Aliexpress LGA2011 X79 motherboards
  • bigbeark
    • Jan 2010
    • 661
    I have been checking out a YouTube site PhilsComputerLab, he reviews modern and retro computer equipment with a focus on gaming. He's getting very good performance from Chinese motherboards using Xeon E5 CPUs with DDR3 ECC Server Ram. These are sold on Aliexpress but I also see some on Ebay and even some Computer chains in North America are now selling them. The main market for this equipment is Russia, Australia and South America. One attraction is pricing. You can buy a complete kit with CPU, 16 GB Ram and the new motherboard for about $100 USD. The other is cheap or free delivery. Phil himself lives in a remote part of Australia. In areas where there are no computer stores this is a real benefit.
    Some sellers are offering new Socket 775 boards with jumpers enabling you to run either socket 771 or socket 775 without any CPU mods for $50. These boards run DDR3 memory.
    Name brand Used socket 775 boards that will run Quad Core CPUs are expensive in these markets, and judging from Ebay, they are still expensive in North America too.
    Comments?
  • BigTroll
    • Sep 2010
    • 1317
    • LAMBDA SOND
    Re: Aliexpress LGA2011 X79 motherboards
    I bought a Chinese 1155 motherboard to try out, it had its share of problems it didn't support turbo boost and only had a 10/100 nic and no PWM fan control but other than that its been rock solid stable. If you don't mind risking a bit of cash I would say go for it but have low expectations so that way if you do get a turd your not disappointed.
    My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
    • bauto601
      • Sep 2012
      • 102
      • Netherlands
      I have ordered a micro-atx X99 board with 32GB DDR4 ECC memory and an E5-2678V3 CPU. According to the russian youtube reviewers, these boards have vastly improved over time. The early x79 were a bit twitchy but the current X99 boards seem to be a lot better.
      Oh well, i'll find out in a couple of weeks i guess.
      If you really need a somewhat good performing budget system, i would skip 775. It's just becoming too old now and you can get the boards and cpu's even cheaper on just the second hand market.
      Go for a X58 setup with something like a X5650~X5670 Xeon cpu and some ECC DDR3 memory which is dirt cheap. For about €90 you can get a sixcore cpu, 16GB ram and a motherboard which will be twice as fast as a 775 setup. X79 is also indeed getting very cheap and may even be better value than X58 now i think about it.
        • 21053
        A few members have asked for bios dumps for some of these chinese boards,they`re hard to find. I`d recommend anybody buying one to backup the bios in case it goes tits-up at some point.
        • bauto601
          • Sep 2012
          • 102
          • Netherlands
          For the X99 boards, mod biosses are very popular since the use of a specific cpu microcode version unlocks the Xeons turbo boost to make all cores run at the single core turbo boost speed at the same tame without a time limit. With this you usually gain 500MHz all-core, which is pretty much when the all-core turbo speed normally is around 2.6GHz. So all these biosses are (luckily) publicly available. I mean, a 12 core Haswell CPU running at 3.3GHz on all cores with quad channel ecc memory support for €90 was tempting enough for me to give it a go.
          I recommend to take a look at this site:
          https://xeon-e5450.ru/
          Google translate is required unless you master the Russian langauge.
          • silentbogo
            • Jun 2020
            • 8
            • Ukraine
            I hate all of those.
            With X99 at least you don't gamble that much on chipset(either x99 or C612), but chinese x79 are a total mess of mismatch-reballed hubs: one person gets X79, next one - B75 or H67 etc.
            Had about a dozen of those in my workshop 2 years ago - all with either dead PCH, or blown VRM, or both at the same time.
            The best alternative is to get a used HP Z420/Z620, Dell T3600 or Lenovo S30. All of those are as cheap as chinese crap, but they are built to spec with full feature set, and are meant to do actual work 24/7.
            Just recently I've built a decent machine on a penny budget: Lenovo S20 chassis(old one from LGA1366 WS), Z620 board, some off-brand tower cooler for sAM4 w/ 2011 bracket and reused some old parts laying around the office. Currently in a process of replacing stock v1 BIOS with modded one (trying to get Ivy EP support and NVME boot at the same time).
            Regarding X99 - same thing. HP Z640 boards go for sub $80 used nowadays. All you need is a PSU adapter($2-3, if not bundled w/ board) and a few jumpers to make it work and not spit-out warning messages at boot. It may not offer overclocking, but it's the cheapest and the most reliable option for this socket.
            Also, when you go to "hi-end" chinese stuff(e.g. proper quad-channel support and semi-decent VRM), you get into questionable territory of matching the price of a mid-range brand-name x99 board.
              master hoarder
              • May 2008
              • 12175
              +1
              Although I have not owner a Chinese no-name board yet, I too am weary of their reliability. Meanwhile, it is truee that Dell and HP workstations are engineered with reliability in mind, and they can be found cheap enough thanks to big companies and research firms retiring them every few years.
              I bought a Precision T7500 tower recently, and that thing is a beast. It has dual CPU socket that will actually handle 125W and 140W TDP CPUs without burning the VRMs, proper tripple channel memory support, and came with a 1000 Watt Delta PSU stock. All of that for $40. A Chinese X55 board costs more than that and many don't even support tripple channel memory or would I trust them to handle a high-power LGA1366 CPU.
              Agreed.
              Seems to be the case with many of the Chinese boards I've looked at. In that regard, I've been looking for AMD socket G34 boards. There are a number of them on eBay - both reputable ones like Supermicro and the Chinese variants. The Chinese variants seem more suitable in terms of features, as they are more consumer-oriented. However, their main problem is the pricing, as you noted. For a little more, I can get a dual-socket G34 Supermicro board with 12+ RAM slots. Given the ridiculously price of used G34 CPUs, and the fact that at least the SM boards will surely be reliable, one has to wonder if the Chinese boards are worth it in the end.
                • 31068
                the chinese boards are aimed at internet/gaming cafe's and embeded stuff like vending machines/kiosks
                they are intended to run 24/7 but dont expect to just throw a win7 dvd at them - you need to install the drivers properly.
                  Lithonia Lighting versus Light of America Compact Fluorescent product quality
                  I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                  I also have back when Light of America had these light bulbs available for yard lights
                  The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                  While the Lithonia lighting fixture has all most certain bulb failure
                  So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                  I have only had this light fixture for not more than a year if it...
                  07-02-2023, 03:45 PM
                • vallllliiii
                  Gigabyte motherboard GA-H110M-S2PH (rev. 1.0) DDR3 | Boot loop and 5 beeps
                  by vallllliiii
                  Hi, last month i bought a broken pc that i tought i can fix for myself but it turned out to be time consuming. The pc turn on and shows no display and beeps 5 times and restarts again and again, i think it s the motherboard because i tested/replaced all the parts except the motherboard. The pc was used mostly for light gaming and i think it wasnt overclocked or something. I tried all the basic fixes(cleaning the ram slots, removing the cmos battery, reseat the GPU/CPU/RAM). I think the last thing to do is to replace or repair the mobo but i prefer to try to repair because i don t want to spent...
                  08-18-2024, 09:21 AM
                • eccerr0r
                  pairing DDR3 in supermicro boards...
                  by eccerr0r
                  I just found out my supermicro ddr3 motherboard enforces dual channel - if I have unpaired or incorrectly paired DIMMs in a bank, it will give up and start beeping... is this common on server boards?
                  I was trying a combination of two 4GiB modules and an unpaired 8GiB module. The only combo that worked is if I had both 4GiB modules installed. Having either size paired with an empty slot or dissimilar module, the machine would beep memory failure on power up. My other DDR3 boards would happily deal with mismatched modules though may not enable dual channel.
                  This is a microserver...
                  06-13-2023, 09:54 AM
                • Foetuss
                  Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                  by Foetuss
                  Hi all
                  Hope this is in the correct place.
                  I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                  Could use some double checking to see if I'm not doing something stupid .
                  Pictures of the boards are attached.
                  What I will be replacing with what : (planned)
                  Soltek Golden ::
                  4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                  6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                  01-18-2025, 11:44 AM
                • eccerr0r
                  DDR3/DDR4 laptop SODIMM to desktop DIMM adapters
                  by eccerr0r
                  Anyone have/use these SODIMM to desktop DIMM adapters, well, not to convert signaling types but just change socket types. Are they stable? Do they slow things down and force downclocks?
                  I have an unused DDR3 4GB SODIMM and have a need for a 4GB DDR3 DIMM. Wondering if I should:
                  - buy a 4GB DIMM (and selling the 4GB SODIMM seems unlikely)
                  - get an adapter for the SODIMM?
                  - Find a cheap 8GB DIMM somewhere and hope it's not a SODIMM...
                  Though DDR3 is my highest technology module out there I suspect I really should be getting 8GB modules especially for a...
                  03-02-2022, 01:56 AM
