 1.
                                7-3 = 1.
                                7-4 = 1.
                                7-5 = 1.
                                7-6 = 1.
                                7-8 = 1.
                                7-9 = 1.
                                7-10 = 1.
                                8-1 = 1.
                                8-2 = 1.
                                8-3 = 1.
                                8-4 = 1.
                                8-5 = 1.
                                8-6 = 1.
                                8-7 = 1.
                                8-9 = 1.
                                8-10 = 1.
                                9-1 = 1.
                                9-2 = 1.
                                9-3 = 1.
                                9-4 = 1.
                                9-5 = 1.
                                9-6 = 1.
                                9-7 = 1.
                                9-8 = 1.
                                9-10 = 1.
                                10-1 = 1.
                                10-2 = 1.
                                10-3 = 1.
                                10-4 = 1.
                                10-5 = 1.
                                10-6 = 1.
                                10-7 = 1.
                                10-8 = 1.
                                10-9 = 1.
                                  You may need to retest it on the 20K range.
                                  • chcbearsfan
                                    • Oct 2011
                                    • 32
                                    What should I be expecting to see? The 1. should have value or the .000/.001 should have more specific value? It looks like there is continuity between 1-3-4-6 and 2-5 but nothing to 7-8-9-10.
                                      Values from 1.00k to 10.00k are typically expected for those types of transformers.
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        2-5 = .598
                                        Okay, 2-5 is your magic combination. Test every inverter transformer with pin 2-5 combo. If 598 ohms is the "correct" reading, every measurement should be +/- 3%.
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                        • robante15
                                          Acer Aspire 4520 won't turn on after reboot
                                          by robante15
                                          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                          If I remove the...
                                          04-06-2024, 06:50 PM
                                        • masoksian
                                          Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                          by masoksian
                                          Hi everyone,
                                          I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                          The system does not turn on, there is no post.
                                          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                          The problem continues in the same way.
                                          I tried to turn on the Fn key, nothing came to the screen....
                                          02-15-2025, 12:08 PM
                                        • eccerr0r
                                          inverter H tree driver imbalance in an AC inverter
                                          by eccerr0r
                                          My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                                          11-16-2025, 12:34 PM
