New RAM
  • stevo1210
    • Oct 2006
    • 4156
    New RAM
    I'm wondering if I should upgrade the RAM for the PC in my signature box below...
    As you can see it currently has 1x Corsair 1GB 667MHz and 1x Kingston 1GB 667MHz chips in there [dual channel configuration], making a total of 2GB. Now for me I feel that 2GB of RAM is more than enough for what I need because I just do simple web browsing, play music, watch a DVD, youtube, ebay and Badcaps forums is all I do with it.
    My friend says that I should upgrade to 2x 800MHz DDRII chips and throw these 667MHz chips out because it's limiting my CPU performance?
    So what do you guys think? is it worth spending the $60 or so for 2x new 1GB 800MHz chips?
    Thanks.
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: New RAM
    Technically, yes, you are losing a little bit of memory bandwidth. But do you really need it? I would also suggest that, if you decide to do this, buy 1066mhz memory, as it's the highest speed your motherboard supports. That way, if you ever upgrade to a 1066mhz fsb processor, you've already got the RAM to match.
    Honestly, I don't think the difference of 667 vs 800 is enough to worry about.
    Ludicrous gibs!
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      Re: New RAM
      Have you tried overclocking your ram?
      • Scenic
        o.O
        • Sep 2007
        • 2642
        Re: New RAM
        - a bit late to upgrade DDR2 (prices skyrocketed already)
        - with that Pentium D (P4 x2) it probably doesn't matter anyways..
        • stevo1210
          • Oct 2006
          • 4156
          Re: New RAM
          I don't like the idea of overclocking... It's one thing I'm against in terms of computing.
          • Scenic
            o.O
            • Sep 2007
            • 2642
            Re: New RAM
            because your Pentium4 x2 doesnt OC too well.. or at all?
            no seriously.. its ok. OC doesn't really make sense on a surf-pc anyways..
            for gaming however..
            my mighty little C2D E4300 i used to have in my main comp
            http://valid.canardpc.com/show_oc.php?id=600052
            and the C2Q Q6600 i've got in there now
            http://valid.canardpc.com/show_oc.php?id=1010922
            if GTA IV / EFLC wouldnt exist, i'd probably still be using my S478 P4 Northwood 2.8 HT
            • mattch
              • Mar 2010
              • 121
              Re: New RAM
              you have to ask your self:
              Can i justify the expense for a performance enhancement that i will not notice on a day to day computing.
              kinda like a car that you dont race; should you get those racing sparks and wires, or will the regulars suffice?
              is your friend in sales? if not maybe they will be good at it.
              • Scenic
                o.O
                • Sep 2007
                • 2642
                Re: New RAM
                • dood
                  Deputy dood
                  • Mar 2004
                  • 2462
                  Re: New RAM
                  Curious... is this also the friend who told you you needed alloys for your car?
                  Ludicrous gibs!
                  • seanc
                    • Nov 2008
                    • 1319
                    Re: New RAM
                    I wouldn't bother, there's such a small margin in speed.
                    You'd be better off whacking a cheap C2D in there.
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      Re: New RAM
                      So, pentium D and C2D are so different?
                      • dood
                        Deputy dood
                        • Mar 2004
                        • 2462
                        Re: New RAM
                        No HT on C2D procs, and about 1/2 of the TDP of Pentium D's. Among other improvements...
                        Ludicrous gibs!
                        • Scenic
                          o.O
                          • Sep 2007
                          • 2642
                          Re: New RAM
                          more power per MHz and cooler running.
                          your mainboard has the intel P35 chipset, so it supports anything up to Core 2 Quads..
                          few examples
                          http://cgi.ebay.com.au/150443291569
                          http://cgi.ebay.com.au/230472882474
                          http://cgi.ebay.com.au/280507766480
                          especially the last one seems to be a pretty good deal price-wise.
                          i'd say even the Pentium Dual-Core E2160 (first link) would be at least on par with your current Pentium D 920 performance wise. you probably wouldn't notice any difference (except the temperatures being a lot lower )
                          side note
                          Pentium DC E2160 -> 65nm
                          Celeron Dualcore E3200 -> 45nm
                          Pentium DC E5300 -> 45nm
                          and don't laugh at the Dualcore celeron. core-based celerons are serious performers. (because they are basically just Core 2 Duos with less cache .. same for Pentium Dualcore CPUs)
                          edit: Pentium D != Pentium Dual Core
                          can be destinguished relatively easy, as the core-based ones all have model numbers starting with "E" followed by 4 numbers (E2180 or E5200 for example) and all Netburst/P4 based Pentium D model numbers start with "D" followed by 3 numbers.
                          • seanc
                            • Nov 2008
                            • 1319
                            Re: New RAM
                            I upgraded to an E8400 recently, cost me about £90, nice upgrade.
                            • Lobo
                              • May 2010
                              • 59
                              Re: New RAM
                              For what you use that PC for, It won't make much of a difference. The only reason I could see that you might need to upgrade your RAM is if you are having issues with using 2 different brands of RAM sticks.
                              And yeah, since Win 7 came out the price of RAM has skyrocketed. Unless you plan on playing games, or upgrading to a 64 bit OS, you should be just fine.
                              • washu
                                • Jul 2009
                                • 310
                                Re: New RAM
                                P4s don't seem to care as much as Core2s about memory speed. You would never notice the difference. Put that money towards a better upgrade.
                                • Junk Parts
                                  Court Jester
                                  • Jun 2006
                                  • 8953
                                  Re: New RAM
                                  Never put good ram in the bin! People like "Junk Parts" value this stuff greatly...LOL I wish I had kept all that real old ram that I tossed. There are people who collect old system that are crying for it these days.
                                  Mark Twain
                                  John Paul Jones
                                  Rod Serling
                                  • stevo1210
                                    • Oct 2006
                                    • 4156
                                    Re: New RAM
                                    Well basically speaking a week ago I had 2x Kingston 800MHz chips in there but my brother traded me these ones cause he needed the 800 for the new build.
                                    I really can't feel any difference...
                                    But at the moment I'm having another confusion. I'm building another secondary system which has an Intel DP965LT motherboard and a Pentium Dual Core E2160.
                                    Since I am buying new RAM for that system, should I run the 800MHz chips in my Pentium D system or should I put the 800's into the Pentium dual core system? The Pentium dual core system will be used for more intensive applications such as DVD burning.
                                    Thanks.
                                    • stevo1210
                                      • Oct 2006
                                      • 4156
                                      Re: New RAM
                                      BTW, the Pentium dual core system is for my father, not me.
                                      • washu
                                        • Jul 2009
                                        • 310
                                        Re: New RAM
                                        Put the 800MHz RAM with the E2160. It is by far the faster chip and core 2s like having synchronous FSB and RAM. You still probably wouldn't be able to tell the difference on either chip between 667 and 800, but benchmarks will show a bigger diff % on the E2160.
                                        • ugamazing
                                          Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                                          by ugamazing
                                          I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                                          08-31-2022, 07:34 AM
                                        • feherhollo
                                          WSON8 NEW Bios Chips READ, ERROR, ETC.
                                          by feherhollo
                                          I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
                                          I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
                                          For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
                                          11-26-2023, 09:33 AM
                                        • Prott
                                          [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                                          by Prott
                                          Hello dear badcappers!
                                          The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                                          Backstory:
                                          After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                                          If there is a way to narrow down which memory module is faulty it would make my life much...
                                          06-03-2024, 12:05 PM
                                        • LukeDavis
                                          Is there a list of known dodgy ATI Radeon chips?
                                          by LukeDavis
                                          Hello again! (People are likely going to get tired of seeing posts from me lol)
                                          I'd like to try and compile a list of known bad AMD/ATI Chipsets and graphics processors.
                                          While I do not possess the knowledge of some of the brilliant minds on this forum, I can at least mention a few chips I've encountered as being troublesome.
                                          1. ATI 216-0752001 (RS880M/RX280M) found inside 2 HP laptops, one I've since deemed screwed, and swapped the board to an intel one, the other HP seems to be less hateful and runs fine.
                                          2. ATI Mobility Radeon X1600 and the...
                                          02-16-2024, 04:34 PM
                                        • piernov
                                          NVidia bumpgate
                                          by piernov
                                          Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                                          Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                                          May complete this post at a later date with more details.
                                          Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                                          03-27-2021, 10:34 AM
