ATX motherboards with missing i/o shield...what to do...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8711
    If you get a bare motherboard with no I/o shield, what do you do with it?
    Use without shield?
    Find a shield?
    Trash board?
    Wish there were more standardized i/o shields but this is annoying...
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: ATX motherboards with missing i/o shield...what to do...
    Make one from a blank if you can't find one. https://www.badcaps.net/forum/showpo...0&postcount=43
    Search the board model on ebay, many times they'll be there unless it's a really obscure board.
    Running without one is a pet-peeve of mine for some reason...makes a build look cheesy & incomplete.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8711
      wow the blanks are not cheap....neither are the plates. ugh... wonder how bad custom plastic ones from 3d printing will work?
      • diif
        • Feb 2014
        • 6978
        • England
        It depends where you get them from. https://www.aliexpress.com/item/4001333341322.html
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8711
          Do you guys make a lot of custom plates? must be time consuming...
          • diif
            • Feb 2014
            • 6978
            • England
            No, in the past I've just modified one that is close, nowadays I'd give a blank to a mate that runs a cnc laser where he works if it mattered.
            • brethin
              • Dec 2008
              • 1907
              Don't use one, they are just cosmetics.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8711
                for those who have dealt with a lot of these boards, are the PS/2 ports at the exact same location regardless of board, short of the V1 boards where the two ports are on the board, and all others are stacked?
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Use without shield?
                  Find a shield?
                  Trash board?
                  Option #3 made me LOL .... but seriously, who'd do that?
                  I'm more of a option #1 guy - sometimes I'll skip it, even if I already have the shield for the board. It depends on who the PC is for and where it will be used. If the PC will see a lot of cable connections/disconnections on the back (be it audio or video), then I prefer to have an IO shield to prevent accidental shorting of pins/ports - particularly with 3.5 mm audio jacks (so in that case, I will buy or make one.) On the other hand, if I have a "hot" motherboard stuffed in a case with not-so-optimal cooling, I may forgo the IO shield to get more open airflow - especially with air from the CPU heatsink going through the CPU VRM area and directly exhausted between the ports rather than having to curve up and into the case exhaust fan (if there is one) and PSU exhaust fan (if PSU is on top.)
                  So in short, the IO shield is a bit of a function-over-form for me... just like most of my PC builds anyways. (though a lot of times, they have neither function nor form )
                  In the late 90's and early 2000's, IO shields were pretty standard: two stacked PS/2 ports on top, two stacked USB ports, a row of two serial ports with a parallel port on top, and a row of three 3.5 mm audio jacks with a game/MIDI port on top. Then in the mid 2000's, the stack of 2x USB's usually got shifted below the stack of parallel + serial ports stack... and often LAN was added above the USBs and/or one of the serial ports was replaced in favor of a VGA port... meanwhile the audio jacks became vertically stacked, and game/MIDI port was dropped. At least, these two were the most common variations of back then.
                  Or just use clear plastic from food packaging and carefully cut away holes for the ports ... though I find most plastic food packaging to be too flimsy for this. A better alternative is thin sheet metal (plus, it will block EMI/RFI, it being conductive and all ). Don't worry about how it would clamp onto the case - you don't actually need to do that. If your cutouts line up well with the motherboard ports, simply the motherboard pushing it against the case will keep it in place... or if the board has VGA, serial, or parallel ports, add holes and use the hex nuts on those ports to secure the IO shield onto the board this way (kind of like how some Dell motherboards come with their own non-removable shields attached to the motherboard.)
                  For the most part, yes, PS/2 ports are usually on the top and stacked together.
                  Known exceptions (off top of my head) are mid-2000's AsRock (PS/2 ports side by side on the board in a single row) and Dell motherboards... again, ironically from the mid 2000's (Pentium 4 era.)
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8711
                    Well they are stacked but are they at the same X/Y displacement and spacing between the two...
                    I've had a bunch of the old ATX V1 boards where the two PS/2 ports are on the board so they're side by side. These are apparently all standardized but it's a lot simpler when the board only has the two PS/2, two RS-232 DE-9's, and one parallel DB-25... USB nowhere to be found...
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8711
                      Ghetto? Not Ghetto?
                      Has elements of both in it, specifically the solder iron hack because of measurement errors...
                      • petehall347
                        • Jan 2015
                        • 4450
                        • United Kingdom
                        i use to throw lots of those away when i was breaking computers to weigh in the parts .. criminal i know but the money was pretty good .
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16959
                          Ghetto? Not Ghetto?
                          Looks pretty good to me!
                          Team : 49813
                          Join in!!
                          Team Stats
                          • ugamazing
                            820-02020 PPBUS_AON missing
                            by ugamazing
                            Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                            Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                            02-05-2025, 04:21 PM
                          • jpreza
                            Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                            by jpreza
                            I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                            Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                            It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                            Looking at the card, it appears to be missing the following:
                            1x 1.0uH inductor - orange square
                            2x...
                            11-01-2024, 10:54 PM
                          • BYTEHAT248
                            Need help fixing ATI Radeon X800XL AGP 256 (Missing components)
                            by BYTEHAT248
                            Got this card out of a box of old electronics and am hoping there's a way to fix it, when i found it i put it in one of my desktops and it displays a kinda static like bars of color. so upon further inspection i noticed that it is missing a choke and a capacitor, and the other choke is cracked and there's a piece of it missing. im pretty good with smd soldering and i looked around quite a bit but cant seem to find what the part numbers of the missing components are. if anybody could help me out with this that would be great. the part number of the card is P/N 102A4900103 159312
                            11-14-2025, 04:48 PM
                          • gurj1979
                            Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                            by gurj1979
                            Hey guys.
                            Need help with this one.
                            Fan not spinning due to missing PWN Fan signal.
                            Also 5 seconds from powering up it freezes, unless in BIOS.
                            But as soon as Windows starts to load, it will freeze.
                            CPU is COLD / Room temp when it freezes.
                            I've replaced the CPU, same problem.
                            Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                            Replaced fan - same problem.
                            Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                            Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                            08-19-2024, 05:22 PM
                          • salopian
                            Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                            by salopian
                            Hello. I would need some advice please.
                            My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                            He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                            I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                            I have already replaced the logic board with another...
                            02-27-2021, 07:30 AM
