I got two liquid cooling blocks from two Powermac G5's both suffered the same fate where the O-rings in the waterblock failed. Luckily however I was able to salvage and still have at least one working pair of 2.5ghz processors.
Anyways, the fix for the leak normally is to drain the unit, unscrew and remove the top of the waterblock, replace the O-ring with a newer and slightly bigger one, flush the system and then reassemble and refill it.
I got all those steps done except the last one. Apple welded (it looks threaded but don't try to twist it off as it snaps clean off the radiator and you need a TIG welder to reattach it) some sort of spring loaded valve/connector thing to it. The unit is also under a small amount of pressure at all times. Does anyone have any idea what kind of special connector is needed? I know how to refill it and repressuirze it but no way to actually get the coolant into the thing.
<----Computer says I need more beer.
