Ssi_400_14a01
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Ssi_400_14a01
    Hello, requesting for some help on this flaming inverter originally came to me with failed Mosfets that drive the transformers after replacing them the inverter worked for about 14 hours while testing the all of a sudden my new Mosfets blew up which are BA6366 type originals are BA9T56 nothing checks shorted but my new Mosfets what could be blowing them out hate these boards. Any help is much appreciated thank you.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Ssi_400_14a01
    Boost
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Re: Ssi_400_14a01
      Boost
        Re: Ssi_400_14a01
        I cannot find a datasheet for either of those MOSFETs.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Re: Ssi_400_14a01
          Hmm will get all the other numbers now buddy.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Re: Ssi_400_14a01
            Right heres what I got:
            Original Mosfets that come with Inv all numbers:
            4614
            BA9t56
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Re: Ssi_400_14a01
              The new mosfets that I installed:
              4614
              BA636G
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Re: Ssi_400_14a01
                Now the ones I installed the middle ones that were originally blown I replaced all 6 that drive the top two most transformers but the 3 middle ones have failed again, my finger is next to in the photo are the ones that failed again.
                  Re: Ssi_400_14a01
                  They are AO4614
                  https://cdn.badcaps-static.com/pdfs/...df367ff0cc.pdf
                  I would check the drive waveforms using a scope if you have one.
                  I would also check if there is a thermal pad - this must be soldered.
                  Could be a bad transformer or bad bulb.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8349
                    Re: Ssi_400_14a01
                    did you check your transformers yet? They should be within 3% of each other.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Re: Ssi_400_14a01
                      Thanks chaps will check all that tomorrow these dont have thermal pads on the bottom so thats out the window I also read up about thw Zero ohm jumpers for these having bad solder joints will have to investigate. Cheers.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Re: Ssi_400_14a01
                        Its strange as it worked for a while then blew again, looks like more digging to do.
                          Re: Ssi_400_14a01
                          Any sign of the board under the transformers have turning brown due to heat?
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Re: Ssi_400_14a01
                            Not under the transformers but under the 3 Mosfets that have failed again, there is obvious discoloration and browning on the pcb.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Re: Ssi_400_14a01
                              There are 4 transformers in total along the vertical height of the board, 3 are big ones and 1 is small. The bottom two big transformers have 4 Mosfets each driving them while the top big transformer and small transformer only has 3 each driving them. There are two independent driver circuits on this Pcb on for the lower transformers and one for the upper set of transformers, so could it be possible that the driver circuit runs the 3 Mosfets that drive the large transformer at the top at a faster rate than the others to maintain the same brightness ? Could this circuit have been damaged by the failed Mosfets and is over driving them ?
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Re: Ssi_400_14a01
                                Originally posted by tom66
                                They are AO4614
                                Thanks for the Pdf as well
                                  Re: Ssi_400_14a01
                                  I doubt it is 3 transistors driving one transformer it will be a half h-bridge or full h-bridge which requires an even number of switches to work.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Re: Ssi_400_14a01
                                    Hmm maybe you are right and its 4 for the big transformer then 2 for the small one.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Re: Ssi_400_14a01
                                      I have some new parts on order and going to start checking things later on will let you know if I find anything.
                                      • CapLeaker
                                        Leaking Member
                                        • Dec 2014
                                        • 8349
                                        Re: Ssi_400_14a01
                                        check that transformer that has those 3 failed FET's and maybe swap the CCFL's around. Maybe the fault shifts?
                                        • BlackScreen_22
                                          Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                                          by BlackScreen_22
                                          Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                                          Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                                          I had no problems connecting mosfets and capacitors,...
                                          08-27-2024, 12:46 PM
                                        • kotel studios
                                          Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                                          by kotel studios
                                          Finally got time to fix this board up.
                                          At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                                          Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                                          04-22-2025, 05:08 AM
                                        • x_orange90_x
                                          Vizio E55-E1 bad backlights or bad inverter?
                                          by x_orange90_x
                                          I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                          I don't know how exactly to test the inverter itself. Is it...
                                          01-29-2025, 09:24 PM
                                        • flerre
                                          Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
                                          by flerre
                                          Hi!
                                          Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
                                          No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
                                          So, could I safely assume all of these 3 mosfets are...
                                          03-13-2022, 12:14 PM
                                        • DrDos
                                          kenwood kr-6030 Mosfets?????
                                          by DrDos
                                          Hello everyone, I have decided to try and replace the mosfets in my power amp (the one with relay and left and right sides) on my kenwood kr-6030. I'm trying to get the A side of my speakers working. I have replaced all the caps in the power board and I thought why not change the mosfets. They seem to be working since I have great music coming out of the B side speakers and since I am not an electronic guru (but I am learning) I don't want to make any mistakes. The mosfets I have are listed A913 so I guess 2sa913 and 2sc1913. Can't really find those in mouser or digikey at least with the info...
                                          09-20-2025, 04:42 PM
