K7vm4
  • Phaihn
    • Jan 2009
    • 842
    K7vm4
    Got this motherboard from one of the computer shops and i cant get past the videos bios msg. any ideas?
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
  • etnietering
    • Apr 2009
    • 379
    Re: K7vm4
    well the usual - make sure the RAM, CPU, cards, etc are all seated properly, try resetting the bios, remove the bios battery for a while (replace it if it's dead), check for bad caps that could be causing bad voltages to appear.
    oh and that's my favorite setup
    • Phaihn
      • Jan 2009
      • 842
      Re: K7vm4
      evey thing looks good but i cant get past that video bios tryed removeing the bat even replaced it with one i had in a difrnt board and even the clr cmos jumper
      My Computer.
      • etnietering
        • Apr 2009
        • 379
        Re: K7vm4
        does it have an 8 pin 12v atx connector? I had a board that wouldn't boot if you plugged a 4 pin cable into the 8 pin socket.
        • Phaihn
          • Jan 2009
          • 842
          Re: K7vm4
          it only has one power connector as far as i can tell.
          My Computer.
          • etnietering
            • Apr 2009
            • 379
            Re: K7vm4
            It could be that the board is just bad - did you buy it new or used? Did they say if it was working or not? Could be something is fried....other people should have more ideas and things for you to try. Good luck!
            • Phaihn
              • Jan 2009
              • 842
              Re: K7vm4
              Got it free the guy at teh store who gave it to me said it worked just needed parts.
              My Computer.
              • Phaihn
                • Jan 2009
                • 842
                Re: K7vm4
                This doesnt look good does that look like broken leeds?
                My Computer.
                • kikkoman
                  • Jul 2007
                  • 691
                  Re: K7vm4
                  whoa.. do you try to run that thing ON A BLANKET?
                  ps: or a shirt?
                  pic #5 could show scratches, but it's hard to tell by the picture.
                  pps: do you have a port80 card? if no, the mobo speaker might be helpful too.
                  "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
                  • Phaihn
                    • Jan 2009
                    • 842
                    Re: K7vm4
                    lol improvise and no port80 card i dont even know what that is and those scrachs in pic are kinda deep i am thinking its hooped but i got a good cpu out of it.
                    My Computer.
                    • Phaihn
                      • Jan 2009
                      • 842
                      Re: K7vm4
                      speaker does nothing unless i try to run it with out the ram.
                      My Computer.
                      • Harvey
                        • Apr 2007
                        • 264
                        Re: K7vm4
                        Put the lid back on the power supply before you electrocute yourself!
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          Re: K7vm4
                          rather elaborate bedwarmer you have there!
                          • NxB
                            • Feb 2009
                            • 1595
                            Re: K7vm4
                            It looks like a scratch. Check the ends of those traces with a multimeter and see if they still connect. We had a Compaq laptop that did that. Showed the logo and then froze, no input, beeps or codes. Couldn't get that one repaired, the RTC got really hot.
                            • Phaihn
                              • Jan 2009
                              • 842
                              Re: K7vm4
                              yeah as soon as i find all he parts for it.
                              My Computer.
                              • Phaihn
                                • Jan 2009
                                • 842
                                Re: K7vm4
                                My Computer.
                                • Phaihn
                                  • Jan 2009
                                  • 842
                                  Re: K7vm4
                                  Dont have one. as ii can see it goes down to the metal.
                                  My Computer.
                                  • NxB
                                    • Feb 2009
                                    • 1595
                                    Re: K7vm4
                                    Go to "harbor freight" or the canadian equivalent and buy a $10 multimeter. You can't really troubleshoot electronics without one.
                                    • throwaway327
                                      by throwaway327
                                      Model No: RC72LA
                                      Serial No: SBNVKD001014459
                                      06-18-2025, 05:52 PM
                                    • macabook
                                      by macabook
                                      🧩 Initial Issue
                                      Yesterday, 02:17 PM
                                    • Vesko356
                                      by Vesko356
                                      08-11-2023, 03:27 AM
                                    • jbonavita
                                      by jbonavita
                                      Some issues
                                      Things I tried
                                      04-29-2025, 09:38 PM
                                    • zenius
                                      by zenius
                                      12-08-2024, 06:13 AM
