Funai LC3200SSx Shutting Down
  • csmith
    • Aug 2014
    • 41
    This set won't power up with alternating green and red power light.
    Forced chassis on all voltages are correct except all 6V. It measures 28v.
    on cathode of D661. Anode measures 6v. Mainboard is BA94F0102 4_a.
    Schematic I'm using LC320MEM9 which is not close enough. Any suggestions
    from the Funai experts. Thanks!
  • szepesif
    Asus ROG GL553V shutting down before Windows
    by szepesif
    Hey guys!
    This is the third laptop here with this exact same issue and the forum threads and YouTube comments are also filled with this problem so I would like to figure out once and for all what's causing it and how to fix it because this model will keep coming to me to repair.
    Symptom: The laptop turns on and works fine UNTIL the Windows starts loading, then it shuts down. I can start it again but the same thing happens over and over again so I can't get into Windows. BUT I can enter the BIOS and it stays there forever without shutting down. The same applies if I remove...
    01-04-2025, 10:39 PM
  • Camarada78
    Carvin PA620 shutting down
    by Camarada78
    I have a Carvin PA620 powered mixer with a weird problem: channel one shuts down the entire speaker output when plugged in. Its not a short because it still outputs sound through the line outs.
    1. voltages are somewhat correct (-42/+42, -26, -17/+17, when it should be +-43, -24, +-18).
    2. Channel 2 if plugged works normally, no issues, any volume.
    3. Channel 1 if plugged very low volume, works normally. if goes a little louder, it shuts down everything (both speaker channels)
    4. line out works normally in any situation, even after shutting down the speakers.
    10-15-2024, 12:07 PM
  • spleenharvester
    QNAP TS-469L NAS shutting down randomly
    by spleenharvester
    I bought this NAS as "turns on then straight back off again". When I received it it had no trouble staying on, just the RAM stick was in the wrong slot so it wouldn't POST. I was hoping that was all that was wrong with it, but it's now started randomly shutting off once a week. When I find it off it will fire straight back up again if I hit power, no need to power cycle. Nothing ever in the logs aside from "the last shutdown was unsafe".
    It's got an internal PSU, an FSP250-50LC (which is wildly overkill for the hardware really). The electrolytic caps in the PSU...
    08-31-2024, 08:04 AM
  • flc1988
    HP Z620 PSU shutting down S10-800P1A
    by flc1988
    HP Z620 PSU shutting down S10-800P1A. i've replace CP2104 and still sutting down. Any ideia ?
    08-02-2024, 10:19 PM
  • rumpumpel1
    ThinkPad T460p keeps restarting instead of shutting down
    by rumpumpel1
    I have a ThinkPad T460p that keeps restarting instead of shutting down. The culprit is the LAN: if it is disabled in the BIOS, the problem is solved. I have already replaced the LAN chip (WGI219LM) twice, done CleanME, flashed another BIOS. Unfortunately all without success. What else can I check?
    04-28-2024, 12:26 PM
