SuitCase PC. :/
  • Phaihn
    • Jan 2009
    • 842
    Re: SuitCase PC. :/
    Originally posted by c_hegge
    Phaihn, How are you going with your suitcase so far? I've nearly got mine done. I just need some RAM and a small enough monitor to fit in the top (about 15" square for 16" Widescreen)
    Gave up i got bored and i decided i didnt like the size of my suitcase so i threw it out ill try again some other time but i want to try a mini itx board instead and i am moveing back to edmonton alberta soon so i needed to make space.
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Re: SuitCase PC. :/
      Edmonton a pretty small town is it?
      Can't fit another PC in?
      I just got one of these.
      http://www.avalue.com.tw/products/EBM-945GME.cfm
      C2D w/PCI-e and only 8" x 5.75". - About the footprint of a CD Rom drive.
      Ad pic shows KZG but it came with all Sanyo.
      Not sure what I'm gonna do with it yet.
      Still waiting on a T2400 CPU & RAM to get here.
      They only had one. *sniff*
      I could fit about 3 of these in a standard ATX case.
      Mann-Made Global Warming.
      - Dr Seuss
      • Phaihn
        • Jan 2009
        • 842
        Re: SuitCase PC. :/
        Not really Edmontons more of a metro but i wasnt liking how the Thing was turning out anyway ill try to get back at it when i find a difrnt case.
        My Computer.
        • c_hegge
          • Sep 2009
          • 5219
          Re: SuitCase PC. :/
          Here's how I'm giong with my Briefcase PC. The components I'll be using:
          Motherboard: Gigabyte GA-M61PME-S2P
          CPU: Athlon 64 X2 3200+
          RAM: Don't have any DDR2 yet.
          HDD: 20GB Seagate U series 5 (for now)
          Optical Drive: Lite-On CD Burner (for now)
          PSU: 450W Codegen
          Monitor: Don't have one that fits in the top yet. (needs to be 15" square or 16" widescreen). All I have is a 17".
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Re: SuitCase PC. :/
            Nice, but why did you use that crappy PSU? (or has it been modded and recapped?)
            • c_hegge
              • Sep 2009
              • 5219
              Re: SuitCase PC. :/
              The only mod I did to that PSU was adding some extra connectors. Other than that it is as it left the factory. I used it for 3 reasons:
              1. They're not that bad (ie. not as bad as Deer or that 250W Worstec model in some Evilmachines).
              2. It doesn't make a high pitched squeal under load like all my re-capped Antec Smartpowers do.
              3. Smartpowers are slightly longer and don't fit.
              • dan86
                • Nov 2009
                • 35
                #27
                Re: SuitCase PC. :/
                Originally posted by Phaihn
                Heres something i am working on.
                Any advice?
                I am trying to figure out how to organize everything.
                Just stick it in a standard atx tower :P You'll need some cooling definitely for that
                • Phaihn
                  • Jan 2009
                  • 842
                  Re: SuitCase PC. :/
                  then it wouldnt be mobile
                  My Computer.
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3113
                    Re: SuitCase PC. :/
                    1. I would argue that most deer's would beat out a codegen no problem. Codegen is known for 'ploding even under a light load. Where as most deer do fine at 200-250W loads. some are even overbuilt true 600W units
                    2. Bestec's aren't bad at all after a recap. They actually run their ratings as well as having full protection circuits, transient filters, medium quality fans, thick gauge wiring, etc...
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Re: SuitCase PC. :/
                      370, I've NEVER seen a codegen go bang or take a board out (unless it gets hit by lightning). I opened the case on this one and it looks better than many of the gutless wonders I see on this site. I can post a pic of the inside if you like.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        #31
                        Re: SuitCase PC. :/
                        please do post pics.
                        all the codegen units i have seen here were total gutless junk.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Re: SuitCase PC. :/
                          Got some pics now. Here they are.
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            Re: SuitCase PC. :/
                            NOOOO!!!
                            i see 4 diodes in place of a bridge rectifier. not even close to ok.
                            not enough caps on the secondary.
                            the wire is too thin.
                            sorry, but your PSU is a POS.
                            sigpic
                            (Insert witty quote here)
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3113
                              Re: SuitCase PC. :/
                              Ugh, looks too much like a leadman. You couldn't even put a bridge rectifier in there with how those diodes are arranged.
                              I'd say it's 200W at best. But I would need to see what is on the primary and secondary heatsink.
                              I'm going to assume it is like most cheapies and has two 13007 knock-off's which the good ones from fairchild are really only good for a 300W unit.
                              Secondary chokes have some thin wiring, as well as being small. All the secondary rectifiers are to-220 which leads me to believe they are probalby all 20A rectifiers, but most of the time they cheap out for the 12v rail and use a 12A or a 16A unit there. Thought it looks like there are two rectifiers on the 12v rail. Still, that dosen't mean something else wouldn't go poof in it, especially since the primary transformer is microscopic.
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                #35
                                Re: SuitCase PC. :/
                                Looks worse than Deer/Allied, but not horrible like Leadman/Sun Pro (probably closer to L&C, but with better output filtering).
                                The input rectifying diodes are really are small, but heatsinks seem okay. At least there is no two-diode treatment for a 12v "schottky" rectifier . That's a big no-no for any system.
                                Might be okay for the system you're using (I'm not too keen about that idea, though).
                                And what the Hec are those caps ?
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  Re: SuitCase PC. :/
                                  So it's a junk PSU, but it's the only PSU I have that fits and doesn't make a high-pitched squeal under load. I'm also not looking to spend more than I really have to on this project, so I'll use it for now. I might put a better one in it later.
                                  • 370forlife
                                    Large Marge
                                    • Aug 2008
                                    • 3113
                                    Re: SuitCase PC. :/
                                    I don't know, even that leadman looks pretty good compared to it.
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      #38
                                      Re: SuitCase PC. :/
                                      Yes, but most newer Leadman/Sun Pro units I've seen here seem much worse than this Codegen.
                                      c_hegge: If the voltages are reasonable and stable, PSU runs cool, and if this whole system will be used only once in a while for light duty stuff, then the Codegen will probably be okay (at least until the caps go bad).
                                      • c_hegge
                                        • Sep 2009
                                        • 5219
                                        Re: SuitCase PC. :/
                                        All conditions there are true. The voltages are stable, it runs cool and it won't be used that often and when it does get used, it will probably just be for basic stuff like internet, word processing, etc. It will probably be running linux (either ubuntu or mandriva).
                                        • shadow
                                          • Feb 2007
                                          • 732
                                          Re: SuitCase PC. :/
                                          To be fair to Codegen...before I knew about badcaps. I have ran a crappy Codegen in a Socket A system for about 3-4 years without problems.
                                          It even works till today! However I do not use it anymore and it has not been turned on in close to 2 years.
                                            TOP201YAI 3-Terminal TO-220 PWM switch Figure #7 in date sheet
                                            by sam_sam_sam
                                            I would like to know what the specifications for the transformer in this data sheet is I would like to build one
                                            Also for figure number 8 as well
                                            Also for figure number 9 as well
                                            Here is the data sheet I know that this item has been disconnected but I can buy them surplus
                                            https://cdn.badcaps-static.com/pdfs/...da43fe7f6c.pdf
                                            I have a mad scientist streak in me lately and want to be a little adventurous
                                            The reason is I have some ATX switching power supply that I have as spare parts from and wondering if I could use one...
                                            10-09-2021, 06:21 AM
                                          • Widget
                                            Blown heated blanker controller. Trying to figure out these smd resistors
                                            by Widget
                                            We have one of those heated throw blankets you plug into AC power. The other day it went *bzzzbzzzbbzz... pop*, so I opened it up to find what appears to be two resistors gone *poof*. (R7 & R14 in picture)
                                            luckily, we have a second blanker with what appears to be identical controller, so I opened it up to take a picture
                                            According to the good controller PCB, R7 = 9531, & R14 = 103
                                            Online SMD resistor calculator says
                                            R7 - 9531 = 95.3kohm
                                            R14 - 103 = 10kohm
                                            Is this correct? Would all I need is a 10k...
                                            06-30-2024, 11:22 AM
                                            Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                                            The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                                            Securing a good thermal interface between...
                                            10-07-2024, 04:35 AM
                                          • sdinelli
                                            Help figure out burnt up resister values after fireworks(:
                                            by sdinelli
                                            Hello all
                                            fun times here tinking with the electronics.
                                            Minifridge PSU blew up. i replaced a diode bridge rectifier and one mosfet that was shorted. a blown fuse and the varistor.
                                            ( yes i know i should have replaced both mosfets. Im learning)
                                            i didnt really find anything else wrong so i plugged in and got some high pitch sounds and after 5 secs fireworks went off.
                                            Two resistors fried.
                                            trying to figure out the values of them. No way to tell but hoping someone can give me a general safe bet based on knowledge of switching PSU's.
                                            ive...
                                            03-03-2022, 06:45 PM
                                            Surface Mount Fuses Fundamentals Datasheet
                                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                            10-07-2024, 06:07 AM
