Got this motherboard from one of the computer shops and i cant get past the videos bios msg. any ideas?
K7vm4
Re: K7vm4
well the usual - make sure the RAM, CPU, cards, etc are all seated properly, try resetting the bios, remove the bios battery for a while (replace it if it's dead), check for bad caps that could be causing bad voltages to appear.
oh and that's my favorite setup
Re: K7vm4
evey thing looks good but i cant get past that video bios tryed removeing the bat even replaced it with one i had in a difrnt board and even the clr cmos jumperMy Computer.
AMD APU A4-3300 2.5ghz 1mb cache
Motherboard GigaByte GA-A75M-S2V
Kingston HyperX Blue DDR3 8GB (2x4GB)
SB Audigy 2 ZS [B800] Sound Card
500GB WD Caviar® Blue™
1 Terabyte WD Caviar® Black™
2 Terabyte WD Caviar® Black™Comment
Re: K7vm4
does it have an 8 pin 12v atx connector? I had a board that wouldn't boot if you plugged a 4 pin cable into the 8 pin socket.Comment
Re: K7vm4
it only has one power connector as far as i can tell.My Computer.
Re: K7vm4
It could be that the board is just bad - did you buy it new or used? Did they say if it was working or not? Could be something is fried....other people should have more ideas and things for you to try. Good luck!Comment
Re: K7vm4
Got it free the guy at teh store who gave it to me said it worked just needed parts.Attached Filesif you find these attachements useful please consider making a small donation to the site
My Computer.
Re: K7vm4
This doesnt look good does that look like broken leeds?Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: K7vm4
whoa.. do you try to run that thing ON A BLANKET?
ps: or a shirt?
pic #5 could show scratches, but it's hard to tell by the picture.
pps: do you have a port80 card? if no, the mobo speaker might be helpful too.Last edited by kikkoman; 09-18-2009, 11:12 PM."Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. MenckenComment
Re: K7vm4
lol improvise and no port80 card i dont even know what that is and those scrachs in pic are kinda deep i am thinking its hooped but i got a good cpu out of it.My Computer.
Re: K7vm4
speaker does nothing unless i try to run it with out the ram.My Computer.
Re: K7vm4
It looks like a scratch. Check the ends of those traces with a multimeter and see if they still connect. We had a Compaq laptop that did that. Showed the logo and then froze, no input, beeps or codes. Couldn't get that one repaired, the RTC got really hot.Comment
Re: K7vm4
yeah as soon as i find all he parts for it.Originally posted by HarveyPut the lid back on the power supply before you electrocute yourself!My Computer.
Re: K7vm4
Originally posted by kc8adurather elaborate bedwarmer you have there!
My Computer.
Re: K7vm4
Dont have one. as ii can see it goes down to the metal.Originally posted by NxBIt looks like a scratch. Check the ends of those traces with a multimeter and see if they still connect. We had a Compaq laptop that did that. Showed the logo and then froze, no input, beeps or codes. Couldn't get that one repaired, the RTC got really hot.My Computer.
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
Channel: BIOS Requests ONLY!
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
