philips 42pfl3506 working for few seconds and after shut down
  • wolf1976
    • Oct 2023
    • 113
    • Ελλάδα
    hi
    i have the above tv it turns on for few seconds and after shut down
    can you suggest me what can be cause this problem ?
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Post clear photos of the power supply.
    • lotas
      • Jan 2016
      • 4743
      • Russia
      Replace the PWM in the power supply (common fault). Optocouplers also suffer.​
      • wolf1976
        • Oct 2023
        • 113
        • Ελλάδα
        thanks sir lotas i replaced only pwm and its ok without to replace the optocouplers
        • modtool
          HP x360 Chromebook 14A-CA, DA00GIMB6H0 REV:H, flooded, restored, slow and stuck in tablet mode
          by modtool
          Dear colleagues,
          I've entered the repair of the chromebook machines just one month ago and I've found some significant differences from the classic laptops or macbooks, so I'm searching some advices.
          The owner of this chromebook gave it to me after it has been left flooded by water for almost a week, so chances of repair were not so high, the mainboard was oxidyzed in many spots but I made a nice cleaning, resoldering and component replaging work and now it is almost working.
          Among other things I've cleaned many spots from oxyds, reballed CPU, EMMC, EC, replaced...
          05-07-2025, 06:10 AM
        • alpersen
          Philips 40 PUK6809/12 Backlight turns off after 10-20 seconds
          by alpersen
          Hello
          Mother called and said TV turns off after switching on. So after turning on Philips logo shows and probably 10-20 seconds image disappears, sat receiver is connected and sound is heard from source. So I turned on my phones light and I can see the image it seems backlight was off after some time. I dis assembled the cover hoping to see a distinc cap blown or leakage. Here are photos I took (I was after 22:00 pm and maybe some of them are dark). Should I order and change caps on the power circuit or what would you recommend? Thanks...
          07-25-2024, 12:50 AM
        • Rayblaster
          HP RP7 RP7800 from 2012/2013 worst fault - has "character"
          by Rayblaster
          Hello friends, I've got a nice toy to play with - it is an HP RP7800 All-in-one POS system. I got it for free and it has one problem - it turns on very rarely, and just for a few seconds. After that it dies and doesn't come on if I don't leave it unplugged for at least 2 hours. I've repaired motherboards before, this is not my first one, but problem with these types of faults is that everything you check on the board will usually be fine. This is the case for me here.
          I dissassembled it completely, and got my hands on the motherboard. Model No. is PIQ67H/Higgins 11047-I 48.3GD02.011....
          12-30-2024, 06:28 PM
        • zyklop
          Philips Soundbar TAB8507B/10 stopped working
          by zyklop
          Helllo everybody....
          i have this soundbar to repair for a friend. Its finally 2 years and seldom used but already broken.
          Inbetween it has one time started, but no more yet.
          Is anybody who has schetatic or service maual ?!
          Power supply seems to be ok and has stable 24V DC. No control line or somthing else...........
          No thermal hotspots or something else controlled with thermal imaging cam.
          No reaction on remote control (function ok, can see it while glow into mobile-camera)
          No shorts to detect.
          ALso tested all reset procederes...
          07-07-2025, 05:08 AM
        • Ierwin
          Philips 58PUS7805 Menu working but no/weird picture from video sources
          by Ierwin
          I got a 58pus7805 that shows some weird behavior.
          The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
          However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
          I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
          I managed to install the latest official firmware by holding the control button while plugging...
          03-10-2024, 12:50 PM
