Fixing a broken W10 disk remotely
  • Nevillet
    • Sep 2019
    • 272
    • United Kingdom
    Hi All,
    I am trying to fix a friends PC that originally had W7 and then was 'upgraded' to W10. It now wont run properly. I have tried repairing it by Windows recovery but it just gets stuck and hangs. Booting from W10 installation disc also hangs.
    On the same PC I have now installed W10 on a formated HD and have connected the damaged disc which now appears as F:
    Is there a way I can repair the original HD W10 installation remotely in this configuration?
    If so what would this technique be called?
    Many thanks
  • petehall347
    • Jan 2015
    • 4450
    • United Kingdom
    Re: Fixing a broken W10 disk remotely
    dont know about doing it remotely but i would try a boot repair first .. something like this one ... https://www.majorgeeks.com/files/det...sk_64_bit.html
      • 31294
      like this:
      • diif
        • Feb 2014
        • 6978
        • England
        It might be possible to fix remotely, if you know what the problem is.
        "Won't run properly" gives no clue as to the issue.
        From experience you'll be better off copying over his files and installing 10 from scratch.
        • Nevillet
          • Sep 2019
          • 272
          • United Kingdom
          I've downloaded and am running the boot repair application disk from MajorGeeks.
          The message on the screen is:
          'creating a bootinfo summery this may take several minutes'
          It's been running for several hours.
          My first thought was to copy off the user data and format and reload W10 but it reports that the disk is encrypted.
          Using a spare HD ive loaded a fresh version of W10 and created a admin user account using the same name and password as the owner. I've then attached the original HD which has mounted as F:. When I browse F:\users\ and try and copy the directory to the C: drive I get a message: 'You need to provide administrator permission to copy this folder'
          • diif
            • Feb 2014
            • 6978
            • England
            You possibly need to take ownership of the files you want to copy before you copy them.
            • Nevillet
              • Sep 2019
              • 272
              • United Kingdom
              Sorry, how do I do that?
                • 22209
                Put the original drive on a different SATA port and unplug the other drive.Boot from the win10 install disk again and see if it gets any further.On the next screen click on select repair then troubleshoot
                • Nevillet
                  • Sep 2019
                  • 272
                  • United Kingdom
                  I ran the boot repair app once again and it reported that it had fixed the problem.
                  I rebooted the original disc and ended up with the same issue where I can log in using an administrator account.
                  The desktop appears along with the message below:
                  If I click the OK in the message it just repeats.
                  Clicking on the Start button does nothing. Same with the task bar search box.
                  The only way I can shut down the PC is via CTRL+ALT+DEL
                  Tomorrow I try repairing the HD from the W10 installation disc.
                  AAMOI why the different SATA port?
                  • petehall347
                    • Jan 2015
                    • 4450
                    • United Kingdom
                    https://www.wintips.org/fix-windows-...in-windows-10/
                    • Nevillet
                      • Sep 2019
                      • 272
                      • United Kingdom
                      OK I think i'm getting there, I managed to replace the missing Desktop folder.
                      I can now navigate to the user files and copy them off. The Windows install is pretty crippled so once all the files are copied off i'll format and reinstall W10.
                      Many thanks to all.
                      • petehall347
                        • Jan 2015
                        • 4450
                        • United Kingdom
                        well done
                        • Nevillet
                          • Sep 2019
                          • 272
                          • United Kingdom
                          Cheers guys.
                          I couldn't have got there without your help.
                          Sincere thanks.
                            • Jul 2011
                            • 6070
                            Many thanks to all.
                            Was this from an update or malware or were you hacked or user error or something else
                            • brethin
                              • Dec 2008
                              • 1907
                              It's a common issue when fixing a friend's computer, see his original post.
                              • welp
                                PS5 Disk Tray issues.
                                by welp
                                I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
                                Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
                                Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
                                So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
                                With that knowledge I preceded to check all the fuses for the 12v rail on the main...
                                12-19-2024, 02:04 PM
                              • DynaxSC
                                ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                                by DynaxSC
                                I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                                Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                                Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                                The behaviour is also really very strange, i.e.:
                                • The disk shows always up in BIOS - so it is recognized, so far so good
                                • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                                02-23-2025, 01:33 PM
                              • chth96
                                Is it possible bridging tiny broken trace
                                by chth96
                                When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                                cutting tiny trace.
                                This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                                Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                                But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                                12-03-2022, 11:32 PM
                              • Stanley1843
                                Windows 11 disk no boot
                                by Stanley1843
                                I tried to install Linux on a secondary disk in my PC and after a failed Linux grub installation my PC didn't boot in Windows 11. I saw the message (Reboot and select a proper Boot device).
                                I made a bootable USB windows 11 and I run the below commands on the cmd but with no succeed.
                                DISM /Online /Cleanup-image /Restorehealth
                                The DISM.... command shows me the error 87.
                                sfc /scannow
                                chkdsk
                                bootrec /FixBoot
                                bootrec /ScanOs
                                bootrec /RebuildBcd
                                For some reason it writes(Total identified installations 0) like there no...
                                10-18-2025, 04:41 AM
                              • huzo
                                Lenovo ideapad 1 not recognizing NVME
                                by huzo
                                Model is ideapad 1 15amn7 ,the board is 5B21J30218 HLS1C_HLS1D LA-L502P with ryzen 5 7th gen... The laptop came to me for broken hinges and displaying only the backlight on the screen...i repaired the hinges and tried booting and all i got was backlight on the screen,but caps lock worked, so i figured the screen or the flat cable was bad, i had the same laptop and connected the cable and screen from the other and the screen acted same, and original lcd works on the other laptop...so then i started removing wifi card and nvme and it started showing picture and i figured out the nvme was blocking...
                                09-04-2025, 01:08 AM
