pairing DDR3 in supermicro boards...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8691
    I just found out my supermicro ddr3 motherboard enforces dual channel - if I have unpaired or incorrectly paired DIMMs in a bank, it will give up and start beeping... is this common on server boards?
    I was trying a combination of two 4GiB modules and an unpaired 8GiB module. The only combo that worked is if I had both 4GiB modules installed. Having either size paired with an empty slot or dissimilar module, the machine would beep memory failure on power up. My other DDR3 boards would happily deal with mismatched modules though may not enable dual channel.
    This is a microserver board, so it's using UDIMMs like consumer machines, though it does use parity for ECC.
    As another thought I wonder what it will do with non ECC modules...would it also barf on them...
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: pairing DDR3 in supermicro boards...
    What board? Some are worse than others....but as a rule, SM can be fickle about memory.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      • 30965
      something i learned about DDR3,
      there are 2 voltages - 1.5v and 1.35v
      the 1.35v are usually called "DDR3L"
      dont accidentally use the wrong type or mix them!
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8691
        That's good to know, seems supermicro does sometimes enforce identical dimms in a channel to boot, which matches my suspicion. This kind of sucks, will have to dump this 8GiB DDR3 on another machine unless I find a matching module.
        I think I have mixed DDR3 and DDR3L on a consumer machine, but this might not be acceptable on these server boards, will have to look at that. This is that Atom micro server board, and being Atom, perhaps those 4GiB were DDR3L, forgot ...
        Hope I can either find another one or use this on a desktop board. My PVR which has way too much RAM (12GiB) for what it does already will probably get a memory upgrade to 16GiB, at least to see if this 8GiB module works or not ...
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8691
          Well, I finally found another 8G DDR3 ECC UDIMM (doesn't perfectly match) and swapped two of the 4G modules in the Supermicro board...
          BEEP BEEP BEEP BEEP BEEP BEEEEEEEEEEEP -- No RAM found
          WTF...or Oh No...
          Hmm... then I noticed that I stuck the two 8G modules in different banks so the motherboard might have tried to pair an 8G with a 4G module. So I swapped the modules around so that the 8Gs are in the black sockets and 4Gs are in the blue sockets.
          (waited for BIOS to boot, dang this board is slow booting...)
          BEEP!
          It boots and shows proper 24GB RAM! Memtest86 comes up fine. Slow... reports less than 5GB/sec with DDR3-1600 modules.
          So yeah looks this SM board is really fickle about memory configuration.
          The two displaced 4GB modules got dumped into my X58 board, now that's another problem I wonder about...
          • eccerr0r
            old X58 triple channel board... memtest86 memory speed?
            by eccerr0r
            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
            06-28-2025, 09:06 AM
          • ongobongo
            Ram Modules with undderfill - tricks for desoldering
            by ongobongo
            I'm working on another Lenovo E14 gen 2 AMD here which has a ton of errors with the factory soldered DDR4 ram chips. I do have a donor board here from which I'd like to use the modules and swap them. Unfortunately, the modules are glued down with underfill, which i have never worked with before.
            I tried with a lot of heat on the donor board but the modules won't come loose.
            Are there any hint or tricks when it comes to dealing with underfilled chips/ic that could help here
            Ongo
            06-02-2024, 02:18 AM
          • gabrielA7
            Zotac GTX 1080 8GB / No video / Error reported on all memory modules!
            by gabrielA7
            Hi guys!!
            I have this video card on my bench, it turns on and the screen goes black!
            I used MATS but it showed an error in all memory modules, when writing!
            I once got a 1060 with the same symptom, all modules were defective, I rebaled the GPU and it stayed the same.
            Remember that I have all the debts ok, 1.35 Vram and such!
            Could the problem really be in the GPU?
            Could it be the BIOS?
            Thank you in advance!​
            06-05-2025, 09:04 AM
          • Topcat
            Topcat's Supermicro X10DAI Build - Plus NVMe BIOS Mod Inside
            by Topcat
            Yes, I know I don't post this stuff much anymore....the only reason I'm posting this one is because of a NVMe adapter incompatibility; seems rather planned by Supermicro.....or I'm atleast a bit suspicious. It's plenty new enough to have a UEFI bios but a short 'happy list' of NVMe controllers that will work with this board, as if by some 'miracle', all Intel....so lets start at the beginning; we'll get back to this later.
            Of course the motherboard is as the thread title states; X10dai....but we'lre going to have some fun shoehorning this into a modern 'gamer case' that can actually...
            09-29-2024, 03:55 PM
          • vallllliiii
            Gigabyte motherboard GA-H110M-S2PH (rev. 1.0) DDR3 | Boot loop and 5 beeps
            by vallllliiii
            Hi, last month i bought a broken pc that i tought i can fix for myself but it turned out to be time consuming. The pc turn on and shows no display and beeps 5 times and restarts again and again, i think it s the motherboard because i tested/replaced all the parts except the motherboard. The pc was used mostly for light gaming and i think it wasnt overclocked or something. I tried all the basic fixes(cleaning the ram slots, removing the cmos battery, reseat the GPU/CPU/RAM). I think the last thing to do is to replace or repair the mobo but i prefer to try to repair because i don t want to spent...
            08-18-2024, 09:21 AM
