No SLP_S5 signal - SAMSUNG NP350V5C shut down while booting
  • Bimad99
    • Jun 2023
    • 37
    • Algeria
    I have this case a SAMSUNG NP350V5C, board number is QCLA4 LA-8861P Rev : 2.0.
    the laptop was dead because of triggered 3.3v and 5v supplies, the problem solved and the laptop fired up, I tried to boot to Linux at first but the laptop completely shuts off while booting all the times i try and it doesn't turn on only after couple hours, So i decided to change the RAM and install windows 10, the installation was successful but when it was booting to windows for the first time it shut down again, But this time it is refusing to turn on even after waiting for hours.
    I checked the board all voltages are okay, When pressing power button the SIO sends PWRBTN# SIGNAL to the PCH, the PCH gets the signal and the supply voltages and sends back the clock signal to the SIO but no SLP_S5 or S4 or S3 signals. there is no change on those signals.
    Any help i really appreciate it and thnx in advance.
    [Mod. Edit-Vesko356] Schematic ---> https://www.badcaps.net/forum/showth...12#post1255012
    Last edited by Vesko356; 08-10-2023, 03:50 AM. Reason: Attached schematic removed and replaced with link.
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: No SLP_S5 signal - SAMSUNG NP350V5C shut down while booting
    Originally posted by Bimad99
    I have this case a SAMSUNG NP350V5C...
    Do not attach laptop schematic and/or BV in this section please!
    Schematic Requests ONLY!
    https://www.badcaps.net/forum/forumdisplay.php?f=41
    Reminder: rules and organization of this section
    https://www.badcaps.net/forum/showthread.php?t=117483
    If you request/offer BIOS/schematics/boardviews, please post in the appropriate subsection, and you can link to it in the troubleshooting topic.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • Bimad99
      • Jun 2023
      • 37
      • Algeria
      UPDATE :
      when i short RTCVCC to the ground the laptop turns on just normal.
      But if i try to boot to windows again it shuts off during the process.
      I tried flashing the main and sub bios chips as well as the EC but no luck.
        09-07-2024, 05:50 AM
      • Aeisens
        Samsung UE50RU7170 not booting /no picture
        by Aeisens
        Dear all,
        My issue is the following:
        Tv suddenly started to make Strange things and went out. After disconnecting power and restarting, it tried to start but failed. After each attempt it got worse and worse. Now only the Stdb light is on and it is not booting.
        I checked the power supply -> Backlight on when disconnected from mainboard, so I guess Power supply is ok.
        Additionally the upper right part of the main-board makes some whistling noise -> probably issue there and therefore issues with booting
        Question 1: Where should I start to...
        06-24-2025, 03:07 PM
        09-06-2024, 11:40 PM
        09-06-2024, 08:40 PM
