Gray-Hoverman antenna
  • Hondaman
    • Sep 2008
    • 1085
    Hello all,
    Recently I'm upgrading my Gray-Hoverman antenna. Original design. I cannot use a "double-stacked" antenna because of attic space. I do not wish to mount anything to my chimney.
    I am using a separate antenna for WHAS Channel 11 (they are using RF Channel 11, 198-205 MHz). I replaced my 29-inch "T" antenna made out of #12 or #10 wire. I made a 58-inch "T" antenna out of 0.25-inch copper tubing. Hooked it up with a matching transformer to the 75-ohm coax going to my TV. I held the "T" antenna up against my ceiling, less than 12 inches below the old antenna in the attic (one-story ranch style home).
    The new 58-inch monster didn't seem to do any better! When I replace the copper wire on the "bowtie" antenna (in the coming weeks) will the rest of the channels show no improvement? Will the signal never reach 100%, but will there be less degradation during wind and storms?
    You can see the towers from my back yard, and I STILL have dropouts during wind and rain. I'm even using a reflective screen (reflective element) 4 inches behind the bowties (driven element).
    Am I wasting my time with this upgrade?
    • 31122
    Re: Gray-Hoverman antenna
    have you tried adding a grounded plate behind the elements?
    • Hondaman
      • Sep 2008
      • 1085
      A grounded plate? Well, yes and no. I have two pieces of wire mesh behind the two "bowties" that "reflect" and make the antenna more directional. I think one is 0.25 inch. The second antenna, that I am building, has 10mm by 10mm mesh. They are not grounded, but just mounted behind the "bowties" and not "hooked up" to anything.
      (I am building a second Gray-Hoverman [and a rod for 201 MHz] that I would like to put on the other side of my attic, to feed the television set in my bedroom.)
      Maybe I'll attach a picture of one of them.
      NOTE: WBNA (Channel 8, 180-186 MHz) put their antenna near the airport in Louisville, a completely different direction than the rest of the TV stations in my area. I am not making any effort to receive their signal.
      Further information: It looks like Channel 51 (692-698 MHz) is as high as modern ATSC television transmitters go nowadays. Soon, it looks like Channel 36 (602-608 MHz) will be the highest frequency for TV. At the dawn of US television (1947) Channel 1 was abolished, it interfered with two-way taxicab radios. Channel 37 (608 to 614 MHz) has always been used for radio astronomy, not television. And the US Federal Communications Commission never gave anyone permission to operate a TV transmitter above Channel 69 (800-806 MHz). Many of those old "television channel" frequencies were "re-purposed" and set aside for use by cell phones, a process that started in 1982/1983.
      • Hondaman
        • Sep 2008
        • 1085
        Okay, when I replaced the wire (10 or 12 gauge in the US system would be metric 4.0 or 6.0 square mm cross-section) on the main antenna with 0.25 inch copper pipe, the antenna did not give any better performance, but I put it back in my attic.
        When I ask my TV to tell the "percent signal" (very un-scientific) on Channel 11 (198-205 MHz), the "T" antenna (29-inches, 10 or 12 gauge wire) DID outperform the 58-inch "T" made with copper pipe. So I put the 29-inch wire "T" back in the attic as well. This time I hung it up, and it is 30 inches higher than before.
        So all TV stations are now at 97% signal except for WHAS Channel 11, which hovers around 90-92% in clear skies. This is as good as I will ever get.
        EDIT: I made sure both the antenna and the "T" antenna had the same length of RG-6 going into the splitter/combiner to prevent signal from one antenna "backfeeding" into the other which would have hurt performance terribly.
        (It also seems that the metal mesh reflector screen did not help things. I was using a temporary crude "bowtie" with no reflector screen and a 29-inch "T" for Channel 11 and got the very same results on all channels that I am seeing now.)
        The attached picture shows the old wire version just after I finished building it at the end of March 2008.
          • 31122
          presuming your signal is DVB encoded and not analog,
          strength is less important than quality.
          the strength can be boosted in the tuner, but the BER (bit error rate) is what it is.
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            Wow, Most plumbers can't put PVC together that nicely!
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • eccerr0r
              old X58 triple channel board... memtest86 memory speed?
              by eccerr0r
              Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
              Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
              Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
              06-28-2025, 09:06 AM
            • Hondaman
              Single-channel antenna?
              by Hondaman
              Recently I switched from my Gray-Hoverman to the Antennas Direct ClearStream 4 MAX. Seems to work about as well as the old G-H in my attic (one-story ranch home), but the Antennas Direct unit can be mounted outside on my chimney if desired.
              I should mention that I was also using a 29-inch "T" shaped antenna for RF channel 11. I know you're not supposed to use TWO antennas unless they have the same length coaxial cable going into your combiner (and even then there might be problems). So I made sure the cables were equal length.
              Years ago I made a "T"...
              11-18-2024, 01:14 AM
            • spleenharvester
              Reverse engineering of 18650 4-channel tester
              by spleenharvester
              Hi friends
              I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
              05-04-2025, 02:43 AM
            • mikey5791
              Help on car amplifier only one channel works
              by mikey5791
              Hi all forum members,
              Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
              My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
              08-06-2025, 10:36 PM
            • Chaks
              Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
              by Chaks
              TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
              The specs says ...
              High antenna efficiency 868MHz ISM Band
              5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
              The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
              1. Should I Fix it with a glue.
              2. Should I fix it with a double side adhesive tape
              3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
              12-09-2024, 11:06 AM
