Intel 915G (dell sx280 & gx280) Custom video driver
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Ok, I ran into a bit shit sandwich that I had to take a big bite out of yesterday. I sold a Dell SX280 to a friend of mine, and I mated it up with a Dell IN1910N 19" 16:9 widescreen monitor. Low & behold, the driver for the onboard Intel video doesn't support its native resolution of 1366x768. 1280x768 looked ok on it, but in my mind, it just wasn't right...... It's been years since I've had to write/hack a driver to make something like this work, but after a few hours of tracking down this monitor's modeline and converting it to hexadecimal, and then hacking it into the driver, I got a quick refresher course on the topic... The driver I used was the latest driver provided by Dell from their site. Before you ask, yes, I tried the latest driver from Intel as well, to no avail.
    Anyway, since I went through all the hell of making this, I figured I'd share it with everyone. Nobody needs to go through the 2 hours of bullshit I went through to make this...so here it is. This driver will work on any Dell SX280, GX280 (thats using the onboard video), and any other Dell board using this video chip.
    https://www.badcaps.net/forum/attach...1&d=1342499453
    Just unRAR it, and execute the setup.exe like you would do for a normal install, nothing special is required to make this driver install or work right, 1366x768 will be in the resolution setting slider. This driver should work for other model monitors using this resolution for their native as well, but bear in mind, it hasn't been tested on any other monitor except the Dell IN1910N (which it works beautiful on). Its written for win2k and XP pro.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • i4004
    • Oct 2006
    • 2029
    Re: Intel 915G (dell sx280 & gx280) Custom video driver
    long time ago adding resolutions boiled down to adding number(s) to driver's ini file...
    still the same?
    (adding the monitor model aside)
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      Yes, still basically the same. The hex conversion of the monitor's native resolution's modeline is what was a pain in the ass, as the string needs to be in hex before added to the INF. Even more of a pain in the ass was actually finding the monitor's modeline, as moninfo utility wouldn't bring it up for some reason. The actual modification of the driver only took a few seconds.....it was all the BS that had to be done in order to make that modification.
      Team : 49813
      Join in!!
      Team Stats
      • msasasgs
        • Mar 2012
        • US
        Hi Topcat
        I have tried opening the RAR archive to get to the setup.exe file but the folder that is unRAR'd is empty. RAR file shows a packed size of 3914KB
        Using Powerarchiver is unRAR the file.
        XP Pro
        Any suggestions?
        Thanks for any help in advance
        SS
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Opens fine with WinRAR here.
          A working TV? How boring!
          • Toasty
            • Jul 2007
            • 4171
            ...and WinZip and 7Zip...
            veritas odium parit
            • RJARRRPCGP
              • Jul 2004
              • 6304
              403
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              "¡Me encanta "Me Encanta o Enlistarlo con Hilary Farr!" -MĂ­ mismo
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Well NOW i get a 403 as well. Could have to do with moving to the new server perhaps?
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  Yup I get a 403 as well.
                  • c_hegge
                    • Sep 2009
                    • 5219
                    403 here too
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16959
                      fixed
                      Team : 49813
                      Join in!!
                      Team Stats
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5045
                        • US
                        when someone gave me this toshiba laptop, the wifi card is actually a realtek 8187 USB chip /w a usb-pcie controller and they changed the hardware ID to 8197. With XP, this did not work. I had to DL the latest 8187 from a realtek site (not the offical one) and hack the HWID's. worked perfectly.
                        i've heard of hacking resolutions in inf file, I think I actually did it once or twice many many years ago.
                        • henwy
                          • Aug 2012
                          • england
                          Entered By Mistake
                          Last edited by henwy; 08-20-2012, 04:54 AM. Reason: Human Error - Hack is Ingenious
                          • osrex
                            LED DRIVER KEEPS DYING
                            by osrex
                            Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                            i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                            i have no datasheet at all for the LED lights, all i have is its length.
                            long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                            as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                            05-05-2025, 03:36 PM
                          • howardc64
                            Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                            by howardc64
                            Problem
                            Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                            Model & Board Pics
                            Conflicting Spec
                            Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                            https://www.shopjimmy.com/vizio-gj-2k1...
                            10-10-2024, 01:16 PM
                          • Teban1306
                            [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                            by Teban1306
                            Hello everyone!
                            I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                            System Information:
                            • Model: Lenovo ThinkPad T14 Gen 1
                            • Machine Type: 20S1S4E600 (Intel i7 variant)
                            • Current BIOS: N2XET42W (1.33) - Latest version
                            • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                            What I'm trying to achieve:
                            Replace the default "LENOVO" boot logo with a custom image during POST.
                            đŸ”§ What I've tried:
                            09-14-2025, 11:49 AM
                          • charif
                            Audio Driver for Thomson P14C4BK128
                            by charif
                            Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
                            I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
                            The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
                            Here are the details:
                            • Model: Thomson P14C4BK128
                            • Operating System: Windows 10 64-bit
                            If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
                            Thanks in advance for your help!
                            04-30-2025, 05:41 PM
                          • bohaboha
                            how to install gl usb2.0 uvc camera device driver on windows 10
                            by bohaboha
                            Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
                            but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
                            any help?
                            01-26-2025, 08:33 PM
