Firewire + USB problems
  • pentium
    • Mar 2006
    • 2778
    *sigh*
    This system is really starting to smell "lemon fresh".
    I got this Canon ZR80 A mini DV camcorder for $20 so I could make quick Youtube stuff however when I plugged it into the system and tried to dump the tape to the system, one of two things would happen:
    1-The system would become horrendously sluggish and unresponsive and the stop button on the camera would have to be pressed or the camera unplugged to return it to normal.
    2-The system would capture fine but then a minute and a half into the capture the system would lock up rock solid and the reset button would have to be pressed.
    I have two VIA chipset based firewire/usb combo cards as well as the firewire on my Audigy 2 ZS platinum and both do the same thing so I can't blame the crappy $5 combo card.
    On top of that, the internal USB headers on my motherboard (MSI 865PE Neo2-Platinum) are erratic.
    One goes to my D-bracket and those ports work fine but the other go to my card reader and front USB port.
    For the reader, Windows sees the reader but does not allow me to do anything with it (not visible in My Computer) and the front USB port likes to just make the system say "Unrecognized device inserted" even though other stuff works fine (My shuffle worked fine the first time but the next time it said it had malfunctioned and refused to do anything)
    My suspicion is it does not have enough power but I really don't know and have not yet tried switching the headers around.
    Any ideas?
    Find Nedry!
    Check the Vending machines!!
  • Harvey
    • Apr 2007
    • 264
    Re: Firewire + USB problems
    VIA chipset based
    Hence your problems.
    • weirdlookinguy
      • Sep 2007
      • 1638
      Dude... no offense but I think you need to find a new motherboard... That system has given you nothing but trouble.
      • Harvey
        • Apr 2007
        • 264
        Shhhhh.. don't tell him about this .. http://www.devhardware.com/forums/mo...b-s-33530.html -you know it keeps him busy playing
        • Wizard
          • Mar 2008
          • 2296
          ICH5R is a raid southbridge chipset. I was wondering if they had investigated bad 5Vsb capacitor failing in PSUs? USB power paths is routed *seperately* from southbridge's via filters and on good boards usually have PTC resistors that momentily opens up if excessive current flowing (look like green or white with symbol "1X1".) Now last few years, USB ports is constantly powered via 5Vsb to my annoyance. I bought a 3.5" USB hub and cut the 5V wire on plug cable and backfed the hub with 5V from one of drive connectors so it will only come on when PC is on.
          Remember: ICH5 and ICH5R was recycled on at least 2 different northbridges.
          PS: Have you diagnosed this by pull both VIA firewire/usb cards and try the usb on the mainboard only to see if this helps? If that does resolve the issues, then I strongly advise getting NEC chipset based USB/firewire cards.
          Cheers, Wizard
          • washu
            • Jul 2009
            • 310
            Firewire: VIA sucks but so does Creative so one VS the other doesn't prove anything. The audigy's firewire hardware may be better, but the drivers are so bad it's a moot point.
            USB: The ICH5 has lots of problems with overloaded and blown ports, at least compared to other ICH# chips. Need a MB with a different ICH or a good PCI card. IE: Not VIA.
            • pentium
              • Mar 2006
              • 2778
              That was worth the read. I should of done my research I guess before I decided on this board. :/
              If anything, I try to find combo cards with TI chipsets. I know it's weird but the serve a double purpose (red PCB TI chipset cards seem to work nicely under irix even though the USB half won't work). These Via boards I bought because they were exactly that: cheap.
              Yes I did pull the cards and it still decided to lock the system solid.
              Find Nedry!
              • Wizard
                • Mar 2008
                • 2296
                I understand. Good diagnosis.
                Cheers, Wizard
                • pentium
                  • Mar 2006
                  • 2778
                  BuMP
                  I ended up replacing the two VIA-based USB/firewire combo cards with two NEC-based cards. one USB, the other Firewire.
                  For starters, the system does not instantly die now when a firewire device like say my iPod is connected but it still gives off static and does other nasty stuff the moment you start to transfer data. The good part though is that the speed is no longer crap, unfortunately, now when you plug any USB devices in other than my mouse or keyboard, the system instantly locks solid, no matter what USB port you try.
                  *sigh*
                  Find Nedry!
                  • toastygoodness
                    • Jul 2005
                    • 813
                    you need a new mb and a TI-based firewire card. neweg has some under their rosewill brand that work well. i use them for audio and video. did you try reformatting? otherwise its your mb that's being special.
                    • pentium
                      • Mar 2006
                      • 2778
                      I'll have to agree with you. Looks like my board is just about at its end.
                      The USB issues have boiled down to another two ports on the board dying. That now makes all four internal onboard USB standoffs dead or malfunctioning. All I got left are four at the bulkhead ond four on the card.
                      I'll buy a nice 2tb drive to back everything up onto first and begin the grim task of replacing the board and reinstalling XP.
                      I always feel like I'm playing Russian Roulette when I reinstall. I have no idea when my copies of Office XP and XP pro will hit their registration limit and I'll have to start hunting for new copies.
                      Find Nedry!
                      • toastygoodness
                        • Jul 2005
                        • 813
                        lol that's kind of gross. man what board do you have? haha
                        you can call microsoft and tell them you are reinstalling can't you? i mean they don't care about those two anymore.... do they?
                        • pentium
                          • Mar 2006
                          • 2778
                          They dont like it when you reinstall as they have no way to know if you really are reinstalling on the same system or if you are using the same license to install on multiple systems.
                          I forget the model of the board but I remember it was one of MSI's last Socket 478 boards. It's black as well. I'm sure I have mentioned the model somewhere here before but it eludes me right now.
                          Find Nedry!
                          • toastygoodness
                            • Jul 2005
                            • 813
                            ew msi haha. bet you recapped the hell outta that. socket478 is out the window, unless you are running northwood. time to save up for some new cheap amds haha
                            • jean luc ferre
                              laptop hp g72 b52sf screen problems
                              by jean luc ferre
                              on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                              the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                              i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                              i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                              06-07-2025, 03:27 PM
                            • Hondaman
                              USB problems?
                              by Hondaman
                              Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                              (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                              I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                              08-12-2024, 03:26 PM
                            • clabr
                              Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                              by clabr
                              Need help to solve some problems with this laptop.
                              After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                              After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                              Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                              Before this had happened I observed some other problems:
                              When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                              12-02-2021, 08:09 AM
                            • falcontech
                              MOTU TRAVELER MK3 AUDIO PROBLEM
                              by falcontech
                              Good Afternoon
                              I have a problem with this MOTU audio card, a traveler MK3, the connection to the computer is via firewire, the card is recognized by the computer (both mac and win) but I have no audio output, on the front there are a series of LEDs including the clock (44.1, 48, etc.) and that LED at the time of connection usually remains fixed telling me the clock frequency set on the computer, now at every start the LED in question remains flashing in most cases, sometimes it becomes fixed, other times it disappears, without any sign of operation, I exclude problems with the firewire chip,...
                              01-24-2025, 08:47 AM
                            • orgamisho
                              Capture digital data between microcontroller and led driver
                              by orgamisho
                              Hello, I have a device which uses 3 7segment displays (4 digits each) controlled by a single led driver (TM1629A) which is controller by a microcontroller (MS51FB9AE).
                              I want to capture the communication between the 2 ICs, so I can decode it and read it from PC with USB cable.
                              The problem is that this task is slightly over my skills and I have no experience is such tasks.
                              I would be grateful if somebody give a hint how can I read and decode the digital signals or share a source where I can educate myself on this matter.
                              I have no idea what protocol is...
                              11-10-2024, 02:42 AM
