Battery calibration
  • stevo1210
    • Oct 2006
    • 4156
    Battery calibration
    How do I calibrate a laptop battery?
    My Toshiba Tecra M2 battery meter seems to be retarded for some reason... when I first got it... for the first few days... the battery would like about 1.15 hours-ish...
    Now it lasts for about 30 minutes, sometimes 45 minutes and sometimes 20!
    The battery is a genuine Toshiba one so I know it can't pull off that fake Chinese battery syndrome.
    Thanks.
    • 31294
    Re: Battery calibration
    i remember the release version of win7 did that!
    try a different o.s. - use a live-disk if you need to.
    • stevo1210
      • Oct 2006
      • 4156
      I'm running XP Pro SP3 though.
      • Scenic
        o.O
        • Sep 2007
        • 2642
        i've had the same problem before. also on a genuine toshiba battery (for my Satellite Pro 4600 PIII 1GHz).
        one of the cells inside the pack was dying, causing the controller to go slightly insane (all other cells were OK apart from lower capacity due to the age).
        sometimes i got almost the full remaining 1h 40mins out of it, sometimes 10, 30, 60min and a couple times it barely managed 3 mins or died instantly (matter of seconds till it turned off without any warning).. totally random..
        • kaniki
          • 514
          if you can calibrate it, it is usually by a program. I once had a compaq that had the software on it for doing the calibration, but it usually comes from the main company. I dont believe that i have ever seen a calibration program on the Toshiba's, but i could be wrong. check the programs that come installed on the PC or check the bios. if there is one, it should be in one of those 2 places. also, if one of the cells in the battery pack is dying, there is nothing you can do but either take the battery pack apart and replace that cell or replace the whole battery pack. calibration will do nothing to fix a dead or going dead cell in the battery pack.
          • stevo1210
            • Oct 2006
            • 4156
            how would you know which cell is dead anyway?
            • kaniki
              • 514
              as far as i know, take the battery apart and do a test on each battery. the dead or bad cell will probably have a variation in voltage vs the good ones or will just bomb out on the test all together. It may just read dead from the start even though the battery is fully charged.
              when you open up the casing on the battery pack, there will be multiple cells in it. basically it will look like 8 or 10 or how ever many batteries in there all connected together.. in a sequence just kinda like you get when you use a battery operated fan or light or remotes.. etc..
              • kikkoman
                • Jul 2007
                • 691
                i noticed that calibration sometimes fails to balance the cells properly.
                it does readjust the battery gauge, but the voltage drift between cells that happens over time (esp. when the pack hasn't been used for a long while) remains.
                with a li-ion charger that has a precise shut-off, i managed to revive the auxiliary multi-bay pack for my Evo laptop. 15 min. before, 70min after.
                "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
                • Scenic
                  o.O
                  • Sep 2007
                  • 2642
                  i once had one of those "intelligent" computer controlled chargers that i borrowed from a friend.
                  with that thing, i managed to revive multiple laptop battery packs by putting the single cells in there and let the charger do its "revive/refresh" program..
                  out of 25 or so cells only 3 failed to come back to life.. but those 3 came from 3 different battery packs.. and all of them had a runtime of less than 10mins with those bad cells in it.
                  i sacrificed one battery pack to fix up the others. runtime of the fixed/revived packs is well over 1hour now.. some of them almost had the full runtime as if they were almost brand new o.O
                  seems like if 1 cell is dying or dead already, the whole controller gets out of whack.. probably because the cells are wired up in pairs in most of the packs i've seen..
                  ([2 in parallel] -> [2 in parallel] -> [2 in parallel] -> [2 in parallel] -> controller .. 1 dead cell and the controller f*cks up..)
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    Measure each cell individually with an ESR meter.
                    Batteries are very similar to caps in that regard as they age their ESR goes up.
                    One cell with an ESR much higher than the others indicates a bad cell.
                    • kikkoman
                      • Jul 2007
                      • 691
                      dead cells usually fall below 3V.
                      anything between 3.0 and 3.6 is a grey zone.
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • mkdj
                        by mkdj
                        Mark and model: ASUS X571
                        Tests already made:
                        - I have removed...
                        07-14-2025, 09:16 AM
                      • techfreak9356
                        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                        by techfreak9356
                        09-14-2023, 11:10 PM
                        NVDC charger configuration...
                        11-05-2024, 03:28 PM
                      • ferah831208
                        by ferah831208
                        03-18-2025, 01:18 AM
