Powermac G5 cooling block refilling
  • pentium
    • Mar 2006
    • 2778
    I got two liquid cooling blocks from two Powermac G5's both suffered the same fate where the O-rings in the waterblock failed. Luckily however I was able to salvage and still have at least one working pair of 2.5ghz processors.
    Anyways, the fix for the leak normally is to drain the unit, unscrew and remove the top of the waterblock, replace the O-ring with a newer and slightly bigger one, flush the system and then reassemble and refill it.
    I got all those steps done except the last one. Apple welded (it looks threaded but don't try to twist it off as it snaps clean off the radiator and you need a TIG welder to reattach it) some sort of spring loaded valve/connector thing to it. The unit is also under a small amount of pressure at all times. Does anyone have any idea what kind of special connector is needed? I know how to refill it and repressuirze it but no way to actually get the coolant into the thing.
    Find Nedry!
    Check the Vending machines!!
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Powermac G5 cooling block refilling
    looks like a r-134 service valve.
    • Wizard
      • Mar 2008
      • 2296
      Pentium, there is so many versions of G5 towers over the years, which one you are working on? 1.5GHz? 1.6Ghz, 1.8? or 2.0?
      • pentium
        • Mar 2006
        • 2778
        Dual 2.5 Powermac G5.
        Also, would the coupling on this work?
        Find Nedry!
        • Wizard
          • Mar 2008
          • 2296
          This?
          http://mac.sillydog.org/archives/000245.php
          http://www.overclockers.com.au/article.php?id=307166
          That fixture that was ripped off is fill/pressurization port. How did you know this is under pressure? You can use antifreeze/distrilled water mix (around 50/50 mix) to refill and no pressure, leave a bit of air bubble for headspace/expansion if this one DOES not have a expansion diaphgram. Which Apple didn't considered including that CRT projector makers are using to prevent coolant from leaking out as coolant expands with rise of heat.
          See if you can find a specialized shop that does small welding job with gas shielding welder for aluminum.
          Cheers, Wizard
          • pentium
            • Mar 2006
            • 2778
            Yep. that's the block alright.
            I'm saying it was pressurized because I had the thing sitting on the kitchen table and I thought "Gee, I wonder what would happen if I pressed the valve open?"
            I did so and was promptly greeted with a geyser in the face of coolant which got all over the ceiling, walls and the table.
            Also, I need to mess with the water/coolant mix a bit. When I opened the blocks it was N A S T Y.
            Find Nedry!
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              looks like they used dexcool (deathcool) in that thing!
              • golemmaster
                • Jul 2009
                • 100
                OMG! Ick!
                • KeriJane
                  Mac Enthusiast
                  • Sep 2008
                  • 681
                  Eww.
                  I like Apple a bunch and wouldn't go near something like that. That's probably not one of their best ideas.
                  Liquid-cooled electronics worked in the space program and major installations but have no place in consumer electronics. The liquid is going to get out at some point. The cooing systems have to be monitored and maintained. Average customers cannot be depended upon to do this.
                  It's a wonder the G5 Power Macs worked as well as they did. That must be a very good design to have lasted this long.
                  My advice is to put that G5 on top of a large cookie sheet, the kind with a raised edge. Big enough to hold all of the coolant.
                  Keep it there whether it's being used or not especially if the floor is anything other than concrete and most especially if there's a ceiling underneath the floor supporting the G5.
                  So THAT"S why empty G5 cases are so plentiful!
                  Glad I waited for the Mac Pro,
                  Keri
                  PS. So far as a fill procedure, I'll bet it involves using a vacuum fill device of some kind. that is, something sucks all the air out and then a valve is opened and the coolant is sucked into the unit.
                  The More You Learn The Less You Know!
                  • pentium
                    • Mar 2006
                    • 2778
                    The only reason why this G5 still works is because the absorbent pad below the block caught all the coolant. Any excess then fell into a plastic tray (again, this was installed by apple) which directed it out the back of the case.
                    I'm pretty sure this is a later revision of the dual 2.5, otherwise I'm sure the latter pad and tray might not even exist.
                    As I already said, the fix is to replace the O-rings with ones which are slightly larger. I'm sure I can just leave a hose disconnected and bleed the system while I refill it with coolant.
                    Find Nedry!
                    • starky52jmas1125
                      • Sep 2010
                      • 6
                      If you use a wrench to hold what looks like a hex nut steady and a pliers or vise grip on the farthest out end the valve will screw out. by the way, do you have an extra water block laying around? I was being too effecient and ended up breaking one of the hose connections.
                      • starky52jmas1125
                        • Sep 2010
                        • 6
                        use a wrench to hold the hex nut steady and a pliers or vise grip to screw theouter most part out.by the way, do you have an extra water block? I was trying to be thurough and ended up breaking a hose connection off.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          i think he had fixed as this was from almost a year ago and he has been having psu issues with it.
                          do not revive old threads unless you are op and have a good reason. if you have a new question, start a new thread (not to be harsh, just saying)
                          sigpic
                          (Insert witty quote here)
                            • 31298
                            the coolant used in those is super-toxic, apple has no end of warnings about them.
                            i read that if they start to leak, apple would rather replace them for free than have you touch the stuff incase you sue them from your deathbed!!!
                            • pfrcom
                              Oldbie
                              • Jun 2006
                              • 1230
                              WHY NOT revive an old thread ?
                              starky52jmas1125's posting is on-topic, relevant, and could be of interest to someone searching for help
                              Reviving old threads is not prohibited by Forum Posting rules in FAQs - but what is in rules is point 1) saying use Search feature
                              better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                There are two reasons this leaking happens:
                                1. Its a mac. Nuff said.
                                2. Water and computers doesnt mix. Watercooling is stupid
                                • Ace Perception
                                  Samsung R530 Bremen motherboard cooling
                                  by Ace Perception
                                  I'm wondering if anybody out there has much knowledge of Samsung Bremen motherboards.
                                  I've got a Samsung R530 which is about 10 years old, over the last 12 months it developed a worsening problem where when asked to do much work it would shut itself down. I had a good idea this was due to overheating which was confirmed by a temperature monitor programme which showed little balls of fire next to the various internal temperature readings. I could also prevent it shutting down if I placed a huge fan running at full speed in front of its air intake!
                                  So I went in pursuit of...
                                  07-21-2020, 03:05 PM
                                • eccerr0r
                                  Running water cooling AIO 24/7/365?
                                  by eccerr0r
                                  Does anyone here run an AIO or other liquid cooled CPU cooling solution 24/7/365 / on a server? Do you feel comfortable with possible failures? Should I be worried about pump failures? Pump failures causing leaks?
                                  Having reservations on a second hand cooling system on a PC. So far it's pretty good, keeps things nice and cool but I've never had long term experience with 24/7/365 operation of water cooling, AIO or not. Might have to downgrade to an air cooled system for peace of mind?
                                  Today, 03:51 AM
                                • Hondaman
                                  Liquid cooling?
                                  by Hondaman
                                  I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
                                  (After previous generation hardware [Gigabyte] didn't...
                                  05-08-2025, 09:37 PM
                                • sheffieldyorky
                                  ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
                                  by sheffieldyorky
                                  Hey there people
                                  While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
                                  This is what I tried, but not in any order.
                                  Google
                                  YouTube
                                  BIOS
                                  Command Prompt (administrator privileges)
                                  On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
                                  10-25-2025, 02:22 AM
                                • hs5424
                                  Dynacord powermate 1600 block diagram.
                                  by hs5424
                                  Hi All,
                                  I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
                                  The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
                                  07-31-2025, 01:35 PM
