Computer seems hyper-sensitive to power outages
+ More Options
Posts
  • seanc
    • Nov 2008
    • 1319
    Re: Computer seems hyper-sensitive to power outages
    The upshot of always using Microsoft drivers, or changing them, is that it's easier to move the HDD to a motherboard with a different chipset.
    I'd put in another board with a chipset other than nVidia or VIA, perhaps SiS?
      • 30963
      SiS = JUNK.
      • seanc
        • Nov 2008
        • 1319
        Well I'm sure Intel don't have AMD boards with their chipset on, I hate nVidia and VIA chipsets, what else does that leave us?
        I don't touch the AMD side of the fence, so am out of practice with any other offerings.
        • weirdlookinguy
          • Sep 2007
          • 1638
          ATI chipset boards.
          • Wizard
            • Mar 2008
            • 2296
            Or Intel chipset based boards.
            This is why I said: AMD chipset or Intel chipset. AMD bought ATI and AMD developed futhur on ATI chipsets into much better AMD chipsets like 790, 785 etc.
            Cheers, Wizard
            • seanc
              • Nov 2008
              • 1319
              #26
              I always use boards with Intel chipsets - but in the case of finding a replacement for his AM2 board, I didn't think this was a viable option.
              • washu
                • Jul 2009
                • 310
                #27
                If you need an AM2 board then something with an ATI 7XX chipset is probably the best.
                • Wizard
                  • Mar 2008
                  • 2296
                  #28
                  Correct!! Still can buy AM2+ boards. These uses DDR2 only. Get 780G AM2+ board, this will handle AM2 cpu too. I checked.
                  Also this is excellent path to move up to AM3 CPU when ready to spend on new CPU.
                  Cheers, Wizard
                  • mosfetratus
                    macbook A2918, orange light off when shut off
                    by mosfetratus
                    When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
                    Works with battery and charges, but when i shut off i get this problem.
                    It had liquid spill. Board has no corrosion, keyboard is working, power button...
                    05-31-2024, 03:34 AM
                  • wolf1976
                    philips 42pfl3506 working for few seconds and after shut down
                    by wolf1976
                    hi
                    i have the above tv it turns on for few seconds and after shut down
                    can you suggest me what can be cause this problem ?
                    05-25-2024, 12:18 PM
                  • GTAVC16
                    Alienware 18, Nvidia GTX 880m presumably shorted
                    by GTAVC16
                    Hi guys!
                    I'm in need of some support so I can try to fix my laptop/gpu.
                    While I am a cerified automotive mechatronic, I have only basic understanding of electronics repair and identification.
                    I'd like to identify the issue and replace the specific component myself to learn about electronics and expand my skills a bit.
                    No better time than now, when my laptop, Alienware 18 from 2013, shut down when playing and refused to start again.
                    I know about electric diagnostics in and about cars, but I've never dabbled with electronics.
                    However, I know...
                    08-20-2023, 05:39 AM
                  • ktmmotocross
                    Lenovo B50-70 all power ok but still shut off by 3seconds
                    by ktmmotocross
                    Hello
                    Have this Lenovo B50-70 LA-B091P that strart with all voltages but shut down by about 3 seconds. all voltages is ok, SYS_PWROK is 3.3V, flashed bios but still the same
                    It have amd gpu, so there can be problem. Any hint? even dis to uma will be good if can be done
                    Lenovo B50-70 80EW
                    LA-B091P
                    sn - MP07V4zp...
                    03-02-2024, 07:27 AM
                  • Bimad99
                    No SLP_S5 signal - SAMSUNG NP350V5C shut down while booting
                    by Bimad99
                    I have this case a SAMSUNG NP350V5C, board number is QCLA4 LA-8861P Rev : 2.0.
                    the laptop was dead because of triggered 3.3v and 5v supplies, the problem solved and the laptop fired up, I tried to boot to Linux at first but the laptop completely shuts off while booting all the times i try and it doesn't turn on only after couple hours, So i decided to change the RAM and install windows 10, the installation was successful but when it was booting to windows for the first time it shut down again, But this time it is refusing to turn on even after waiting for hours....
                    08-10-2023, 03:42 AM
