Re: macOS Big SUR changed my life
I heard about it corrupting the spi rom or something on older machines, I also have a 1466 2014 Macbook Air and kept it on catalina for fear the update might bork it. Hope you find a solution to the problem.
Yeah my mac mini 2018 didn't have it, they started to remove it from models starting with the 2016 MBP, then added it back with big sur.Leave a comment:
wut i have a 2012 mbp 13inch on catalina and the startup chime was always there were there apple devices that didnt have this from factory and big sur added it back ?Leave a comment:
Hello to all,
I have Macbook Air 1466 early 2015 and I tried to update macOS Catalina to Big Sur. After that when laptop starts there is a very loud fan noise like working on full speed and the screen is completely dark. I have tried SMC and NVRAM reset combinations but that didn't solve the problem.
So I can safely say that macOS Big Sur changed my life also.
Since there is a fan noise on the start, the motherboard is not dead. Did anyone have similar issues.Leave a comment:
Because, even when Macs had been around for a good amount of time, The Vermont Achievement Center, only had some Macs!
And rarer, was an IBM!
You actually had a better chance of spotting an Apple III in a classroom! Wow!
Then when I went to Crotched Mountain Rehabilitation Center, in Greenfield, New Hampshire, starting on July 5, 1994, it was vice-versa, mostly PCs with Windows.
I can't recall seeing an Apple III or an Apple II, in fact!
Where there wasn't a PC for a computer, there usually was a Mac.Last edited by RJARRRPCGP; 11-18-2020, 06:41 PM.Leave a comment:
Oh boy, looks like I upgraded too soon.Louis Rossmann said the new OS spies on you. https://www.youtube.com/watch?v=aS2lJNQn3NA
https://www.youtube.com/watch?v=9tQVQUd94AwLeave a comment:
...and I thought Windows 10 was bad... Thanks for proving me wrong, Apple!!Leave a comment:
Might wanna stay clear of this update if you have a 2013 or 2014 MacBook Pro, ouch!
https://www.techspot.com/news/87610-...rick-2013.htmlLeave a comment:
incidentally, who wants to bet if this osx update has "contact tracing" hidden in it?Leave a comment:
Both of my main systems are Ryzens.
The second one is a Ryzen 5 2600 on an AsRock A320M/ac motherboard.Leave a comment:
Some people are left in the cold, because the computer makers refused to offer a BIOS with an updated CSME for PCs with a 9th-gen Core i series and earlier!Leave a comment:
at least m$ has ways to stop or severely halt telemetry collection
https://blogs.systweak.com/how-to-di...in-windows-10/
I don't believe there is any way to disable it in mosLeave a comment:
if you watched the video, apple was already doing it - possibly for years.
the update just puts a stop to you blocking it.
IMO apple turned to the darkside when they left Motorola and started using Intel.
and that's another thing, all these intel based machines have the ME filth in them - that's as bad as it could get.
the ME is a seperate microcontroller that can acess your harddrives, ram and networking even in sleepmode.
maybe that's why the latest windows versions dont like to do a proper shutdown - just a thought!!Last edited by stj; 11-15-2020, 05:52 AM.Leave a comment:
wow this takes big brother spying to a whole new level now if apple does it also on mac os! first we had m$ and their win10 telemetry bs and now apple is on the same bandwagon as well!ah well... all your life and data are belong to us!
Macbook A1398 - had repeating loop of startup chime with no actual boot. Just startup chime, then restart, start up chime, then restart, etc. I pulled the battery and cleared BIOS. It will now power up, fans on, CPU warming, but no startup chime and no boot. I reflashed the BIOS chip but the same thing happening. Where should I go from here?06-14-2023, 11:45 AM
by valvashonYet another 19" TV here in the maintenance shop. This one belongs to my 95 year old mom so I'd really like to get it fixed for her.
Samsung UN19F4000AF. Back home for a week, I found this TV in her master bathroom unplugged and not connected to anything. Would start to power up and make about half of the Samsung startup chime, then shut back down.
Brought it back home with me but after having a quick look it no longer tries to start up and does not have the red LED lit in the IR receiver/switch thing.
Power supply is good, tested it on an exact same... -
Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....1 Photo
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by duwaneHi All.
Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
The issue:
Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,... - Loading...
