LED DRIVER KEEPS DYING
  • osrex
    • May 2025
    • Egypt
    Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
    i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
    i have no datasheet at all for the LED lights, all i have is its length.
    long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
    as soon as i fix the chandelier to the ceiling and bury the driver inside the hub, it works for 1 hour then the driver burns, and trips the breaker.
    the seller suggested its just overloaded and to split the 24 arms in 12 arms each for its own driver, and i did that, worked fine on the ground for 3 - 6 hours continuesly "well ventilated", as soon as i hanged it to ceiling again, worked for 2 hours then again, driver burnt, breaker tripped.
    im almost sure going back and forth with chatgpt, copilot & gemini, is its a driver issue, and basically its just not well ventialted, but i have no option to ventilate it.
    if this driver is wrong for this chandelier type, which would be the correct one
    please check all pictures attached for the external and internal driver components.
    https://imgur.com/a/9p6PAPM
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8327
    From what I see the DB307S bridge rectifier shorted out and that most certainly makes your fuse blow.
    Pulled up a datasheet and looked at the output current derating curve. At 40C it does 3 amps, but at 110C it's down to only 1A. That also goes along with that 1hr lifetime you experience. You got thermal runaway… and considering your location, things are just getting too hot up there when that PSU is mounted inside the hub. Also a quality bridge rectifier should not derate like this one does. Nothing on that board is mounted on a heatsink either. Poor design, cheap components, no cooling. Cheap as F*. It bound to go
    • howardc64
      Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
      by howardc64
      Problem
      Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
      Model & Board Pics
      Conflicting Spec
      Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
      https://www.shopjimmy.com/vizio-gj-2k1...
      10-10-2024, 01:16 PM
    • charif
      Audio Driver for Thomson P14C4BK128
      by charif
      Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
      I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
      The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
      Here are the details:
      • Model: Thomson P14C4BK128
      • Operating System: Windows 10 64-bit
      If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
      Thanks in advance for your help!
      04-30-2025, 05:41 PM
    • bohaboha
      how to install gl usb2.0 uvc camera device driver on windows 10
      by bohaboha
      Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
      but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
      any help?
      01-26-2025, 08:33 PM
    • Daveleone
      UN55D6900 BN44-00428B partial led driver circuit failure
      by Daveleone
      Hello TV experts! I have a UN55D6900. The successfully TV turns on, and the backlights light up, and I get a picture, but there is a section that is dim. I took it apart and 1 out of 4 segments of backlight LEDs are not lighting on both sides of the TV (in other words, the same segment is out on both LED strips).
      I tested the LED strips with my LED tester and all of the LEDs light properly, so I believe the problem is with the PSU/LED driver board (BN44-00428B). The voltages at CNM810 (between PSU and main board) look ok to me. The voltages at CNL801A and CNL801B look off for one...
      07-23-2021, 06:31 PM
    • harp
      help with graphics driver for eMachine G725
      by harp
      I am trying to find graphics driver for old laptop eMachine G725, for winxp 32bit... from data on internet, https://gadgetaz.com/Laptop/eMachines_G725--1942 it will have Intel GMA 4500MHD graphics, so I downloaded a few of them but nothing work, error say: this computer does not meet the minimum requirements for installing the software. So, please somebody help me to find bare minimum graphics driver to see non deformed screen anymore...
      07-02-2025, 01:26 AM
