42" Spectrincq no power
  • avaktech
    • Jan 2012
    • 68
    • US
    Rescued an off brand 42" LCD tv from a local landfill today. Going through power supply and found an open fuse and a couple bulging caps. Tv does not power on at all, no light, nothing. Only thing possibly fishy is a closed 400v polyester foil capacitor. I am very inexperienced so can someone with knowledge tell me if these types of capacitors would normally appear shorted? If it is a problem what else should I check? Thanks
    avaktech is offline Reply With Quote
    Re: 42" Spectrincq no power
    Please post good clear pictures of all the boards so we can see how they are connected, pictures of the cap? Please use attachment function to post the pictures.
    We are trying to troubleshoot the problem without having the boards in front of us, so good clear pictures are very important.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      ]per other thread
      Also found these two resistors both look fully closed, does anyone wanna chime in on the value for these?
      Old Today, 04:05 AM #3
      selldoor
      There is no need to start multiple threads with the same question - let this one die and use the main one.
      Resistor values - why not look them up yourself?
      Type hobby hour resistor into your search engine.
      avaktech
      I noticed the tv repair threads and decided to move over there. Not trying to be pushy, sorry. And yes I did look up the colors on multiple charts and calculators but none of the showed silver or gold in the positions of the ones I pictured. I am guessing they are just fusibles but dont really know.
      Dont look like fusibles.
      OK see attached - please can you update profile with country and mains voltage
      • avaktech
        • Jan 2012
        • 68
        • US
        I noticed a repair kit online for the board:ad301m24-4n1 I ran a few tests at these locations but am not very experienced so not sure what I'm doing exactly.. The SMD resistors all seems within spec. There is some sort of controller in the kit and the small heatsink attached to it has come loose so it is suspect, however I have no idea how to test it?
          PICTURES!! Or we can't help you locate things!
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Budm is the man for that - as he says we will need clear pictures - might help if you post a link to the kit.
            • avaktech
              • Jan 2012
              • 68
              • US
              Alright guys here's some pics, not the greatest
              • avaktech
                • Jan 2012
                • 68
                • US
                Here's another with the other sink cover removed, I'm having a hard time getting the lighting right.
                  I can see some caps with domed tops. This power supply looks familiar, I think TOM have seen this before in VESTEL?
                  • avaktech
                    • Jan 2012
                    • 68
                    • US
                    There is definately bad caps, several, however the main fuse is open so i am trying to be cautious. I don't wanna do more damage by just doing the caps. I haven't been able to find a glaring fault yet. Thats why I was asking about the 400 volt poly foil cap, it seems shorted is this normal?
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      Ok good pics - looks like c64 is bulged and possibly the Big cap? may be just the camera angle.
                      Can you locate and test the bridge rectifier, I think I see it in Pic 2 on the heatsink
                      behind the yellow box with RGA404C182324 on it.
                      Bridge rectifier test
                      a) put your multimeter in diode test mode
                      b) put your red lead on plus + pin side and the red lead on adjacent ~ pin - record reading
                      c) reverse the leads - recording reading
                      Then repeat the test on the other two pins
                      b) put your black lead on negative - pin side and the red lead on adjacent ~ pin - record reading
                      Then repeat the test on the middle two pins
                        Where is the pictures of this FOIL cap?
                          This PSU looks similar, but not identical, to the one used in certain Lexsor and Polaroid TVs - a Harwa PSU. But it is different, so it might not be identical. Mine had several bad caps too.
                          • multimeter
                            • Jan 2011
                            • 739
                            • united kingdom
                            looks like samxon GF's on the outputs,rip em out !
                            fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                            please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
                            • avaktech
                              • Jan 2012
                              • 68
                              • US
                              Foil cap is bottom right on pic 238.
                              On the left you can see on the 120 connector one of the pins got burned up a bit.
                                That green cap C44? Do you have the value as printed on the body? It is used for snubber circuits and they do go bad due to exposing to high kick back voltage from the transformer, if it goes out, the MOSFET that drive the transformer will be damaged and it can take out the SMPS IC with it also. May be that is why the fuse blown due to BACK EMF of the transformer. You should remove it from the board and see if the body has crack or bulging out to the side. You should also see if it has leakage resistance.
                                See example:
                                http://s807.photobucket.com/albums/y...nt=badcap1.jpg
                                • avaktech
                                  • Jan 2012
                                  • 68
                                  • US
                                  Well c44 seems to be nearly open, can get reading in diode mode. How do I test the SMPS? Is that this part?:TNY266PN It is included in the repair kit so I'm guessing its common for it to go.
                                  • avaktech
                                    • Jan 2012
                                    • 68
                                    • US
                                    c44 is 47uf 25v electrolytic.
                                    • avaktech
                                      • Jan 2012
                                      • 68
                                      • US
                                      Budm where you asking about the foil cap at c3? above c44? If thats the case it has nearly no resistance. It looks just like the one in your pic but its a different color. I think its a 105j400v
                                        No, C44 is the green polyester cap at the bottom right corner of the board as you have said in pic238, see post 15. Isn't that c44 you are talking about?
                                        in post1 " Only thing possibly fishy is a closed 400v polyester foil capacitor"
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • survivalbloke
                                          Acer Predator PT516 - no power, drawing 2.8a lid closed, battery connected
                                          by survivalbloke
                                          This is a Predator PT516-51s laptop, serial number is rubbed off. Board is LA-L211P Rev 1A. Charging light is on, machine draws 2.8a lid closed. If I press the power button, I get a blue power light indicator about 5 seconds, then it goes back off. I pulled the board to discover that with battery and AC connected, battery mosfet 1 light up under thermal. I then verified a short to ground on battery mosfet 2 source. If I inject voltage there, my PSU goes to current limit, but nothing illuminates on the board - anywhere, either side. I removed mosfet 2 but still have the ground short at source....
                                          10-21-2025, 01:35 PM
