ok so I got this tv, and it would turn on but inverter wouldn't lite up, had correct voltages and everything so it let me top belive main board, so today I got main board and need help with two things... so now once I power on, it takes almost 30-45 sec for picture to show, so would that be startup cap going bad? if so which is the start up cap??? also here is the picture now,,, so is this main bad? or do I need a tcon also? so here is a picture of power supply to see maybe if bad startup cap and is so which is it?and here is picture of screen now.[/ATTACH]
KDL-40S4100 lcd help please
Tags: None
Re: KDL-40S4100 lcd help please
Solarized picture will be T-CON board. Check the GAMMA voltage on the test points on the T-CON board. Post the picture of the T-CON board.
I do not know about the cause of the delayed on problem. No blinking LED during the delayed period?Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Where do I check the gamma points? Where are the test points?Comment
If you swapped the mainboard couldn't be possible that that mainboard was set for another panel format and could also be the cause of the solarized picture?
I have a toshiba that's doing this exact issue not as bad as your as my picture is full on the screen and sometimes looks almost normal. I am going to access the service menu and tinker with the panel display options see if it cannot fix the issue before trying to fix the t-con. T-con on my toshiba is buried and hard to access when the set is put together I have to figure out how to run it in pieces to get voltage readings from the T-con!
Interested to see how yours turns out!Comment
As budm asks - "Post the picture of the T-CON board." Personally I suspect main board as Shinju suggests, it is not smooth enough to be gamma and the image also appears the wrong size... but it's always good to be thorough.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
please let me know where to testAttached Filesif you find these attachements useful please consider making a small donation to the site
Can u tell me where to check?Comment
Better picture here:
http://www.shopjimmy.com/media/catal...02275e-top.jpgNever stop learning
http://www.badcaps.net/forum/showthread.php?t=24809Comment
So where is the test points?Better picture here:
http://www.shopjimmy.com/media/catal...02275e-top.jpgComment
See the top row and bottom row of the test points I have marked. Meter set to DCV, BLACK probe on the chassis.Attached Filesif you find these attachements useful please consider making a small donation to the site
Put them into this EXCEL spreadsheet.Attached Filesif you find these attachements useful please consider making a small donation to the site
Then just post each voltage reading of all those test points then.Never stop learning
I would look into the service menu before doing all this footwork that might be able to be avoided.
I just fixed a Toshiba with a Solarized picture as stated above, I am assuming someone swapped the mainboard out and powered it on and saw that the screen was all mucked up and tossed it out. I found out that the panel output settings were wrong and the RGB CUT and DRIVE settings were also set to wrong output and cause the solarization of the picture.
I am thankful too because a new T-con would not have fixed the problem and the T-con for the 37HL17 is not only spendy its the only one that works for this unit (no shared parts) and rare as heck to find. The Toshiba Service menu was all in Hexadecimals and short hand abbreviations and not easy to navigate but it was doable.
I set all the service menu tuning modes back to stock via the service manual and went from there.
Budm and Tom are pro's and will set you right, I am not saying don't be thorough but check the service menu first it might save you some money! I am no professional just merely giving my advice since I just had to deal with a panel with this issue!
Just make sure to write down all your previous settings first because once you change them there is no going back VIA reset/factory reset as you are pretty much flashing/re flashing the bios.
Good luck!Comment
I have no clue how to do that... and don't have remote. Can I stilll do it?Comment
You will need the remote, I know some like Pioneer PDP's don't but 90% of the other ones do. Being that this is a Sony it will require it.
http://www.ebay.com/itm/SONY-REMOTE-...item27de4e3441
I keep a box of remotes around for this sort of thing, quite a few off brand LCD's use the stock Samsung remote perfectly find but Toshiba,Coby,Sony and Westinghouse seem to only worth with their own brand name remotes. You can try a universal remote but I don't know if that will work.Comment
I have a VIZIO E70-E3.
Symptoms: Black screen, no picture, but LED backlights are working.
I probed the power board and voltages are as listed on the board.
Main board appears fine, too.
I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
There are two separate ribbon cables feeding the LCD.
If both are connected, the screen is black.
If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and... -
by iglitareHi,
i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
Backlight seems to work, Sound (Setup menu after reset) works.
If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
With my small knowledge i would think at least the cables are good.
Can this happen because of a bad tcon board?
Or is it always a bad/shorted... -
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by x_orange90_xJust bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
by shelby5041hi
i have a samsung lcd tv
it powers on with sound and backlight but no picture
all voltages from PS are good 12v 3.3v and 5v
whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
no 12v at the tcon fuse
i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
the odds of having 2... - Loading...
- No more items.
