VIA Apollo 133A AGP4x stuffs
  • Oerg866
    • Nov 2009
    • 61
    Hey,
    so I have this dual PIII-1000 machine I built for personal satisfaction, with 1GB PC133-CL2 RAM and a GF FX5600 and 2 HDD on the ATA100 controller...
    The board is a MSI 694D Pro AR (MS-6321) and fulfills its purpose completely. It's running Windows XP since a few days (Updated from Windows 2000 due to compatibility issues with some newer programs that are losing W2k support soon).
    Now, my main issue here is that I cannot use the AGP4x. I read that it's a common quirk with the VIA Chipset and Nvidia cards. Nvidia driver always goes to AGP2x.
    I've tried RIVATuner to force it to AGP4x, which worked but anything 3D was extremely unstable (1 image.... wait 5 seconds... black screen..... new image) and lead to a locked up machine..
    I've tried the Hyperion-Pro-Registry-Trick without luck (the damn key doesn't even exist for me lol), and also tried various version of the 4in1 drivers.
    I have no clue why this is happening but it really sucks.
    Any ideas?
    Cheers,
    Oerg
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: VIA Apollo 133A AGP4x stuffs
    switch to ATI?
    sigpic
    (Insert witty quote here)
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Try enabling AGP 4x but disabling AGP fastwrites, might make it more stable
      • Shodan486
        • Nov 2009
        • 203
        switch to ATI?
        Aaaaah, my beloved Apollo133a - kay, let's get into this. First I gotta argue with ratdude - sorry pal, that ATI solution won't comply with this chipset - actually I experienced the same problems ONLY with ATI cards - the myth of Nvidia cards are not compatible with this particular chipset is crap - it does not depend on brands only - depends on the overall design of the board and its BIOS plus the VGA card itself.
        During my tales with the Abit VP6, I tried almost every suitable (and powerful) VGAs - the most stable I had at avail (and the most overclocakble) was the 7600GS from Gainward - many caps, many MOSFETs used on it, not to mention I could have modded it, which I have seen, proved to be quite effective. Then I tried the 6800 - very same, the OC was about 50MHz lower (probably due older chip process). After that I received some ECC RAM and it proved to be even more OCable than non-ECC, so I pushed the AGP frequency a bit higher - exactly 86,6MHz. Even this level did not cause any trouble - just for fun tried something older, like MX400 and 440 - no difference, everything worked as supposed to. The only thing that bothered me was the inability of the NTuner to control the GPU fan speed properly...workaround was to set the fixed speed and the job's done.
        Now I tried the ATI, coz they have that 4650 (i guess), which is the last of the AGP cards - but before I bought it I wanted to try any ati card, just for verification all's gonna be OK. And the torture started :
        First - Not all VIA hyperion drivers were compatibile. But that was easily overcome - tried the drivers designed for KT400 - 600 & worked. And now, finally your problem - AGP speed...Not only we share the same issue, but additionally I had problems with the SideBand Adressing option and FastWrites/Reads:
        I couldn't have both Fast Writes / Reads enabled, after the obligatory reset it always disabled the Fast Reads (the Catalyst), BUT (as I recall) it was capable running at 2x as well with SideBand enabled. This really surprised me, so many obstacles. So I'm trying, different drivers, different catalyst - nothings...then I reminded myself of Omega. This only fixed the sideband problem and the Fast R/W - the speed remained the same. End of story, really didn't spend much time testing it...just tried other cards, the only good one was the slow Radeon 9200, but that's from the Ice age.
        I don't want to blame the VGA vendors, but try to install everything once again, try the newest Hyperion drivers and XP SP2, then try some Nvidia first if it is possible - just give it a try...if not, try the ATI and use Omega drivers, maybe you'll have some luck.
        Just to summarize the whole problem, any ideas are welcome: Why the Abit VP6 has no problems with Nvidias and many problems with ATI. And why does it not have problems with R9200? And and and...
        I think ALL factors, from proper power management to the AGP slot / VGA card itself through ideal BIOS settings to the end of compatible OS + drivers installation - should be considered crucial towards solving such issues.
        Last thing that comes to my mind is the AGP driving value - 7600GS was happy with the CD value, on the other hand 7950 required EA to run without any problems/glitches/falls. This setting increases the signal potential of the graphic subsystem, simply put it tries to ensure stability. Don't worry, you won't fry anything, had the FF value many times set and all is cool.
        Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Some of the ATI 2xxx 3xxx 4xxx AGP cards support HDMI audio via a built in soundchip
          This requires that the card gets two IRQ numbers, (one for the soundprocessor and one for the GPU) the BIOS must be coded for this...
          I modded one such BIOS myself;
          https://www.badcaps.net/forum/showth...highlight=hdmi
          http://www.techpowerup.com/forums/sh...15#post1839815
          • RJARRRPCGP
            • Jul 2004
            • 6304
            That can also occur when a Nvidia GPU is overclocked too much.
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • Shodan486
              • Nov 2009
              • 203
              I think the guy's not OCing anything, just getting it stable. Anyways it's true, if the firmware has a throttling option.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Just FYI, even though I saw that with a GeForce 4 Ti 4200. It would do that in 3D Mark 2001 SE and sometimes 3D Mark 2001 SE actually then gives an error, interestingly not from Windows, with a pop up from 3D Mark 2001 SE claiming it failed to init the graphics.
                Arc A770 16 GB
                • Rulycat
                  • Apr 2010
                  • 724
                  • United Kingdom
                  Perhaps a silly question, but have you seen if there's a BIOS update for your board which fixes graphics card issues?
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    no, come to think of it, my compaq presario 7000 does that too... same chipset, same problem with NVIDIA. or at least it did under linux with nvidia's drivers.
                    sigpic
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      I have a dual PIII myself, but i'm running a BX chipset. Dual 1400/512k Tualatins on adapters, mobo needs modding (a new PLL IC) as it only does 100FSB thus the CPUs run at 1000. I said i'll mod it this year but i'm not too sure, patching in a new FSB clock is tricky business, and i sure as heck don't want to screw the board up.
                      Anyway, i run a Radeon 9800 Pro 256MB on that machine (last card compatible with AGP 2x). The card is overclocked and voltage modded, AND the mods resulted in gains. The 2x bus isn't limiting the card *that* much, so i'd leave it as it is.
                      Or, sell me the board. I'd be glad to have support for a HD4650 AGP, even if it would only run at 2x.
                      A working TV? How boring!
                      • goodpsusearch
                        • Oct 2009
                        • 2850
                        • Greece
                        what do you find so fascinating with those Pentium 3 systems?
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          old, but has enough power to do heavier linux amd xp.
                          sigpic
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            My can opener opens cans fast enough for my needs so should they come out with a faster one the upgrade would be pointless and a waste of money.
                            And, I just DON'T CARE how fast the neighbor's can opener is.
                            I only went past socket 370 because USB1 wasn't doing the job anymore when drives got big. [Too slow to transfer a whole drive.]
                            Even then I was still using one for office work up until last year.
                            It did IT'S job just fine.
                            Mann-Made Global Warming.
                            - Dr Seuss
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              I thought about that too - i have a PCI USB 2.0 card on mine, i bought it off my cousin for $10 about 3 years ago. And i also have a Silicon Image PCI SATA card + 320GB Western Digital HDD.
                              @ goodpsusearch, it's mainly because they are extremely reliable. I've never had mine crash even once. And upgraded to the maximum (i only have ONE mod to go till i truly reach the limit of the system), you'd be surprised what a pair of PIII Tualatins can do. Just FIY, they keep up with low-end C2Ds at video encoding. It's not my main system, i have it at my grandparents' place.
                              I've grown accustomed to tinkering with that system every year, and it keeps on going so why get a new one? If i need an extra helping of modern tech i have two laptops bought last year. I bet that computer will outlive the two laptops though. I'm sure i'll be able to use it for at least 5 more years, and when it'll finally be truly obsolete i'll host a CS server on it or something.
                              • goodpsusearch
                                • Oct 2009
                                • 2850
                                • Greece
                                I see. Thanks for replying!
                                I have an Intel Pentium 3 Celeron Tualatin 1300MHZ @ 1456MHZ, 3xSDRAM 112MHZ 640MB, ATI All In Wonder Rage 128 Pro AGP, 2xHDD IDE 7200 20GB WD & 5400 40GB Samsung, BTC DVD ROM & Yamaha CD RW, lan PCI card and Soundblaster 128 PCI running windows XP service pack 3.
                                I use it mainly for TV and testing computer parts that I get for free.
                                It can be used for surfing the web too, only drawback is it can't play youtube videos without dropping frames..
                                I attach some photos I took of it 9 months ago.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  That's fine if you're happy with Windows.
                                  I got sick of the add-in card method because hunting for Linux compatible USB 2.0 cards gets OLD real fast because most ads don't mention which USB chip they use.
                                  That and when you get a good deal on a board but have to cough up an additional $10-$20 for an add-in card + shipping that pretty much kills the good deal aspect.
                                  Never used Silicon Image cards for the same reason. [Linux]
                                  - Dr Seuss
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    There's an odd VIA mobo chipset [CLE266] that gives P3 USB2.0 and allows either/or DDR or PC133 RAM if the manufacturer wants to build the board that way.
                                    Problem is VIA used it to push their EPIA line of CPUs so most boards that have that chipset have the sucky EPIA CPU soldered on. [No socket.]
                                    I looked for one for a while but boards with that chipset and an actual socket 370 ZIF socket tend to be expensive for what they are.
                                    It's more cost effective to find a MODT board that takes a Pentium M.
                                    A Pentium M is basically just a P3 Tualatin in a package designed for laptops AND they go to higher clock speeds AND the mobos are USB2.0 and take DDR.
                                    [It's a P3-Tualatin with all the P4 advantages.]
                                    - Dr Seuss
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      not to mention the Pentium m has SSE2, 1 or 2mb cache, and a nicer version of speedstep.
                                      sigpic
                                      • Shodan486
                                        • Nov 2009
                                        • 203
                                        BTW guys, any updates on the progress in resolving the issue originating the thread? I'm merely interested in the Omega driver usage results, if it has helped so far...
                                        • giulio93
                                          Samsung S21 FE wifi not working
                                          by giulio93
                                          Hi everyone, I have a Samsung S21 FE with no wifi. I can't see the classic antenna cable so i suppose it is integrated in the circuit of the mobo. Can anyone help me with this?
                                          I have very good skills in soldering and stuffs.
                                          01-08-2025, 11:55 AM
                                        • juergenb
                                          Sophos XG86w Firewall forgets the date and time as well as the DMI environment variables after power cycle
                                          by juergenb
                                          I have a small Sophos XG86w firewall here, which is still working so far. But there is a problem with the BIOS and the DMI environment variables.
                                          The hardware forgets the date and time after a reboot or a power failure.
                                          The DMI environment variables are also reset to default values.
                                          I have now tried 2 different batteries (CR2032).
                                          I reset the DMI vars via an EFI shell and with AMIDEEFI64 (v5.21.0057).
                                          However, after a reboot or a power cycle, these values are reset again.
                                          It is an Apollo Lake platform with an Intel...
                                          10-08-2024, 04:19 AM
                                          HP Pavilion Pavilion Desktop - 570-a079w Pavilion 570 J4205 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-a079w can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-a079w boardview and Pavilion Pavilion Desktop - 570-a079w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 03:44 PM
                                          SHUTTLE XPC slim DX30 XPC slim J3355 Specification for Upgrade or Repair
                                          This specification for the SHUTTLE XPC slim DX30 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DX30 boardview and XPC slim DX30 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for SHUTTLE...
                                          09-12-2024, 03:30 PM
                                          ACER Aspire XC-730 Aspire XC J4205 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire XC-730 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire XC-730 boardview and Aspire XC-730 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER...
                                          09-12-2024, 03:28 PM
