HP DV6 6080ep - GPU ATI
  • magneh
    • Apr 2014
    • 615
    • Portugal
    Hello!
    A friend of mine brought his DV6 with GPU problems.
    The laptop has intel integrated graphics and an ATI gpu.
    A month ago, he was unable to enable the ATI and could only work with the laptop with the integrated Intel graphics.
    He told also that the laptop when turning on, if the fan would start full speed, we would'nt turn on.
    To work on it he had allways to force the Intel graphics, most of the times removing the plug to force battery mode.
    If the ATI was activated in Windows, the image would come blurry and unreadable.
    Well, I removed the BGA and cleaned it. Reballed it and tested it.
    When I booted into windows I allways get a BSOD related to atipackage.
    Installed a fresh OS, laptop works fine until I try to install the ATI.
    Mesured the SMD's on the chip and found 4 of them with 0.6 ohm (see picture).
    Any thoughts?
    BGA is dead?
    Should I order a new one?
    Another issue is that the BGA has the code unreadable, and so I dont know wich BGA order to replace this one in case of need.
    Waiting for your follow ups!
    Thanks!
  • magneh
    • Apr 2014
    • 615
    • Portugal
    Re: HP DV6 6080ep - GPU ATI
    Hello!
    Update : the BSOD is the atikmdag.sys.
    • magneh
      • Apr 2014
      • 615
      • Portugal
      Some screens of the Gpuz before installing ATI drivers
      Nice temps and core clock
      • jtamad44
        • Apr 2013
        • 145
        • israel
        check this out
        http://forums.guru3d.com/showthread.php?t=363233
        • magneh
          • Apr 2014
          • 615
          • Portugal
          The 0.6 ohm in 4 of the small capacitors isn't a sign of bad BGA chip?
          Could it be just a software/drivers issue?
          • magneh
            • Apr 2014
            • 615
            • Portugal
            Well bought an ATI 216-0752001 new chip.
            Gonna wait for him to arrive and put him on the board... and see if the issues are gone!
            • jtamad44
              • Apr 2013
              • 145
              • israel
              If you can't install the driver of the old chip after you reflowed or reballed it, you must replace it.
              • lefos
                • Nov 2013
                • 321
                • Greece
                This chipset is known to be faulty.
                Change it to be sure.
                • whaldsz
                  • Apr 2013
                  • 395
                  • Philippines
                  indeed, you need to replace this chip.
                  • magneh
                    • Apr 2014
                    • 615
                    • Portugal
                    Waiting for the BGA to arrive and gonna swap it
                    I'll share the results...
                    thanks!
                    • magneh
                      • Apr 2014
                      • 615
                      • Portugal
                      Hello!
                      After a big mess with getting the right BGA from the supplier, I got the correct one a few days go.
                      So I attached him to the board and ... working like a charm!
                      A few pics.
                      Thanks for all the help!
                      Cheers,
                      • jtamad44
                        • Apr 2013
                        • 145
                        • israel
                        Great job magneh!
                        • dj_ricoh
                          • 2073
                          • uk
                          Hello!
                          A few pics.
                          Cheers,
                          that chip got more one type of balls?
                          what size did you use?
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1489
                            • portugal
                            dj_ricoh best chip source you can get BRAND NEW , factory sealed .. GOLDEN CHIPSET ...since started to buy from them .. never had any troubles or machines coming back .. altough very good prices.
                            • teknikbursa
                              • Sep 2014
                              • 64
                              • turkey
                              good job, thanks
                              • Ramee
                                • Jul 2014
                                • 218
                                • Israel
                                Can you guys share the link of the store. Is that on ebay or Aliexpree?
                                • dellxps15
                                  • Feb 2014
                                  • 1598
                                  • italy
                                  first time i bought something from them was about 490$
                                  all seems ok to what they sell
                                  ps: good work magneh
                                  • senchire
                                    • Dec 2012
                                    • 190
                                    • Bosnia
                                    Hmm to be honest for new chips they aren't that expensive actually quite a good price .
                                    • guyandpit
                                      Asus tuf fa507r BSOD
                                      by guyandpit
                                      Hi there! Need help! its been 2 months finding the cause of BSOD ntoskrnl and other error, this has water damaged before no power, i replaced sio and pwm control for gpu and cpu. It will boot 3 times in BSOD before succesfully boot in windows. I done stress on cpu, gpu and ram no errors found. Any opinion guys with same exprience? Thank you see attached bsod error
                                      05-09-2025, 11:46 PM
                                    • alambrose
                                      LG GRAM random bsod SOLVED
                                      by alambrose
                                      LG Gram 15Z980 picked up on Ebay for $200 (was sold as parts because no M2 drive and bios pw locked), but otherwise intact and working.
                                      Threw a 500gb M2 in, and was able to install Windows. On Gram, Win activation is stored in the bios, so Windows was automatically activated. I still kept getting random bsod's. Also bought a pw and unlocked the bios.
                                      Upgraded Windows to 11, still didn't solve the random & frequent bsod's. Cleaned & reseated all cables, RAM, etc... still getting frequent bsod's. Bought & installed a new stick of RAM, still getting frequent...
                                      02-12-2023, 06:12 PM
                                    • alleotechno
                                      HP Omen RTX2060 BSOD while nothing presure on CPU
                                      by alleotechno
                                      Details:
                                      Model : Omen HP Laptop 15-DH0038TX
                                      Serial Num : CND93433LW
                                      Product ID : 7LJ89PA#UUF
                                      Bios Version : AMI F.53 4/24/2024 (8600)
                                      Laptop Input Voltage : 19.5Vdc | 10.3a
                                      My Adapter Charger : Original HP 200Watt 19.5V | 10.3a
                                      My laptop keep on blue screen after 10 second successfully windows loaded, BSOD while installing new windows and cannot windows update, if update ask me to perform to restart and the laptop will BSOD while installing the update.
                                      The blue screen comes after nothing stress/pressures my CPU not GPU. I need to use...
                                      02-04-2025, 10:37 PM
                                    • the Benninger
                                      Vostro 14 3468 w BSOD KernelPower aleatory
                                      by the Benninger
                                      HI Folks, I have a problem randomly a BSOD screen appears in the event viewer indicates KernelPower failure, discard the source/memory and SSD, only the battery is in bad condition, it will be possible that the battery is causing this BSOD event , I mention it because the times he gave BSOD he happened to have the battery installed, and last Friday it ran all day without the battery installed and didn't generate any events
                                      At the moment I am checking the mosfets and voltges in general everything seems to be perfect on the main board
                                      Vostro 14 3468
                                      CPU: Core...
                                      04-29-2024, 08:54 AM
                                    • jean luc ferre
                                      upgrading windows7 to windows10 on an old laptop toshiba satellite m40 331 allways in error
                                      by jean luc ferre
                                      on this old laptop toshiba satellite m40 331 i am trying (but failing) to upgrade frow w7 to w10 and allways i have the error : 0xc1900101 - 0c20017. The upgrading process stops with the pc blocked with the logo screen w10 on the display; then there is no activity on the disk hdd or ssd.
                                      it's also impossible to boot from a dvd iso bootable, the device equally blocks on the w10 logo screen...
                                      i verified the informations in the device manager and it seems there are no problems...
                                      i wonder if it's not an issue about the bios (which is very old) or an interface problem...
                                      05-27-2025, 07:13 AM
