Here is a place to store the latest issues you are dealing with and their solutions. Everybody contribute (just brief stuff is ok)
Bug/Issue Reports and Solutions
Tags: None
Re: Bug/Issue Reports and Solutions
McAfee enterprise 8 - (win2k) System log in event viewer shows instances of "A driver packet received from the i/o system was invalid". I researched this and found it was noted to be due to mcafee. No solution yet, look for other vendor.
Symantec Corporate 10 - (win2k) system takes a long time to shut down, waiting at "saving your settings". event viewer shows "windows cannot unload your registry file. Appears to be due to symantec 10. avoid. -
LOL Will, for buggy software, we need a dedicated forum for that........... I could go on and on!
<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
Norton Systemworks/Internet Security/Antivirus in its current state reminds me of the good old Nuts & Bolts days. You would fixup a customers computer, have it running excellent, they pick it up, stop by walmart and buy Nuts & Bolts, install it and screw up the computer in less than 12 hours.Comment
yes it is very disappointing. even more so to see mcafee to have big probs also. i was reading one thread where a sysadmin was trying to deal with this issue on their servers and workstations. they had reinstalled the servers several times. poor guys. yep they had installed symantec 10. (but with 2003, 2004, 9 we are ok, why to screw up now)
anyway i say to keep this thread, i will dump some stuff from time to time here and hope it gets googled and helps some poor admin somewhere. Please take time to contribute and save our evenings and weekends sweating in the server roomLast edited by willawake; 08-20-2005, 01:12 PM.Comment
Issue but No Solution (Yet)
I've seen several references to MemTest86 in the forum posts. I had never tried this after recapping my Abit BE6-II, so I searched (Yahoo) the Internet for it, and found both MemTest86 and MemTest86+. Downloaded 86+, ran it on the BE6-II (Pentium III, 700 MHz, not overclocked), and promptly got a General Protection Fault (same place, four times in a row, machine powered off each time in between). Just for grins, ran it on the new Dell (Pentium 4, 2.8 GHz, not overclocked), and also got a GPF, but in a different place! So then I downloaded MemTest86 (not +) and ran it with no problems on either machine. Both MemTest86 and 86+ run just fine on the Compaqs at work. How do you distinguish between bad components and bad software?Comment
Umm? I have no clue what you downloaded, but no version of memtest86(+ or not) that I'm aware of is meant to be used within windows.
--RandyComment
MemTest86 3.2 Release from www.memtest86.comOriginally posted by bushytailsUmm? I have no clue what you downloaded, but no version of memtest86(+ or not) that I'm aware of is meant to be used within windows.
--Randy
MemTest86+ V1.60 from www.memtest.org
Neither one was used from within Windows. I downloaded the appropriate version for a floppy disk, made the floppy, and "booted" the computer with that. Windows doesn't even recognize the floppy as being formatted (on any of the machines), so they do something strange there.Comment
That's weird... haven't had any experience w/86+ so I couldn't help you there. Memtest86 3.2 from memtest86.com works fine for me. I also dunno how a gpf cna happen outside of Windows.
No CPUID program whether it was crystalcpuid, cbid, cpu-z, or wcpuid could install on my old win98 Duron sys. Why? doesn't make any sense to me....Comment
was struggling this morning to get the Sony Vaio PCGA-CD51 pcmcia attached cd rom drive to work on a Sony Vaio PCG-C1XD to install win98. Forgot to copy the win98 directory to the HDD second partition before format...
anyway here is the solution. not much info about it on the net.
autoexec.bat should look like this
a:\MSCDEX.EXE /D:cdrom
config.sys should look like this
DEVICE=a:\HIMEM.SYS
DEVICE=a:\VA16365.SYS
DEVICE=a:\VA16CD.SYS /D:cdrom
you need the files VA16365.SYS and VA16CD.SYS from Sony.
http://www.vaio-link.com/common/accd...sp?ID=275&L=uk
it is the "Boot Disk to use for PCGA-CD5x models"
direct link on ftp
ftp://ftp.vaio-link.com/pub/vaio/Opt...m_bootdisk.exe
provides the files VA16365.SYS VA16CD.SYS VA16CLI.SYS it is not a boot disk really, just some stuff to make your own boot disk.
here is also the readme from the "Boot Disk" but its not necessary to use this below part, just the stuff above. Hope this helps someone, i was suprised when it didnt boot from the cd automatically. also Sony has a few non working solutions on their site. enjoy.
VA16CLI.SYS Card Service Client driver
VA16365.SYS Intel82365 Compatible Socket Point enabler
VA16CD.SYS CD-ROM Device driver
[Usage]
Copy these files and edit CONFIG.SYS to include following
lines;
DEVICE=<Card service manager>
DEVICE=<Path>\VA16CLI.SYS
DEVICE=<Path>\VA16CD.SYS /D:<DEVICE NAME>
or
DEVICE=<Path>\VA16365.SYS
(no Card service manager required)
[Options for VA16CLI.SYS]
/PORT=###
180, 190, 1A0
Default: 180
/INT=#
3, 5, 6, A, B, E, F
Default: Unassigned
/MMIO
Memory map transfer mode
/PIO32
32bit PIO mode
/PIO16
16bit PIO mode
Default: 32bit PIO mode
/NS
Standardize PCIC controller transfer speed
Default: High speed
/PCICADR=####
PCIC controller port address (4 digit)
Default: 03E0(3E0H)
[Options for VA16365.SYS]
/PORT=###
180, 190, 1A0
Default: 180
/INT=#
3, 5, 6, A, B, E, F
Default: Unassigned
/MMIO
/PIO32
32bit PIO mode
/PIO16
16bit PIO mode
/NS
Default: High speed
/MEM=####
Memory segment address (4 digit)
Default: CE00(CE000H)
/I365RST
Compulsory reset of PCIC controller
Default: Do not reset
----------------------------------------Last edited by willawake; 02-15-2007, 05:02 AM.Comment
Anyone interested in Memtest should download themselves a copy of the "Ultimate Boot CD", which includes several MemTest versions along with many other useful utilities for testing hardware.Originally posted by AK0RMemTest86 3.2 Release from www.memtest86.com
http://www.ultimatebootcd.com/
Along with WinPE, it's one of my favorites.Comment
i have always relied on doc memory, it helped me out a few times finding bad sticks. also western digital diagnostics is a honest program also.Comment
Years ago I stumbled onto the Steven Gibbs Research site where he was offering the Shields Up appelet for monitoring open or stealthed ports.
Ever since I found his AVG antivirus program it has kept me and mine safe.
No infections ever. I could never stand Peter Nortons smug face on that box, and also don't like the perfarmance hit of Mcafee.
I'm just sayin.JimComment
Sony vaio PCG-Z505R with a PCGA-51CD, but the same issue!
I just read your thread about the trouble you had with your sony vaio.
I reciently purchased a PCG-Z505R, with the USB floppy drive and the pcga-cd51 pcmcia cd drive.
My problem sounds like what you encountered. The HD is formatted, but has no OS.
I have never done anything like you described,
could you please walk me through the proceedure?
I am guessing that I should make a windows 98 start disk, add the downloaded files, and edit the bat file in notepad?
If you could help me out I'd greatly appreciate it, I have been online for about 8 hours just looking for this information, and just found this forum.
Cheers!
Erick
aka Dr. Pepper
P.S. I tried to send a pm, but it didn't show up in my out box. Im glad I joined the forum, looks like a great place!Comment
This is a Win2000 bug. You can permanently fix it using Microsoft's UPHClean utility. I installed this on my Win2000 system, instant fix of the problem.Originally posted by willawakeSymantec Corporate 10 - (win2k) system takes a long time to shut down, waiting at "saving your settings". event viewer shows "windows cannot unload your registry file. Appears to be due to symantec 10. avoid.Comment
good one. i just got a newer version so i will check if its still doing it or use your fix. but as far as it being a win2k problem and not a symantec one, i disagree.
ok it does not happen on 10.1.5Last edited by willawake; 02-15-2007, 09:36 AM.Comment
My rule of thumb is never installing something from Norton or Symantec on a system runing any OS >Win98
Way to mutch very timeconsuming and totaly anoying and avoidable problems, as they don`t get it, that no one should dig that deep into a MS OS. It is insane to anchor a software that deep inside of Windows OS, that any small update from MS can make it a nighmare of a mess.
Not to mention that absolut mess wich any of those progs leave in the registry.....absolutely not something i would tolerate at any system i would have to care fore.
I assume the only reason why they are still in busines is their name from the good old day`s.Comment
symantec corporate is generally ok, except for that problem above. i definitely dont recommend to install their internet security versions though. still i tried AVG once and then got the first virus infection i had for a long time.
what do you use?Comment
by rouninHi everyone,
I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
🛠 Original Issue
The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
⚠️ New Problem: One USB-C Port Only Works in One Orientation... -
by ugamazingI have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre... -
by shahnldGood day Experts
I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core... -
by ahmarzoHave a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
Help me to diagnose this issue as there is no shortage in the inputs MOSFET -
by elmarkHP Pavilion 15-CW1002UA
S/N 5CD0251CBC
P/N 7KE54EA
Hello guys!
I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
It powers on OK and has no other issues except the following:- CAPS LOCK does not work at all
- Fn button toggles Flight Mode
- When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
- (with SHIFT pressed: 't%' and 'y^' respectively)
but when I press and hold...06-27-2025, 01:10 AM - Loading...
