lappys and firewire
  • toastygoodness
    • Jul 2005
    • 813
    lappys and firewire
    is it just me or is it impossible to find a $1000-or-less lappy with firewire?
    the reason i need firewire is for audio recording to connect to my echo audiofire2.
    you guys know of any lappys that have firewire?
    thanks a bunch!
  • pentium
    • Mar 2006
    • 2778
    Re: lappys and firewire
    What's wrong with buying a PCMCIA firewire card?
    Find Nedry!
    Check the Vending machines!!
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      dont a bunch have 1394 4pin built in? i see it on laptops all the time... or do you need 6 pin?
      otherwise, get a pc card or the like for it.
      sigpic
      (Insert witty quote here)
      • Scenic
        o.O
        • Sep 2007
        • 2642
        yeah.. PC Card would be the cheapest option.
        otherwise.. i remember that a lot of Sony Laptops had Firewire built in. however.. a lot of the still-useful ones (Pentium M and above) have problems with dead mainboards..
          • 31201
          firewire400, or firewire800 ?
          if it's full-rate then i suspect only apple will make them - if at all.
          • toastygoodness
            • Jul 2005
            • 813
            lol most lappys don't have card slots anymore either :-(
            just fw400. expresscard was pretty popular like last year but now i can't find them either.... so weird....
            six or four-pin don't matter, the interface has its own p/s.
            here it is: http://www.echoaudio.com/Products/Fi...ire4/index.php
            btw, thanks for all the help guys, you guys are amazing
            • bgavin
              • Jan 2007
              • 1355
              If your interest is sound cards, etc, make SURE to get the Texas Instrument chipset as your FW foundation. My research showed significant latency and other big problems with non TI chipsets.
              • toastygoodness
                • Jul 2005
                • 813
                yeah thanks for the fast reply.
                i know which expresscard i'm getting if i can find a lappy with EC. most lappys should have TI chips, since via pulled out a while ago. i currently have a gigabyte ga-ma770-ds3 so i've got a nice tsb fw chip in here. at least an old acer my buddy has (1.5 years old) has a ti chip in there.
                • stevo1210
                  • Oct 2006
                  • 4156
                  I thought firewire was standard on all laptops these days? (except netbooks).
                  Because even my 5 year old Dell Inspiron E1505 and even older 7 year old Toshiba Satellite P25 has firewire...
                  • mockingbird
                    • Dec 2008
                    • 5484
                    What!? All the lower end laptops have firewire, or at least they did...
                    Laptops only use TI chips... Or at least I've never seen one with a VIA.
                    • toastygoodness
                      • Jul 2005
                      • 813
                      yeah, they used to........... now i can't find one :-(
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        usb sound?
                        that might be a better alternative...
                        firewire seems to be a dying interface. usb seems to have taken over almost every port...
                        sigpic
                        • toastygoodness
                          • Jul 2005
                          • 813
                          can't. the only usb audio interface i know of is either e-mu 0404 or tascam ul144mk2. both cut out at random intervals (not predictable at all) and only reset when the asio driver's reset. usb sucks for audio, no matter what. even usb3 isn't supposed to have the right specs. plus i'm not gonna go out and spend another $260 that i've already spent.
                          not only firewire is dying; seems like pcmcia/expresscard too.
                          • mockingbird
                            • Dec 2008
                            • 5484
                            Expresscard certainly is not dying. These days you can even get Phillips-based SAA713x based tuners. And they really pass through the PCIe unlike the fake expresscard tuners which simply route everything through USB.
                            • mockingbird
                              • Dec 2008
                              • 5484
                              Also, Newegg has a large selection of PCMCIA/Expresscard firewire cards:
                              Newegg PCMCIA Firewire
                              Newegg Expresscard Firewire
                              Good luck.
                              • washu
                                • Jul 2009
                                • 310
                                Dell Studio 15 and Latitude E5400 both have firewire and are well under $1K. Don't know what chipset, but I assume TI.
                                • toastygoodness
                                  • Jul 2005
                                  • 813
                                  no no no no, you misinterpret. i've already found the cards themselves. lemme rephrase it: the SLOTS are dying. they are nowhere to be seen.
                                  • toastygoodness
                                    • Jul 2005
                                    • 813
                                    Hmmm sounds interesting. Thanks for the find!
                                    I only wish it weren't Dell but at least its a Latitude.
                                      • 31201
                                      they are probably not fitting the slots because of the stupid obsession with trying to make laptops thinner (and easier to break).
                                      give me a nice chunky thinkpad or satellite-pro type machine anyday.
                                      who wants a laptop that looks like a sheet of thick cardboard!!!!
                                      • toastygoodness
                                        • Jul 2005
                                        • 813
                                        well, found out it can't be a dell.... ironically from an amazon review, the guy was complaining about the audiofire not working until he noticed that dell used via...
                                        • mat2k
                                          Lenovo 300-15IBR - No SYSON, no SUSP#, bunch of missing voltages
                                          by mat2k
                                          Hello, I've been struggling with this one today. I'm troubleshooting a Lenovo 300-15IBR (board BMWC1/BMWC2 NM-A471) that turns on the power LED and does a bit of fan spin but nothing else. 3v3sb and 5vsb present, no 1.05v, no 1.35vddr, no vcore, no 1.8vsb.
                                          BIOS has been reflashed with one I found here, supposedly tested OK by someone else. I don't have an EC programmer unfortunately.
                                          I looked around and SYSON is 0v, SUSP# is 0v too. Forcing them to 3v3 enables the 1.35v rail, but the 1.05v and 1.8v rails are still missing (generated by PU704). EN_1P05A signal is 3.3v, and IN_1P05A...
                                          12-01-2024, 11:00 PM
                                        • falcontech
                                          MOTU TRAVELER MK3 AUDIO PROBLEM
                                          by falcontech
                                          Good Afternoon
                                          I have a problem with this MOTU audio card, a traveler MK3, the connection to the computer is via firewire, the card is recognized by the computer (both mac and win) but I have no audio output, on the front there are a series of LEDs including the clock (44.1, 48, etc.) and that LED at the time of connection usually remains fixed telling me the clock frequency set on the computer, now at every start the LED in question remains flashing in most cases, sometimes it becomes fixed, other times it disappears, without any sign of operation, I exclude problems with the firewire chip,...
                                          01-24-2025, 08:47 AM
                                        • Jidis
                                          Need T-Con Advice (Vizio P602ui-B3)
                                          by Jidis
                                          I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
                                          He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
                                          09-22-2025, 05:10 PM
                                        • sknepscheld
                                          Garmin Echo 101
                                          by sknepscheld
                                          Hi
                                          I am busy repairing a Garmin Echo 101 device that has a blown IC.
                                          The only information on the IC is IV7DF. (See attached foto)
                                          I am not able to find this component or any replacement.
                                          Are you perhaps able to assist me to identify the component or a possible replacement?
                                          Regards
                                          Spidey...
                                          07-28-2020, 02:35 AM
                                        • TrumanHW
                                          M1 MBA has MDM mgmt but is not locked - should I still try removing?
                                          by TrumanHW
                                          So, people like Stephen and others are working on IC and MDM on the M1 ...
                                          There's a recipe posted for dealing with MDM ...
                                          ------------Mazoot's RECIPE------------
                                          1. Hold ⌘-R to boot into Recovery --> Utilities --> Terminal, type:
                                          $ csrutil disable
                                          $ reboot
                                          2. Hold ⌘-R to boot into Recovery again:
                                          3. Enter Disk Utility, mount: Macintosh HD volume (if its not already)
                                          4. Exit Disk Utility & open Utilities --> Terminal and type:
                                          $ cd "/Volumes/Macintosh HD/System/Library"
                                          $ cd ../../etc...
                                          04-09-2022, 10:07 PM
