Relubing fans
    master hoarder
    • May 2008
    • 12175
    Re: Relubing fans
    Originally posted by kaniki
    2. The opposite side of the fan that the blades are on, there is usually a sticker down the middle of the fan. Remove it. It will usually just peel up from the edge. Don't expect to reuse it as they usually don't stick very well when reapplied.
    If you don't put too many finger prints on the sticker or the plastic where the sticker goes, it will stick just fine. I've reused quite a few stickers multiple times without any problems (the only ones that give me trouble are the paper ones, but those are rare).
    5. Once the clip is off, the fan blades should just slide or easily pull out. Once it is removed, clean everything off. I wipe everything down and if too bad, wash the fan blades with soap and water. Make sure that it is completely dry before you put it back together if you do get it wet.
    Washing the blades and plastic with water is fine, but don't get the stator (the metal pieces with the coils on them) wet! They will rust. Probably better to just use a moist cloth to wipe the blades/plastic and a dry one for the stator.
    Originally posted by Toasty
    Cleaning the shaft with a solvent and a rough cloth to remove any build up or discoloration.
    Excellent point! I do this to the shaft and the sleeve bearing as well and it definitely helps the fan spin more freely than before.
    Sometimes if the fan was stuck really badly, I use a small screwdriver to make scratches in the sleeve bearing parallel to the direction of the shaft (you can't really see any scratches, but they are there). After this I clean with a rough cloth and put oil. The scratches help the sleeve bearing to hold lubricant for a longer time and clean gunk that the solvents and rough cloth might have not gotten in the first place.
    I've had a fan that was hard to turn even after cleaning and oiling. The scratches made a world of a difference.
    To make them, you just take a small flat-head screwdriver, hold it with one of the sharp edges against the sleeve bearing, and make streaks parallel to the part where the shaft goes. Do this for the whole inner circumference of the sleeve bearing. Don't apply too much pressure on the screwdriver (you should feel only a bit of resistance).
    As for lubricant, I use regular motor oil only, and it usually works fine for a few years. I've also used regular grease before, but that dried up quickly. Maybe other kinds work better, but motor oil seems to work flawlessly every time.
    By the way, good job on the descriptions kaniki.
    I think there are also some videos on youtube on how to lubricate fans in case anyone is interested (I can't seem to find them right now, though).
    • kaniki
      • 514
      Re: Relubing fans
      First let me say thank you
      as foir the sticker part sticking.. I think it more comes down to how old the fan is then anything.. most fans that i usually have to do this to are not like 1 or 2 years old.. or if they have, they ar in a house of smokers or something like that.. and that tar in the air does make a big difference.
      As for the fan part getting wet. If you noticed, i put the wash the fan blades.. i never said anything about the core of the power part.. guess i should have put "Do not get the electrical part of the main body wet" in there. But for the fans.. wiping is fine and dandy, but again with the smokers part.. sometimes kinda hard to get them clean just by wiping the blades off. For me, if the blades are too bad, a quick spray of Westleys whitewall cleaner, let it sit for about a minute, rinse well, then dry it off. for the drying, i dry with something like a washcloth/towel and then either used canned air and let it sit for a spell or put in front of my heater for a bit. just to make sure that it is good and dry with no moisture left. I have done this many times and never had a problem yet.. If my fan blades were only needing water then i dont usually need to get them wet.. but in a smokers house.. dont see just water doing a lot..
      I looked up info on the net (youtube and websites) about oiling the fans.. most of what i found says to just take the sticker off, put a drop or two of oil in, put the sticker back on and then spin the fan a few rounds. I guess that would work if the fan was just starting to run a little rough but by the time i get them, either things are so crudded up that that is just not a feasible thing to do.. well, not if you want it to last more then a month. and if in a smokers house.. there is going to be so much tar in there that it will make more of a sludge in there then a lube once the oil gets inside.
        master hoarder
        • May 2008
        • 12175
        Re: Relubing fans
        I guess I've been lucky not to get any "smoked" fans .
        And yes, most websites only mention to take off the sticker and put oil, so usually they're not a great source of details on this matter. They are okay for visuals, though.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: Relubing fans
          You can use good ole rubber cement to put the stickers back on.
          If you dunno what it is it's that 'stuff' that comes on some store packaging [to hold labels or whatever on plastic] that looks like clear silicon sealer but acts like sticky snot.
          Comes in a bottle with a brush.
          Mann-Made Global Warming.
          - Dr Seuss
          • NxB
            • Feb 2009
            • 1595
            Re: Relubing fans
            I just injected CLP into my top case fan with a hypodermic syringe and it seems to have done the trick. Before it would make noise.
            • sLowEnd
              • Aug 2008
              • 33
              #26
              Re: Relubing fans
              Originally posted by c_hegge
              If it's a case fan, you can replace it with a better one. If it's a video card fan, it can be difficult to find an appropriate replacment, so that's when you oil it.
              Ghetto mods for the win.
              • kaniki
                • 514
                #27
                Re: Relubing fans
                for the mod.. kinda disturbing.. but i have seen much worse.. I once saw a fan put on a heatsink that was only held on by 2 screws (could not put the other 2 in, no room to mount as it was the wrong size).. if that was not bad enough, the fan was not even screwed down snug.. it was loose and flapping in the breeze..
                Originally posted by PCBONEZ
                ...that looks like clear silicon sealer but acts like sticky snot.
                what a wonderful description..
                  master hoarder
                  • May 2008
                  • 12175
                  #28
                  Re: Relubing fans
                  ahem...
                  http://thereifixedit.com/2009/12/01/...-acted-screwy/
                  I think you're going to like my computers as well too - they all have at least one ghetto fan mod somewhere (though they're not nearly as bad as the one above).
                  I have a Dell that my family uses here - well, the Northbridge gets really hot so I just put a 40mm fan on it with two random screws I found (they do match and are of proper size). It fits the heatsink perfectly, works well, and is fairly firm on there.
                  I have two other computers that have similar mods (both have hot-running video cards with passive coolers).
                  And my latest mod (I still haven't taken pictures of it yet):
                  https://www.badcaps.net/forum/showpo...5&postcount=33
                  Sorry for going so off-topic.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Re: Relubing fans
                    uh, globe fans suck, FYI.
                    sigpic
                    (Insert witty quote here)
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3113
                      Re: Relubing fans
                      Ehh, they are pretty good. They are about like adda. They have been used in enermax's, some FSP's, ATNG, sirtec, even some delta's I have seen have them.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Re: Relubing fans
                        and iirc addas are prone to seizing?
                        sigpic
                        • ss627
                          Super Member
                          • Mar 2008
                          • 52
                          #32
                          Re: Relubing fans
                          I hate adda fans. While they look well built, I've had so many cheap sleeve fans that worked without noise issues for much longer. I tend to use a lot of the cheap yate loon and coolermaster fans since I haven't experienced a single problem with them so far.
                          • kaniki
                            • 514
                            #33
                            Re: Relubing fans
                            Originally posted by momaka
                            ahem...
                            actually, i have seen 1 that was very close to that.. but at least that one was on snug /tight.. and not in danger of falling off..
                            OK OK.. how about this.. i had a computer over a few months back.. this is the condition it had shown up in.. first, only 3 screws holding the MB in place.. the rest, well... i think fell out.. the 3 that were there were very loose.. as in the MB was actually moving back and forth while in the case, cross threaded screws for the hard drive, only had 1 screw in on the right side to hold it in place, but dont worry if it falls out, there was a second one in the spar slot that does nothing (why he did not put it in the 2nd mount screw slot, i have no idea), wrong size and thread screws in the CD-ROM, screws floating around in the case (think came out of the motherboard), the mounting spacers for the MB, none were tight, as in 2 or 3 threads out frokm being all the way down, fan on the vid card was screaming, had the fan in the case pulling air in from the back while the power supply fan was pushing it out of the back to make like a small vortex, ram was bunk (probably overheated), hard drive was just previously replaced (was overheated), and found out that the owner had the PC sitting on top of the heater duct.. The case had a hack job for mounting the fan in it too.. looked like it was cut out with a set of tin snips.. very rough and very sharp edges.. There were a couple other things but can not remember off the top of my head... Scary thing is he could not figure out why the PC kept having problems.. Its like Gee, I wonder... IDIOT!!!
                            Now that was a computer from hell.... Glad i dont run into people like him very often..
                            • cheese007
                              • May 2009
                              • 85
                              #34
                              Re: Relubing fans
                              I have a Pentium II with a couple of 80MM fans attached to the heatsink with one screw each. They also happen to hang off the edge and cool my memory and video card. :P
                              • emil_t
                                RTX3090 working fine but fans not spinning
                                by emil_t
                                Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                04-12-2024, 06:54 AM
                              • b-slayer
                                Asus Strix-G15-G513RM fans don't work
                                by b-slayer
                                I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
                                The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
                                (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
                                (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
                                ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
                                09-04-2025, 04:58 AM
                              • Delicieuxz
                                I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
                                by Delicieuxz
                                I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
                                Here's an audio clip of the sound coming from my speakers:
                                https://vocaroo.com/16HaryHwTx78
                                I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
                                11-15-2023, 09:50 PM
                              • JayPoorJay
                                Hot Water Rad - A Few ECU Fans and a Timer Switch
                                by JayPoorJay
                                Good Afternoon, Good People.
                                I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
                                I REALLY would appreciate y'alls help.
                                This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
                                10-29-2024, 12:54 PM
                              • ChaosLegionnaire
                                correct way to connect bare speaker wires into spring clip terminals?
                                by ChaosLegionnaire
                                i recently bought a logitech z607 surround system. however, its giving me grief. when i first connected it, it only had sound coming from the front right speaker. after a great deal of fiddling and reseating the speaker wires into the spring clip terminals, i finally had sound coming from all 5 satellite speakers.
                                however, the sound still gets cut off intermittently if i move the speakers, subwoofer or move/touch the speaker wires on the back of the subwoofer. so i wanna ask what is the right way to connect bare speaker wires into spring clip terminals?
                                i googled...
                                10-27-2022, 06:19 AM
