An ultrafast rechargeable aluminium-ion battery
    http://www.nature.com/nature/journal...ure14340.html?
    If it is true, that will be one of a great break through in batteries development.
    • 31197
    Re: An ultrafast rechargeable aluminium-ion battery
    aluminium - i bet that burns real good once it gets started!
    • redwire
      • Dec 2010
      • 3912
      Charging time of one minute, 98% efficient, flexible, 7,500 cycle life
      It looks really promising. "The electrolyte is basically a salt that's liquid at room temperature, so it's very safe"
      "Currently, one of the prototype battery's biggest shortcomings is its voltage. Although Dai points out it is more than anyone else has achieved with aluminum, the battery only generates around two volts of electricity, which is around half that of a typical lithium-ion battery. However, the researchers are confident they can improve on this. http://www.gizmag.com/aluminum-ion-b...tanford/36936/
        "Rechargeable aluminium-based batteries offer the possibilities of low cost and low flammability, together with three-electron-redox properties leading to high capacity3"
        "The battery operates through the electrochemical deposition and dissolution of aluminium at the anode, and intercalation/de-intercalation of chloroaluminate anions in the graphite, using a non-flammable ionic liquid electrolyte. "
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          in 15 years we might see these.
          this is the trolling for investers stage.
          • redwire
            • Dec 2010
            • 3912
            You're right, usually these kind of articles are PR for researchers to get more grants and funding.
            Get this quote from Thomas Edison:
            "The storage battery is, in my opinion, a catchpenny, a sensation, a mechanism for swindling the public by stock companies. The storage battery is one of those peculiar things which appeals to the imagination, and no more perfect thing could be desired by stock swindlers than that very selfsame thing. … Just as soon as a man gets working on the secondary battery it brings out his latent capacity for lying."
            Lithium Ion batteries are ~30 years old. First papers on lithium ion batteries were published in 1980, commercialized by Sony in 1991.
            So we need around 10 years?
            • Spork Schivago
              • Mar 2012
              • 4734
              • United States of America
              I think with these, they might come a bit sooner than 10 years. There's a high demand for something a bit greener. With lithium ions, maybe there wasn't such a demand back in the 80's? I don't really remember much from then, I was born in 81. I was just thinking maybe perhaps back then, technology wasn't advancing as quick as it is today. Just a thought.
                • 31197
                Toshiba is selling a new battery now, i think it's LiTi (Lithium-Titanium)
                massive cycle life and the ability to constantly charge & discharge it without damage.
                they are marketting it for solar storage.
                https://www.toshiba.com/tic/industri...rgable-battery
                  It has been around since 2011:http://www.greencarcongress.com/2011...-20111117.html
                  I wonder beside Honda, who else is using it. It sounds very good based on the spec.
                  "The SCiB charges in about half the time of a typical Li-ion battery, Toshiba says. An SCiB 20Ah cell charged with an 80Ah current will reach 80% of capacity in 15 minutes and 95% in an additional 3 minutes" I never hear Honda claiming about quick charge either.
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • mkdj
                    ASUS X571 no power : battery issue?
                    by mkdj
                    Mark and model: ASUS X571
                    Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                    Tests already made:
                    - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                    - I have removed...
                    07-14-2025, 09:16 AM
                  • techfreak9356
                    Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                    by techfreak9356
                    I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                    09-14-2023, 11:10 PM
                  • ferah831208
                    Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                    by ferah831208
                    Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                    03-18-2025, 01:18 AM
                  • huzo
                    HP ELITE X2 1013 G3 weird battery issue
                    by huzo
                    Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                    01-31-2025, 12:09 AM
