phillips 32pfl4507/f7 squeal like a pig
  • CraigR
    • Dec 2013
    • 965
    This philips came in dead and I found on the power board the fuse blown then checked and a mosfet was bad and a diod shorted etc... so I got a repair kit and replaced
    F601
    Q602
    Q601
    Q501
    Resistor R611
    Resistor R501
    Diode D608
    Diode D607
    Diodes D601,D602,D603,D604
    After reinstalling the board I plug it in and get a very loud squeal and still no power. If I unplug the cable to the main it goes away. That cable looked good on the contacts. Would I also have a bad main???
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: phillips 32pfl4507/f7 squeal like a pig
    No,still a short on the power board,but the mainboard turns on the power supply,hence why it only squeels then.
    In short bursts you should measure what voltage is missing when it squeels.Your short will be in the missing voltage section
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • CraigR
      • Dec 2013
      • 965
      D608 was replaced but reads shorted (in circuit) but ok once removed. I really don't want to plug it in again with all the new parts if something is still shorted.
      • R_J
        • Jun 2012
        • 9588
        check the diodes in the secondary, d650, 651 and the other 2, I can't make out the numbers. It seems like the primary is working and having a short in the secondary would cause the squeal.
        • CraigR
          • Dec 2013
          • 965
          I did that before posting and none are shorted. D653 and D654 are the other 2.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            its likely a shorted mlcc on one of the converters.
            looks like there are 3 on that board.common on funai sets.
            • CraigR
              • Dec 2013
              • 965
              Just to be clear you're talking about what I have circled in this picture. Correct? If so none are shorted.
              • R_J
                • Jun 2012
                • 9588
                are you getting any secondary voltages? Did you try disconnecting the cable going to the led backlights?
                There could be a problem with the backlight circuit on the back of the board.
                Did you check for shorts accross the secondar voltages, ie: accross c650, You could have a shorted component in the circuit that is supplied by one of the secondary voltages (backlight inverter ic or fet)
                • CraigR
                  • Dec 2013
                  • 965
                  Unsure on voltage as I unplugged it right away so not to make it worse. I have disconnected all the cables except the main to the power board and still squeals. I also checked the cable to make sure nothing is crossed.
                  • CraigR
                    • Dec 2013
                    • 965
                    UPDATE: it turned out to be on the main board caps C3102, C3103, C3105 working again!
                    • jackal68
                      • Mar 2014
                      • 91
                      I'm trying to fix the same issue on the same board, my fuse didn't blow but I have a whinning noise coming from the powerboard when the mainboard is connected (no noise when not connected). I suspect the mainboard but not sure what the values of the caps are.
                      do you know what the values for the 3 capacitors are?
                      thanks for any help you can provide.
                      • Maalobs
                        • Jun 2016
                        • 120
                        • Sweden
                        You have the service manual available to download from this page:
                        https://www.electronica-pt.com/esque...ileinfo/22650/
                        If you search for those names in the PDF, you'll find that they are all marked as "4.7".
                        In microFarad I guess, since other capacitors are marked as 0.015, which would mean 15 nanoFarad if the expected unit was microFarad, and that sounds unreasonably low.
                        • freak
                          • Jan 2022
                          • 3
                          I just had this exact problem and those caps were bad for me as well. Curious how you found which ones were bad. I checked them on board with a cheap dvm with cap mode and they showed OL while the others gave me a value. Popped them off and the TV works. Looks like they are filter caps so I assume that's why it works without them. Gotta order new ones now.
                          • jackal68
                            Phillips 32PFL4507/F7B humming sound, no power
                            by jackal68
                            Hi
                            Im trying to fix this Phillips 32" led tv, 32PFL4507/F7B. There is a humming sound when the power plug is connected. The humming goes away when I disconnect the cable from the powerboard to the mainboard. The humming seems to be around the mosfet/330uf capacitor area of the powerboard.
                            I have taken out the mosfet and tested it with a DMM and it seems to be fine. I also checked the voltages going to the mainboard and they're totally off. I'm not getting 3.3v standby (no light at the front), where it is supposed to be 24v, i'm getting 2.3v, and where it is supposed...
                            06-22-2021, 10:47 AM
                          • RetroComputingGrotto
                            Viewsonic VA2010wb (High Pitch Squeal At Power On)
                            by RetroComputingGrotto
                            I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
                            On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
                            The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
                            What component(s)...
                            02-03-2025, 06:00 AM
                            Phillips OLED TV 55P0S9002/05 715G8886-P01-000-004Y Schematic
                            Brand: Philips
                            MPN: 55POS900255
                            GTIN: 8718863012352​...
                            11-05-2024, 02:45 PM
                          • learnmore
                            Service manual req Phillips 75PUS6754/12
                            by learnmore
                            Hello Community,
                            Would welcome any help on getting a service manaula for the above model (Phillips 75PUS6754/12) TV or anything similar.
                            Picture intermittently works fine for a day or a minuite then goes off, but backlights appear to remain on.
                            I thinking troubleshooting TV or using a tape method on the panel but would like some guidance on tracing the signals accurately rather than a trail and error.
                            Thanks in advance,
                            LM
                            11-13-2023, 04:58 AM
                          • Bloopeta
                            Phillips 58PUS7805/12 No Picture
                            by Bloopeta
                            Phillips 58PUS7805/12, was told it had sound no picture, sometimes picture would come back then go again?
                            From what I have seen myself, its just blank illuminated screen. Tried unplugging each ribbon cable from Tcon in turn.
                            When one is unplugged, I get half sceen, clear picture.
                            With other unplugged, get half screen but with thin horizontal lines
                            Any ideas? Or is it likely a bad panel?...
                            03-10-2023, 02:08 PM
