Running water cooling AIO 24/7/365?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8712
    Does anyone here run an AIO or other liquid cooled CPU cooling solution 24/7/365 / on a server? Do you feel comfortable with possible failures? Should I be worried about pump failures? Pump failures causing leaks?
    Having reservations on a second hand cooling system on a PC. So far it's pretty good, keeps things nice and cool but I've never had long term experience with 24/7/365 operation of water cooling, AIO or not. Might have to downgrade to an air cooled system for peace of mind?
    • 31296
    they dont leak,
    the failure modes are pump dying and liquid slowly being replaced by air causing air-traps.
    the liquid thing takes several years,
    the pump failure is no different to a fan failure, the pump output's a tacho signal to the motherboard.
    so the system will detect the failure and shutdown.
    widgetinstance 457 (Related Topics) skipped due to lack of content & hide_module_if_empty option.
