Mangavox 50ME314V/F7 "Funai junk"
  • heavymachines
    • Mar 2011
    • 1028
    Alright guys this tv is totally yuck. Anyways it won't turn on or do anything. power supply seems to be working but hard to test anything this thing uses jump bridges as test points. Where the hell do i begin on this nasty tv lol.
    It has standby and other voltages and is not sending voltages to led. Main appears not to respond at all to power button presses. Pics coming soon
  • heavymachines
    • Mar 2011
    • 1028
    Re: Mangavox 50ME314V/F7 "Funai junk"
    pics
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8146
      Does the PSU make STBY power?see if the main board sends PSON and BLon...
      • heavymachines
        • Mar 2011
        • 1028
        Ps_on is only 1.011v
        bl_sw is .001 there is no bl_on.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8146
          That is not enough voltage to turn the PSU on. So I think you need a new main board.
          • heavymachines
            • Mar 2011
            • 1028
            Any more tests i can do to confirm that is all? How do you force the power supply on this thing?
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8146
              With the main board unhooked from the PSU, put PSON and BLon through a 1k resistor to STBY voltage. Plug the PSU in and all the power rails shall be on and the backlight too.
              • heavymachines
                • Mar 2011
                • 1028
                LOL i cannot find standby and nothing appears to be on when main disconnected
                this tv is just wow lol
                can u see it in pic?
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8146
                  Not tonight on my IPad... to hard to see anything on that lil thing. However, see if you an find a service manual and upload that. These are also rebranded Philips and Emerson.
                    Look at those jumpers close to the black connector that goes to the main board, you will see printing such as: ALL 3.3V, PONH2, AMP+13V (about 8V in standby), PON21V (about 12V in standby), PROTECT3, BL-SW (BL-ON), BL-ADJ (DIMMING), ADIM3 (DIMING), OVP3, UVLO3, VLED3, LED+40V, etc.
                    Also look at the bottom side of the board.
                    There are two white stickers that I cannot read the printing on them, please tell me what they are.
                    The blank PCB is P/N BA4GU5F01 02.
                    Is there chassis number printed on the model number sticker on the back of the TV?
                    • heavymachines
                      • Mar 2011
                      • 1028
                      panel sticker is....
                      P/N: U4AUOXH
                      S/N: E7256170 063388
                      power board stickers are as follows
                      BARCODE
                      14112P01A
                      A4GU6-MPW
                      E7255590
                      STICKER
                      A4GU6MPW C
                      7255590
                      • heavymachines
                        • Mar 2011
                        • 1028
                        Well here is a kicker... With main disconnected i cannot find any voltages worth recording.
                        However with main connected i have red led on at ir board and have all voltages come up except none on led output side of power board.
                        amp13+V is 12.22 v and does not change with main connected and power button presses or remote has no effect.
                        with main disconnected nothing worth recording.
                          I do not need the LCD panel sticker.
                          So is there chassis number on the model sticker? I.E. FL?????
                          Can we see the picture of model number sticker?
                          Power supply/led driver board:
                          http://www.shopjimmy.com/magnavox-a4...me314v-f7.htm#
                          • heavymachines
                            • Mar 2011
                            • 1028
                            Not that i see, but here i took pics of everything i could find on this beast.
                            oops just noticed some pics are flipped but readable.
                            i included main stickers as well in case we need it later
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8146
                              yeah... when the main board is disconnected from the psu, there should be then only the stby voltage available from the PSU, nothing else. I can't see any FL chassis number on these pics. I know, I've uploaded a service manual for a 50me313v/f7, which is a previous model, on here some where. I wonder if the pinout on the PSU would be the same or not? I know the PSU looks different, but may be worth a shot.
                                So with all the boards connected, what DCV do you have on these jumpers?
                                ALL 3.3V =
                                PON-H2 =
                                PON21V =
                                PROTECT3 =
                                BL-SW (BL-ON) =
                                • heavymachines
                                  • Mar 2011
                                  • 1028
                                  As follows
                                  ALL 3.3V = 3.27v
                                  PON-H2 = 1.069v
                                  PON21V = 21.24v
                                  PROTECT3 = .163
                                  BL-SW (BL-ON)= .001
                                    Originally posted by heavymachines
                                    As follows
                                    ALL 3.3V = 3.27v
                                    PON-H2 = 1.069v
                                    PON21V = 21.24v
                                    PROTECT3 = .163
                                    BL-SW (BL-ON)= .001
                                    OK, so the PONH2) PS-ON is fine otherwise you will not have the 21V for the PON21, and about 12V for PON+13V.
                                    But you do not have the BL-SW (BL-ON).
                                    • heavymachines
                                      • Mar 2011
                                      • 1028
                                      is that controlled by main or something in power supply?
                                        Main board.
