Audio Driver for Thomson P14C4BK128
  • charif
    • Feb 2016
    • 26
    • agad
    Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
    I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
    The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
    Here are the details:
    • Model: Thomson P14C4BK128
    • Operating System: Windows 10 64-bit
    If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
    Thanks in advance for your help!
  • andrewsawesomr
    • Jun 2022
    • 101
    • United States of America
    Since Thomson doesn't provide drivers, let's figure out what audio device the laptop has. Press Ctrl+R simultaneously, then type msinfo32 and press the enter key on your keyboard. Go to Components>Sound Device, then take a screenshot of that page and upload it in a reply.
    • charif
      • Feb 2016
      • 26
      • agad
      Thank you for responding to my issue. I would like to mention that the sound was working before the format.
      • andrewsawesomr
        • Jun 2022
        • 101
        The Everest I2S drivers are available from Microsoft here. To update the driver, open Device Manager, right-click the Everest I2S Codec Audio Device, click Update Driver, click Browse My Computer for Drivers, and navigate to the folder the driver you downloaded is in.
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
        • i_am_patch
          Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
          by i_am_patch
          Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
          04-30-2024, 08:20 PM
        • Piaskos
          Dell Vostro 5490 - no sound, no audio device
          by Piaskos
          Hi, i've got problem with Dell Vostro 5490.
          Board - Mantis CML 18788-1
          Windows says "no audio device detected". The other functions work properly.
          What i've done:
          1. I checked motherboard
          2. I changed audio codec (ALC3204)
          3. I reflashed bios with clear ME
          4. Audio is enable in bios
          5. Both speakers are good
          6. After installing the drivers from the Dell website, the devices visible in the manager:
          - Audio for intel displays
          - Intel Smart Sound Technology...
          01-30-2023, 02:58 AM
        • CapLeaker
          Motorola Minitor V pager no audio / sound repair
          by CapLeaker
          Got a bunch of Motorola Minitor V pagers from Fire Departments here trying to fix some out of the non working ones. These pagers are known for either no sound / audio or they don’t charge. The internet is full of suggestions like metal shavings inside the speaker?
          Anyway so I took one of the Minitor’s apart for my amusement in order to see why that is and nobody can fix em. There are no service manuals or schematics for these that I know of. However… I did find the problem!
          On the main board of this unit where the speaker connects to there is a metal shield....
          06-10-2025, 07:44 PM
        • JRade
          Audio video receiver KENWood KR-V990D,no sound
          by JRade
          When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
          The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
          I replaced the capacitor C303/0.047F, nothing changes.
          I'm asking for help, what should I do next?
          Thanks in advance!...
          08-05-2025, 10:23 PM
