WD2500 issues
  • stevo1210
    • Oct 2006
    • 4156
    WD2500 issues
    I have an IDE HDD here from a little old lady that lives with her son.
    Basically... old ladies don't know much about computers, so she hasn't fiddled with the internals and neither has her son.
    The HD is a Western Digital Caviar WD2500, 250GB HDD. I think it has bad sectors because it won't format properly... is there any way to fix this? or is the bin the only option...?
    Date code on the drive is 21 June 2004... so it's about 6 years old. The computer that it was in has had little use, so I can't see why this damage has occurred...
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: WD2500 issues
    There is a good read on this site about that model:
    http://datacent.com/datarecovery/hdd...digital/WD2500
    Another suggestion is to download Wester Digital's drive utility/diagnostic software. This software is free and is worth trying.
    • seanc
      • Nov 2008
      • 1319
      Re: WD2500 issues
      Run MHDD on it, it may be able to fix the sectors. You can also use it to read the SMART attributes.
      • Scenic
        o.O
        • Sep 2007
        • 2642
        Re: WD2500 issues
        that site is next to useless. they basically say the same thing for all drives listed there. and those are mostly the absolute end-of-life-symptoms..
        • Newbie2
          • Sep 2005
          • 885
          Re: WD2500 issues
          Websites like those give very generic explanations, and then simply substitute in the model number of the hard drive that you search.
          My gaming PC:
          AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
          ASUS M4A77TD AMD 770 AM3 Motherboard
          PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
          G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
          TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
          WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
          ASUS Xonar DG 5.1 Channel PCI sound card
          Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
          Antec Three Hundred Mid-Tower Case
          Microsoft Windows 10 Pro 64-bit
          Microsoft Windows 7 Ultimate SP1 64-bit
          • NxB
            • Feb 2009
            • 1595
            Re: WD2500 issues
            Try HDD regenerator after you try the wd utility. Its on the hirens CD. I've used it on 3 WD 250s and they appear fixed. I've been using 2 of them for over a year without issues.
            • stevo1210
              • Oct 2006
              • 4156
              Re: WD2500 issues
              doesn't the HDD regenerator on Hiren's CD only do like a few sectors and that's it?
              • NxB
                • Feb 2009
                • 1595
                Re: WD2500 issues
                Unless something has changed, it worked through all the sectors on mine. Ran for a few hours.
                • kaniki
                  • 514
                  Re: WD2500 issues
                  back to the main part.. you said that you dont know why it may be going bad and not a lot of use.. 2 things i would check that could prematurely kill a hard drive.. enough ram for the system and make sure that there is adequate cooling for it.. That is one thing that drive me crazy, seeing a custom built PC and people thinking that the fan in the power supply is good enough to cool the PC and all its parts. I have even hard hard drives that have gone bad because of not enough cooling.. just a thought..
                  • larrymoencurly
                    • Oct 2004
                    • 960
                    Re: WD2500 issues
                    http://www.HDDguru.com forums may have information.
                    • dood
                      Deputy dood
                      • Mar 2004
                      • 2462
                      Re: WD2500 issues
                      In my opinion, if a drive does test to have bad sectors, it's junk. You can run utilities that will remap the bad sectors over to the pool of sectors that drives keep for "spares", but the point is, the drive is failing, and should be replaced ASAP.
                      Ludicrous gibs!
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        Re: WD2500 issues
                        run smartudm on the hirens cd.
                        look for a bunch of reallocated sectors and current pending.
                        speedfan also does this and links to an online database to compare your drive to others.
                        • stevo1210
                          • Oct 2006
                          • 4156
                          Re: WD2500 issues
                          I've always had bad luck with WD drives, but I'll give it a shot and see what happens with that Hiren's CD utility.
                          • seanc
                            • Nov 2008
                            • 1319
                            Re: WD2500 issues
                            Right now I'm having rubbish luck with Seagate, probably because 98% of my machines have Seagate drives in them though.
                            • NxB
                              • Feb 2009
                              • 1595
                              Re: WD2500 issues
                              2/3 WD drives have no issues for me. Run 24/7. The 3rd one has issues with the boot sector but works fine as storage. Also have a maxtor mac drive that I cut off the first 30gb because it was screwed up. The rest works fine. I wouldn't put irreplaceable data on it but so far no major failures.
                              • dood
                                Deputy dood
                                • Mar 2004
                                • 2462
                                Re: WD2500 issues
                                Thats fine for use in your own systems, where you understand the risk is higher for it to fail completely. But to return it to use in a customer's PC? Never.
                                Ludicrous gibs!
                                • NxB
                                  • Feb 2009
                                  • 1595
                                  Re: WD2500 issues
                                  If it passes hdd regenerator and then tests good?
                                  • dood
                                    Deputy dood
                                    • Mar 2004
                                    • 2462
                                    Re: WD2500 issues
                                    I wouldn't, but maybe I'm more cautious. For the price of a new drive these days (under $50 for a 250gb), I will always recommend a new drive. And given the choice of a new drive over a used one that I've pulled from a working machine and tested as 100% good, most people will choose the new drive.
                                    Ludicrous gibs!
                                    • severach
                                      • Aug 2007
                                      • 1055
                                      Re: WD2500 issues
                                      Bad sectors can be created by turning the drive off during write. When read it will report as bad but will not be remapped until it gets written to. Though there's nothing wrong with the drive or the sector it will be remapped instead of fixed because the drive doesn't know whether the bad sector was created from a partial write or failing media.
                                      There's nothing wrong with a drive that creates a bad sector once in a while since it's probably PEBCAK. When they start showing up too often or overwriting the bad sector is unable to remap it then the drive is toast.
                                      Utilities are not required to remap sectors. Any write that hits the sector will do it. Utilities help by doing the whole drive at once ensuring all sectors are tested and remapped.
                                      A drive with a lot of remapped sectors can get slow. Writing zeros to the whole drive seems to bring the speed back up.
                                      Zero write the bad drive then install or write your image. If the zero write is successful then all bad sectors were remapped.
                                      Any tool that writes only zeros will work. I use WD Diagnostics for Windows to write zeros. dban can do it.
                                      sig files are for morons
                                      • stevo1210
                                        • Oct 2006
                                        • 4156
                                        Re: WD2500 issues
                                        I give up. tried HDD regenerator and it freezes at 31MB...
                                        • gretti
                                          MSI Z370-A Pro, works but does not power off or reboot and USB issues
                                          by gretti
                                          I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
                                          The MSI BIOS included the ME firmware for the board. The size...
                                          10-16-2025, 02:14 AM
                                        • SoulFreeze
                                          Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                                          by SoulFreeze
                                          Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                                          After repairing the above issue, I realized the following remaining problem,
                                          Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                                          The computer recognizes headphones are connected and displays a popup in windows
                                          Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                                          06-21-2025, 09:53 AM
                                        • Nagyesz
                                          Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
                                          by Nagyesz
                                          I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
                                          All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
                                          How can I extend its lifespan? Could reflow help?
                                          It has ryzen 5 5500h, rtx 2050, no soldered ram.
                                          Example of the artifacts:
                                          03-01-2025, 11:11 AM
                                        • pwnjuice
                                          Bitlocker issues
                                          by pwnjuice
                                          Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
                                          Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
                                          Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
                                          01-06-2025, 05:33 PM
                                        • Skgod
                                          Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
                                          by Skgod
                                          Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
                                          Black screen, freeze
                                          The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
                                          When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
                                          So can anyone tell me what would be the possible cause?...
                                          10-16-2024, 08:11 PM
