[Stupid Question #2] Why we are still using 12v on the ATX power source?
  • leotron
    • Apr 2019
    • 29
    • Offworld
    As the title says do you think it would be useful for modern PCs to use more DC voltage ? I know you can compensate the lack of voltage giving more AMPs but still at this rate we should be using 36v at least. Also why we can't connect an badass AC turbine (110~220) inside the case?
    Delete the thread if its garbage please.
    Regards and thanks for you patience.
  • petehall347
    • Jan 2015
    • 4430
    Re: [Stupid Question #2] Why we are still using 12v on the ATX power source?
    12v is easier to find in the ghetto .
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      (1) There needs to be some intermediate voltage, and it will still be a double conversion (120/240 line -> 12V or whatever -> 1.5V or whatever the ICs need, and this wire needs to be really thick as it could need to deal with upwards 50 amps...). 12V is ubiquitous anyway and it's needed for hard drives and other peripherals anyway.
      Note that in server farms they typically use 48VDC but this too is a historical number and may well could have been 36V. We should be focusing on using less energy anyway.
      (2) There's no 120V fans due mainly to cost - to ensure that it meets grounding safety requirements.
      • redwire
        • Dec 2010
        • 3912
        Power mosfets in the 30V league are optimized for cost, use in laptops and motherboards, so you could go higher than 12V but not to 24V.
        Intel's new ATX 3.0 standard (for 600W gaming video cards!) is still 12V. They added a connector but seem OK to go to 50A. Nobody likes the standard yet.
        • leotron
          • Apr 2019
          • 29
          • Offworld
          Thanks for the honest answers, maybe I forget that the big tech companies make money selling servers and such (BIG LEAGUE) desktop gaming pc it's just 5 dollars per piece if I recall correctly, the earning are in the ideas ("look i have an algorith or a diode that reduces 5w in pwr compsunsion, etc")
          Another question: Wouldn't be cool if the GPU came with their own PSU ?
          • diif
            • Feb 2014
            • 6978
            • England
            Google's servers use 48v.
            Why would it be cool, what's the benefit ?
            • desert-rat
              • Mar 2014
              • 4103
              The old (ww2 era) aircraft tube radios had a small motor/ generator for the tube plate voltage ( 150-300 vdc typically)
              • brethin
                • Dec 2008
                • 1907
                They way Video Card requirements are going I wouldn't be surprised to see a 24v or higher PSU introduced in the next year or so.
                • brethin
                  • Dec 2008
                  • 1907
                  more power less connecters.
                  • brethin
                    • Dec 2008
                    • 1907
                    It's the same reason battery yard tools went to 80v vrs 40v.
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      I've kind of wondered this a little as well..... I'd love to see the little kiddies playing inside their PC's when there's a motherboard full of exposed metal with 80v present!!
                      <--- Badcaps.net Founder
                      Badcaps.net Services:
                      Motherboard Repair Services
                      http://folding.stanford.edu/
                      Team : 49813
                      Join in!!
                      Team Stats
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        24V works great in my world. Pretty much *the* standard for industrial controls wiring (PLCs, automation, etc.).
                        Per OSHA (and other codes) Low voltage ends at 50V... which is why POE is considered low but 120V isn't. Which technically means the 90V on phone cords isn't low voltage either!
                        sigpic
                        (Insert witty quote here)
                        • desert-rat
                          • Mar 2014
                          • 4103
                          With the battery system on the new electric cars around 800v ,I can't wait until d I y ers with poor electrical skills start messing with them.
                          • TechGeek
                            Computer Geek
                            • Jan 2015
                            • 2254
                            Unless there's ring current, then it's basically trickle-charge levels of current available.
                            Permanently Retired Systems:
                            Kooky and Kool Systems
                            sigpic
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16958
                              ~100v @ 20Hz will still sting you.
                              Those old magnetos from hand crank phones can be a lot of fun sometimes!
                              Team : 49813
                              Join in!!
                              Team Stats
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                OT: Took some digging, but I found a better smiley for you in this case:
                                sigpic
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16958
                                  Added.
                                  Good find, especially for this place!
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                    • Jul 2011
                                    • 6057
                                    This is a good one
