Post your system.......
This is a sticky topic.
    Re: Post your system.......
    You're still using a Can't Read This monitor??
    Me thinks it's time for an LCD, and some zip ties for those cables too.
    Anyhow, nice case modding.
      reasons I still use a CRT:
      1. not enough $
      2. not enough $$
      3. not enough $$$
      If I had the money and more incentive, I would. however it never seemed like a priority to me. As many decent CRT's i have gotten free, if it works, I'm happy.
      for the zip ties- I used to have more in there for the front panel cables... but for the others, there is little point since the PSU is not modular and there is so much cable there that zip ties wouldn't help much... why this one was not made modular is a mystery to me. It was a freebie (needed a recap) so whatever.
      sigpic
      (Insert witty quote here)
        I have a 21" Sony trinitron (dell oem) if you want it, gotta pay for shipping... hahah
          Sorry, I guess I just take for granted how cheap my one was.
            Intel Core i7 920 @ 4.01GHz (191x21=4011MHz @ 1.33Vcore)
            Gigabyte GA-EX58-UD5
            3x 2GB Corsair XMS DDR3-1600 (764MHz 8-8-8-24 2T @1.64V)
            XFX AMD Radeon HD6950 2GB (Flashmodded to HD6970 specs)
            Sound Blaster X-Fi Titanium (recapped)
            Crucial M225 64GB SSD
            Highpoint RocketRAID 3510 (4x Samsung F3R 1TB RAID5=~2.8TB usable)
            Cooler Master HAF 932 case
            Cooler Master UCP 900w
            LG 10x Blu-Ray burner.
            Windows 7 Professional 64-bit
            Prolimatech Megahalems with 2x 120mm Fans in push/pull. Case cooling is stock. 230mm on the front, side and top. 140mm on the back.
            My Netbook
            Asus EeePC 1000HE
            Intel Atom N280 2.66GHz
            2GB Kingston HyperX DDR2-667
            Seagate 160GB
            Gentoo Linux 10.1
            The desktop bound laptop:
            Dell XPS M1330
            Intel Core 2 Duo T5450 1.66GHz
            2x2GB DDR2-667
            WD Caviar Black 7200RPM 160GB
            Gentoo Linux 10.1 ~amd64
            The touchpad does not work, even in Windows, some sort of hardware issue with it since it appears in the list of devices. Also, the battery is cooked, if you unplug it from the wall it will last about 5-7 minutes then just click off, no warning whatsoever.
            Toy:
            Dell Poweredge SC1430
            2x Intel Xeon 5148 2.33GHz Dual Core.
            4x 1GB DDR2-667 FB-DIMM
            MSI nVidia 8500GT 512MB (Cut PCIe connector to x8 width)
            2x Seagate 7200.11 500GB (RAID 0)
            Gentoo Linux 10.1
            Case, power, cooling all factory.
            Brother's Laptop:
            Acer Aspire 4730Z
            Intel Pentium Dual T3200 2.0GHz
            2x 2GB G.Skill DDR2-667
            WD Caviar Black 500GB
            Windows 7 Home Premium 64-bit
            Mom's
            AMD Phenom II X3 715 2.8GHz@3.2GHz (Heka)
            Gigabyte MA770-UD3
            4x 1GB GEIL Dragon DDR2-1066 (Running DDR2-900)
            EVGA nVidia 9800GT 512MB
            Pioneer DVD-/+(R)W[DL] SATA
            WD Caviar Black 750GB
            Antec EarthWatts 650W
            Has a Thermaltake Ultra-120 with a single silent 120mm fan. Fire red case with single 120mm out.
            Grandma's:
            AMD Athlon 64 X2 6400+ Black 3.2GHz (Windsor)
            Gigabyte MA764-S2H
            2x 1GB OCZ DDR2-800
            nVidia Geforce 9400GT 1GB
            Pioneer IDE DVD-/+(R)W
            PC Power & Cooling Silencer 420W
            Seagate 7200.10 SATA 250GB
            Some Pink case with two 120mm fans. CPU has Xigmatek 92mm tower cooler.
            Unused/Kinda HPC:
            Intel Pentium 4 HT 3.2GHz
            Biostar P4M900-M4
            2x 1GB Corsair DDR2-800 (@ DDR2-667)
            nVidia Geforce G210
            Pioneer IDE 8x DVD-/+(R)W
            Lite-on IDE 52x CD-(R)W
            Seagate 7200.8 250GB SATA
            Seasonic S12II 520W
            Windows Vista Ultimate
            Has a copper thermaltake cooler on the cpu. Another generic biege case. 3x 80mm fans; one on the front another on the side in a hole I cut and one on the back.
            Router:
            AMD Athlon XP-M Barton "2400+" (200x12=2400MHz@1.8v)
            DFI NFII Ultra-AL (Capacitors Replaced)
            2x 512MB GEIL DDR-400
            ATi Radeon 9600SE
            PC Power & Cooling Silencer 410W
            Generic 10x DVD-ROM
            Seagate 7200.10 80GB IDE OS Drive
            Samsung Spinpoint 40GB IDE Proxy cache
            2x Intel PRO/100 NIC
            Gentoo Linux 10.1 Hardened
            Case is a pretty generic biege save for the vent in the side allowing the Thermaltake cooler to draw outside air. Additionally has two 80mm; in the front, out the back.
              The day job work horses.
              Full poly SX280, D820
                E5300 oc'ed @3,4ghz
                ASUS P5E X38 mod to RAMPAGE FORMULA bios
                4x512mb DDR2 ECC PC5300
                Galaxy 9800GX2
                ZEUS 850W -ST85ZF
                Samsung 19" LCD
                2x80GB raid0 2,5" seagate momentus 5400.3
                1,5TB WDC Grenn Storage
                  you realize that that motherboard has no ECC support. Your ram might have it, but its not being used
                    Neat! Now all I can say is that I bought a new Hp a few months back. Can't tell you what model is because its dark in here and I can't see the sticker on the side of it. Here is what I can tell you. Its has a four core AMD Phenom II CPU, and eights gigs of RAM with a 1.5 TB hard drive. There is also a card reader and a 16X DVD burner with two USB sound jacks on the front of the case. The monitor is a 25" Hp flat screen. The OS is windows home preium and I'm loving it so far....
                    Mark Twain
                    John Paul Jones
                    Rod Serling
                      My latest project;
                      Asus CULS2 with Pentium 3 866 Mhz
                      Maxtor 20 gig HDD, 256 meg ram
                      GE force 3 TI 200 4X AGP video card
                      Sound card, Network card, and USB2 card
                      Bestec ATX-300 12Z power supply (recapped 5vsb)
                      Ubuntu 11.04
                      Case?................what case?????
                      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                        and the purpose of this compute is what?
                        heh, want a GF4 ti4600, I got one > not free
                          The purpose of this computer is the same as the purpose for any computer!
                          I gave two dollars for this mother board to prevent it from going to the garbage. I checked my junkbox for other things to finish the project. Don't have a case yet....but maybe in the future. I hope to find a processor for it that is a little faster.
                          The power supply STANK and was full of brown (nicotine) dust. I took the case apart, removed the pc board and fan, and put all in a dishpan full of soapy dish water. Scrubbed it all, washed it off, dried it. Then took the fan apart, cleaned and oiled it. Capacitor C36, the usual culprit, was bloated. I replaced and relocated it on the other side of the heat sink. Power supply now works great. the GeForce video card works much better than the onboard video. For a ten year old system, it runs well with Ubuntu.
                          Some people enjoy getting dirty greasy working on old cars. Not me. I think I will just stick with an old computer project like this.
                            I had one and hated it... got it NOS, it never ran right. the 512mb limit was my biggest complaint... the VIA based boards were much better.
                            sigpic
                              C2D 4300, 1.8 GHz no overclock
                              ASUS P5K replaced failed chassis-signal FET, reflashed BIOS
                              2G of some cheap RAM(kingston) in 2 plates
                              1.5TB WD EARS-series(green) HDD
                              GeForce 8500(replaced old 6600 only for support of PureVideo)
                              Mandriva 2011.
                                Good on you Everell
                                I think my TUSL2-C with Tualatin 1400-S is the best thing since the proverbial
                                Got that one with faulty PS/2 ports which irritated me so much I was tempted to scrap it a few times, but eventually stumbled upon a fix which I documented in another thread
                                Asus's S370 boards were pretty much their last product before corporate greed got the better of them, and their cost shavers spoiled later offerings
                                Not sure on which criteria "VIA based boards were much better"
                                If you want something which works without hassles, Intel chipsets are the way to go
                                Or if you want a VIA chipset, why use a S370 processor ? - S462 all the way
                                better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                                  if you want a 1ghz p3 I can send you one haha
                                    Athlon II 245
                                    1gb DDR2 800 Mhz
                                    Inno3D GT 220 1gb GDDR2
                                    WD 500 gb 32mb cache
                                    700w Deluxe PSU (380w Real) - you cant go more crappy than this one
                                    19" ASUS monitor - got it broken with bad caps, recapped it and using it.
                                    Before this i was using a p3 but ram went bad and theres no way in hell I'll find SD RAM where i live.
                                    Guns don't solve problems. I'll take 12
                                      That appeared to be true with socket A boards, except for the divider, PCI and AGP OC roadblocks.
                                      And you often could get the same for less, compared to the Nvidia versions, the only con was the lack of locking the PCI and AGP!
                                      Because Asus introduced C.P.R., (CPU parameter recall) a feature that allows the motherboard to recover from an OC unstable enough to cause POST failure, without clearing the CMOS.
                                      Unfortunately, it appears that Asus cannot support C.P.R. with the nForce chipset. It appears that Asus ran into a technical problem with implementing it on the nForce (and nForce 2) chipset.
                                      And nForce 2 appeared to be more BIOS corruption prone than Via was at the time with the KT400, KT600 and KT880.
                                      ASRock B550 PG Velocita
                                      Ryzen 9 "Vermeer" 5900X
                                      16 GB AData XPG Spectrix D41
                                      Sapphire Nitro+ Radeon RX 6750 XT
                                      eVGA Supernova G3 750W
                                      Alienware AW3423DWF OLED
                                        My computers are very old.
                                        HP Pavilion ze1210
                                        AMD Athlon XP-M 1400+
                                        768MB of RAM (the computer won't POST with the maximum 1GB)
                                        S3 Twister K graphics
                                        Toshiba 60GB hard drive (failing)
                                        Toshiba combo drive (will only read audio CDs and DVD movies)
                                        Conexant AC-Link audio/modem combo
                                        Windows XP Home Edition SP3
                                        Worn-out keyboard
                                        Broken Synaptics touchpad (common failure)
                                        Dead battery (the computer shuts off immediately after unplugging the AC adapter)
                                        Gateway Solo 2500
                                        333MHz Intel Pentium II
                                        224MB of RAM
                                        NeoMagic MagicGraph 128XD graphics
                                        NeoMagic audio chip
                                        4GB IBM hard drive
                                        Toshiba DVD-ROM drive
                                        13" TFT display
                                        Windows 98 Second Edition
                                        Compaq Presario 2286
                                        AMD K6-2/500 (83MHz FSB, 6x multiplier)
                                        128MB of RAM (installing more makes the computer extremely slow)
                                        SiS 5598 graphics
                                        8GB Seagate hard drive
                                        Samsung SD-616 DVD-ROM drive (will not read one of my game discs)
                                        ESS ES1869 audio
                                        Hipro 75W power supply
                                        Sony CPD-15SX1 15" CRT monitor
                                        Compaq Easy Access keyboard
                                        Logitech 2-button mouse (no scroll wheel)
                                        Windows 98 Gold (first edition)
                                          what games could you possibly trying to play on a K62 500?
                                          should run crysis with that awesome video card
