Post your system.......
This is a sticky topic.
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747 -
ASRock B550 PG Velocita
Arc A770 16 GB
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
Re: Post your system.......
Just did a few upgrades again.
Also,replaced the stock heatsink finally. It's some Acer/Foxconn heatsink that comes with a backplate.
Specs:
ASUS P5QL PRO w/ Xeon BIOS
2GB RAM
Radeon R7 240 2GB DDR3
Pentium E5200 2.5GHz
Allied AL-A400ATX 120mm
2x H-L Data Storage DVD-RW drives
1TB Samsung HD103SI 5400RPM SATA II HDD
AVerMedia AVerTV Super 009 TV tuner
Windows 7 Ultimate SP1 x64
Delux MG760 case (BMW-styled case made out of Zinc.)
Attached Filesif you find these attachements useful please consider making a small donation to the site
Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
Main rig:
Gigabyte B75M-D3H
16GB DDR3-1600
Delux MG760 case
^ Lol, what's with all the red paint inside the case?
Or is that blood from someone cutting their fingers on the cheap case?
... Or perhaps this came from some place where there was a zombie apocalypse?
Anyways, good build, though. Looks like you finally have a pretty decent system now.
I've taken pictures of a few of my rigs. Will share soon when I have time. They are all ratchet / laughing stock, but they serve me well for now.
It was some failed case mod - I had an red spray paint can that was past its expiry date and using it quite gave that result. I didn't bother to paint the metal chassis again so I just painted the plastics (front panel and top handle (since this case has a handle) and the side panels and left the chassis like that.^ Lol, what's with all the red paint inside the case?
Also it's not that bad. Unlike every case on the market that is made out of thin tin,I was told this thing was built using Zinc,and just the case itself (without anything in it) was heavy as hell.
Main rig:
Gigabyte B75M-D3H
16GB DDR3-1600
Delux MG760 case
Finally stuck a drive(that actually works) in my Dell Inspiron E6520.
160GB HDD(maybe temp)
everything else is stock
Service Tag: CTXH4R1Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
Permanently Retired Systems:
Kooky and Kool Systems
sigpicComment
The Asus P5QL Pro was the motherboard I used to have. From September 24, 2008 to February 11, 2013, it was my best motherboard in service!Just did a few upgrades again.
Specs:
2GB RAM
I first had a Pentium E2180. (Core 2 Duo-based and 65nm) (Also a Conroe)
On August 17, 2009, I dropped a 2007 Core 2 Duo "Conroe" E4500 (65nm) onto the Asus P5QL Pro motherboard. And probably during the tail end of 2012, was when it got a Core 2 Duo "Wolfdale" E8400 (45nm) in there!Last edited by RJARRRPCGP; 03-26-2017, 05:27 PM.ASRock B550 PG Velocita
Arc A770 16 GB
Just did a rebuild of my main rig after the death of key components:
Intel i7-3770
16GB of RAM (4x4)
MSI B75MA-P45
ASUS GTX 660 Ti DirectCU (2GB DDR5)
Seasonic S12II-620 PSU
2x1TB HDD (Seagate and Western Digital)
1x500GB (Western Digital)
ASUS DVD-RW
Antec 300 CaseCPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1Comment
I got this system from a dumpster. Anyone know what GPU should I replace the MX440 with?
ASUS P4B533
1GB RAM
80GB HDD
300W Deer DR-A300ATX
GF4 MX440 64MB
JNC case w/multicolor leds
Pentium 4 2.8GHz Northwood core
Pioneer DVD-117 DVD-ROM
3com 10/100 NIC
Windows 2000 SP4Main rig:
Gigabyte B75M-D3H
16GB DDR3-1600
Delux MG760 case
MX440 is an AGP card , so you don't have Pci Express slots . Anyway , I would go for VisionTek Radeon 3450 , because it can support directx 10 .
Here's a web link where you can choose :
https://www.lifewire.com/best-agp-graphics-cards-834107Comment
I finally got around to using my AMD Athlon 64 FX-57 CPU!
Just in case anyone still remembers... YES, this is indeed that CPU with the broken pins that I posted about several years ago in the Ghetto Mods thread:
https://www.badcaps.net/forum/showpo...5&postcount=54
It took me a few tries to get the CPU going, mainly because a few years back, I tested it in a motherboard that had gel flux in the CPU socket, so the flux had some of the pins slightly corroded. But after cleaning the pins and testing the CPU in various motherboards to try to figure out why they wouldn't detect it, eventually it did come back to life. I now have it in my "Team Red" ATI-AMD 64 classic gaming PC. And boy, that CPU flies! Windows XP is extremely snappy. Even internet browsing is fine, despite this being a single-core, single threaded CPU.
Then again, this is after all one of the fastest single-core CPUs one can buy (and certainly the fastest for Socket 939).
After the upgrade, though, I did have to use a lower-TDP GPU in that PC. The FX-57 is a 105 Watt TDP CPU, and I am using a 250 Watt HiPro with 16 Amps rating on the 12V rail. There was no way I could keep my HD3870 in there with that CPU, because that would require 210 Watts on the 12V rail (and that's without factoring the HDD or anything else). I was already close to maxing out the PSU's 12V rail even with the AMD Athlon 64 3500+ that was in there before the FX-57. So that PC is still not quite finished yet. But I do have some work-in-progress pictures... just need to get them off my camera and organize them a bit. I've been a bit sloppy with file management lately.
Lol. That mod actually turned out awesome, though. You now have a proper Halloween-themed PC.
I doubt it is purely made of Zinc. Zinc is rather hard and brittle. Probably just thicker steel.
Well, the question is, what do you want to do with that PC? General internet browser? Or just a classic gaming PC?
I personally wouldn't use a Pentium 4 CPU without HT for an internet browser, because the P4 architecture will struggle without HT on just about every website. If you do want to use it as an internet browser, then I suggest going with a GeForce 6 or 7 series video cards, because those support H.264 and will off-load the CPU quite a bit on flash/video-heavy websites. An alternative to the GF 6 and 7 series are the ATI HD3x00 series, as those are the first generation of cards that offer somewhat better H.264 decoding/encoding.
Otherwise, if you are building a classic gaming PC, something like an older mid/high-end AGP GPU like the GeForce4 ti4400/4600 or Radeon 9500/9600/9700/9800 would do quite alright. If you can find one of these for cheap, definitely snatch it - the value of those video cards has gone up quite a bit in the last several years. And it will go up probably even more as AGP gets older and older. Just look up the price of any VooDoo video card now, and you might get an understanding.
My bad. It's actually galvanized steel. (which I think it has Zinc in its composition)
I might source a Radeon 9500 or any of these. One of my friends runs a 2.8GHz Pentium 4 w/ FX5200 as his daily driver (he couldn't afford anything better) and Firefox 50 and Youtube ran okay,without stuttering. I have to mention,it has a 2GB DDR400 Kingston KVR stick in it,so that may be the reason internet browsing was pretty easy for him on that P4.Well, the question is, what do you want to do with that PC? General internet browser? Or just a classic gaming PC?
Gigabyte B75M-D3H
16GB DDR3-1600
Delux MG760 case
It does, galvanized steel is steel that is dipped in molten zinc (or in some cases electroplated) to provide a corrosion resistant coating.Comment
yea that makes much more sense. last i checked the commodity prices of base metals in the stock market, zinc is half the cost of copper per pound and more expensive per pound than lead or aluminium. a full zinc case might end up getting stolen by thieves lol...Comment
Just recently upgraded to Skylake from Haswell, and from mini-ITX to microATX at the same time, as i figure it'll be the last 7 box for me. Just did a test clone of 7 to a fresh SSD and it migrated cleanly over, with just a reactivation needed since all the hardware changed.
So far i've been impressed by Skylake's overclocking ability and cooler temps relative to Haswell, with roughly equivalent cooling. So far seeing CPU temps about 15 to 20 C cooler relative to Haswell when redlined in latest version of Prime95 with 200MHz minimum clock speed advantage .
Core i5 6600K (4.5GHz in single/dual, 4.2GHz in triple/Quad) , + 100mV Vcore offset, so peaks about 1.27V in single/dual mode.
Asrock Z270M Pro4 microATX Z270 motherboard
16GB (2x8GB) Crucial DDR4-2133
Sapphire RX480+ 8GB videocard
Samsung 850Pro 512GB SATA boot SSD
Samsung 850Evo 500GB SATA SSD
Samsung 750Evo 500GB SATA SSD
Crucial MX300 750GB SATA SSD
Samsung XP941 M.2 X4 128GB PCIe SSD
Intel 600p M2 M.2 X4 512GB NVMe SSD
Seagate 4TB 7200 HDD
Hitachi 3TB 7200 HDD
Seasonic M12II 520W Bronze PSU
Cooler Master N200 microATX chassis.
LG bluray burner
PCIe x1 addon card for 4X SATA ports
120mm Tower CPU cooler, i forget the brand, but replaced the stock fan with a decent Noctua fan, 3000 RPM max, but it doesn't get hot enough to run the fan 100%.
I'll probably eventually throw in a 2X hotswap 2.5" bay in it, and use a couple more of the SATA card ports.Comment
If you really like Skylake, then Kaby Lake shall really rock!Just recently upgraded to Skylake from Haswell, and from mini-ITX to microATX at the same time, as i figure it'll be the last 7 box for me. Just did a test clone of 7 to a fresh SSD and it migrated cleanly over, with just a reactivation needed since all the hardware changed.
So far i've been impressed by Skylake's overclocking ability and cooler temps relative to Haswell, with roughly equivalent cooling.ASRock B550 PG Velocita
Arc A770 16 GB
My systems as of now:
Main rig:
ASUS P5QL PRO
Pentium Dual Core E5200 2.5GHz
2GB RAM
Windows 7 x64
Delux MG760 case (galvanized steel)
2x H-L DVD-RW (IDE)
Radeon R7 240 2GB PCI-E
AVerMedia AVerTV M733A TV Tuner (PCI, Phillips based)
1TB Samsung HD103SI
Allied AL-A400ATX 120mm PSU (recapped)
2nd:
ECS G31T-M7 v1.0 (poly caps from factory on VRM, OST on RAM and other low power stuff)
Pentium Dual Core E5300 2.6GHz
1GB RAM
Windows XP SP3
Delux MT375 case
1x LiteOn DVD-RW
Samsung HD161JJ 160GB SATA HDD
Delux ATX-450W P4 PSU (recapped)
3rd:
ASUS P4B533 (recapped)
Pentium 4 2.8GHz (Northwood)
1GB RAM
Windows XP SP3
JNC FQ-70 case
1x H-L DVD-RW (white bezel)
Radeon HD3450 AGP 512MB
80GB WDC WD800BB IDE
L&C LC-B350ATX (recapped, thick heatsinks)
4th:
Gigabyte GA-8I848P-G (recapped with Rubycon MBZs)
Pentium 4 2.8GHz
512MB RAM
Windows 7 Ultimate x86
JNC RJA52 case
1x Samsung DVD-RW
Palit GForce FX5500 256MB AGP
80GB WDC WD800JB HDD
Modecom FEEL-400ATX (Deer built - recapped with Rubycon MBZ)
5th:
Biostar P4M80-M4
Celeron 2GHz Northwood
512MB RAM
Windows XP SP3
JNC 4JA-52 case
1x Sony CRX-300E DVD-ROM
ABIT Siluro FX5200 64MB
80GB Hitachi SATA HDD (laptop drive)
no PSU yetMain rig:
Gigabyte B75M-D3H
16GB DDR3-1600
Delux MG760 case
Main box consists of
Striker extreme main board
Intel quad core extreme clocked at 3.2gig
cosair 1200 watt psu
16 gig ram
2 x gtx780ti (SLI)
250 gig ssd system
2 tb data drive
Win 7 professional
2 LG optical drives
I am not sure what brand the tower isComment
by canadaboy25Hey guys,
I have an Asus M5A99FX Pro R2.0 motherboard with AMD RAIDXpert. I set up a 1000GB RAID1 array on it. This was about 8 years ago. Every once in a while, a power outage or something would knock one drive offline and degrade the array. After a reboot the drive would be back online and it would rebuild just fine.
Recently, a drive dropped offline and the array became degraded. I figured it was no big deal and rebooted then set it to rebuild overnight. The next morning I took a look and both drives had dropped offline at 70% rebuild. Uh oh.
I rebooted...-
by SMDFleahttps://winraid.level1techs.com/t/wi...uncement/38021
The win-raid forums are closing at the end of this year,its a sad time for all who have used the site to gain knowledge from some of the really talented members there.
by bmxlovahHi,
My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...-
by tbalint3Hello All,
I am trying to repair an old Abit ST6-R motherboard.
The symptoms are the following:
I got it in a non-working state. I was told that it sometimes turned on, but many times just the CPU fan was spinning and no other signs of life, the board didn't POST, and now it doesn't POST at all.
It was full of bulged electrolytic capacitors, so I replaced all of them with new Low-ESR ones, but it didn't solve the problem.
If I install a CPU in the S370 socket, only the fans are spinning and no POST. There are no beep codes even if the RAM DIMMs...3 Photos -
by canadaboy25Hey guys I'm wondering if anyone has any ideas on how to get Windows 10 to boot up and install drivers after changing the bios settings for the sata port from raid to ahci.
My motherboard is an Asus M5A99FX pro R2.0 and when I built the PC I set all of the sata ports to raid mode. There is one setting for ports 1-4 and one setting for port 5 and the esata port. I currently have 4 drives set up in two raid 1 arrays on ports 1-4. My ssd containing Windows 10 is plugged into port 5. I also have an external esata enclosure with a 2tb drive that I use as a Windows backup plugged into...-
- Loading...
