Tell me about mixing ECC
  • Logistics
    • Apr 2007
    • 721
    So I'm acquiring an old server with a Supermicro X10DAX board using dual E5-2690 v3's. The previous owner had four 16GB RDIMM's in it, which are all Samsung 2133 CAS15's. I want to have ALL memory channels running so I need to purchase another four sticks. But most of what I'm finding is more along the lines of 2400 CAS17. My understanding of basic systems is the system will run at the higher latency sticks' speed, but I don't know if these servers will be happy with that. It's not that I can't get exactly the same part number sticks, it's just that finding them for a good price is less likely than finding the 2400's.
    What are my options? The system is currently loaded with M393A2G40DB0-CPB sticks.
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5056
    • US
    Re: Tell me about mixing ECC
    Motherboards like that can be iffy with memory sticks
    Your title said about mixing ECC, when I believe all sticks on these boards have to be REG ECC
    the Samsungs are on SuperMicro's compatibility list.
    https://www.supermicro.com/en/suppor...d=0&cpu=others
    I'm not saying they won't work, but it's iffy. They will not work if they are not REG ECC
    • Logistics
      • Apr 2007
      • 721
      The other ones I'm looking at are RDIMM's, they just aren't the same frequency and CAS latency. I know not to mix RDIMM's and LRDIMM's.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5056
        • US
        It might work. TC and ratdude should be the one that has experience with supermicro boards.
        • Per Hansson
          • Jul 2005
          • 5897
          • Sweden
          It can work, but there is no way to know without testing.
          If it was my money and it was just a little bit more expensive I'd go with the identical memory modules.
          • Logistics
            • Apr 2007
            • 721
            Sage advice! I'm more interested in rock solid stability and longevity. However, after some conversations and reading up on the Web, it appears that the cases in which running Quad-Channel will actually yield an increase in performance are nothing I will ever do. I see people being proud of the fact that they are running in full Quad-channel on a single processor board, but I see no benchmarks for desktop software that show an increase in performance. It appears that only some obscure server-only software would make use of having to move so much data that Quad-channel actually matters.
            So long story short, I'll just leave it the way it is unless someone has some wisdom they can afford me to convince me to use all channels.
            • SluggerB
              • Aug 2020
              • 747
              • US
              I've been looking at memory for my new retro build, and basically what I've seen is 2400 costs more $$ than it is worth, 2133 is rare/can't find it for sale, 1833 RAM seems to be problematic and many users complain of instability or the RAM just running at 1600 anyway. 1600 RAM seems to be rock solid and the right price, so I bought all 1600. Does that seem about right?
              • Logistics
                • Apr 2007
                • 721
                I think you're talking about DDR3, which would be difficult find in those speeds. I'm speaking if 2133 DDR4, which is pretty basic and plentiful.
