Samsung UN60FH6003FXZA 410vdc going to LEDs
  • Captain Blu Ballz
    • Sep 2016
    • 32
    I'm not sure that the voltage is correct coming off of my power supply board to power the LEDs. There are 4 wires going to the LEDs off of the power supply board and they are marked S+,S-,D+,D-. Testing each terminal to ground is as follows: D+=410vdc, D-=0vdc, S+=7vdc, S-=7vdc. I thought that 410vdc was a little excessive so I purchased another power supply board and I get the same voltages and still no backlight. The tcon board was replaced too as well as the main board (it was a bundled deal). Before I tear into the panel to check the LEDs does anybody have any knowledge of the proper voltages I should be getting at the connector? Thanks for your help
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung UN60FH6003FXZA 410vdc going to LEDs
    I believe there's a legend on the power supply board giving the voltage for the Led connector (CN802) but I can't read it in google photo's.
    Edit
    Pictures of your boards would prove helpful
    The one capacitor close to the connector looks like its marked as 500V 22uF.
      • 31283
      there are no proper voltages, led's are current-drive.
      the psu should vary the voltage to regulate the current to the led's
      you see it's maximum output probably because the led's are open-circuit or not connected - and so are not drawing any current.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8351
        The psu should vary the voltage to regulate the current to the led's
        +1
          • 31283
          not sure what the S lines are btw, maybe for a temperature sensor or something!
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            +1
              You have open circuit in the LED string.
              Is this your board?
              Samsung BN44-00669A.
              D+ is the Anode which the boosted Voltage is fed to the LED string, D- is the Cathode which is the return lien of the LED string and is connected to the PWM Control power MOSFET to and the current sensing resistor for maintianing the constant current and then back circuit Ground.
              You are getting 0 on the D- because of the open circuit.
              The 'S' is for Sensing, they are not used as you can see how the connection is made at the LED connector.
              The LED power supply output Voltage with load is printed on the chart on the board.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8351
                In easy words: You gotta tear into the panel and find the open circuit LED('s) and replace them.
                • Captain Blu Ballz
                  • Sep 2016
                  • 32
                  Thank You everybody for your quick response. I was hoping it would be something board related but kinda knew I would eventually have to tear into the panel. I hope I don't screw this bad boy up.
                  Quick question, I've read that when repairing the leds it's best to to replace them all at the same time. If that is the case I'm having a difficult time locating a place that stocks a kit that has all of then sold as a package. Besides jimmys, (out of stock) I can't find anybody else that sells them or has them in stock. Thanks again everybody for your input. I think I've found a new place to hang out. Gotta love fixing stuff except led panels and microwaves. Microwaves have always scared the #$&! Out of me and the Led panel I'm working on now, well, one wrong move and the thing is destroyed.
                  • Captain Blu Ballz
                    • Sep 2016
                    • 32
                    Has photobucket always been riddled with ads? I find it almost impossible to view photos using photobucket.
                    • Captain Blu Ballz
                      • Sep 2016
                      • 32
                      Here are the pictures from the power supply board and the panel once removed. I found one open Led and several shorted Leds. The tv is only 3 years old, huh. The red are shorted and orange is open. Need to find new led strips, any help would be greatly appreciated.
                      • flocko
                        • Nov 2012
                        • 1121
                        • uk
                        I would say replace the top pair of LED strips,then cut the 11 good LEDs from these and use them to stack repair the defective LEDs on the other strips. when you have repaired the set turn the back lights down for a longer life
                          What is your LCD panel model number?
                          http://www.shopjimmy.com/catalogsear...UN60FH6003FXZA
                          • Captain Blu Ballz
                            • Sep 2016
                            • 32
                            Panel number
                            Shop jimmy is out of stock
                            • Captain Blu Ballz
                              • Sep 2016
                              • 32
                              Update:
                              Found a full set of leds on ebay. They belonged to a different tv but had the same numbers on the leds themselves. Picture indicates this. I got them to light up no problem but upon reassembly of the tv I heard a slight "tick" and I knew exactly what it was. The screen cracked! ! It wasn't visible until I powered it up though. Lots of time and effort invested in this tv researching, trying to find parts and reading. Boy was I disappointed.
                              In the pictures below you'll find the numbers I was able to search for to find replacements. You'll notice that your search will come up with a few different tv model numbers but as long as these numbers are in the description you should be golden. Just be careful putting the thing back together. The screen is super thin and made of glass. It will flex to some degree but it is fragile.
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                              • m1ch43lzm
                                by m1ch43lzm
                                05-12-2025, 08:37 PM
                              • ohren
                                Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                by ohren
                                I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                The models launched in 2018 and 2019 respectively....
                                09-08-2023, 05:24 PM
                              • C152Heavy
                                Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                by C152Heavy
                                Summary for TL-DR readers:
                                • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                • Have read ALL applicable threads
                                • C1818 and CP820 replaced as low hanging fruit
                                • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                • VCC pin (18) of PFC...
                                01-11-2023, 02:53 PM
                              • x_orange90_x
                                Samsung UN60FH6003FXZA LED tv bad main board repair?
                                by x_orange90_x
                                I have a UN60FH6003FXZA that due to a bad solder joint, blew the fuse on the power supply board. I replaced the fuse last night but had no power indicator and the tv won't power up. I unplugged the main board and the backlights come on. When the fuse blew on the power supply I audibly heard the pop and the fuse was blackened inside. I'm assuming that a spike went to the main board. My question is, can I track down some sort of transistor or smd that would've taken the jolt and can be replaced? The board is not in stock on SJ and it's rather scarce and expensive on eBay.
                                Here is...
                                10-12-2021, 06:55 AM
