audigy 2 sound card
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    audigy 2 sound card
    ok, so i have an audigy 2 sound card. i got it as a gift, used, with th front panel. went to use it on my tv tuner p3 box, lots of static. the amout changes per channel. even with the mic plugged in, it does this.
    it didnt do this with my ess allegro card
    i read that muting all channels not in use fixes that but i want a solution that is hard ware, not software. would jumpering the extra internal channels form data to ground fix this or would it kill the card?
    note- not working in ubuntu- its a bug that i will fix once i replace the blown hd.
    note 2- i dont want to hear the answer "sound blaster sucks buy a new card". i cant afford a new one and all my other cards have no front panel and since somebody destroyed the drive bay cover for it, i want to keep the panel in there without it being a brick.
    sigpic
    (Insert witty quote here)
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: audigy 2 sound card
    bump. i dont want this to get buried because of the 2 mac vs pc vs linux wars.
    sigpic
    • weirdlookinguy
      • Sep 2007
      • 1638
      What OS is it running?
      Also, that card (in my experience) seems to be sensitive to different PCI buses. Mine liked to pop and click during gaming on the P4 box I ran for a month or two, but it doesn't do it on my new C2D machine. Try switching the PCI slot it's in, that definitely helped when I was running mine on the P4 mobo.
      I ditched mine because it came out of a Gateway machine, and it was lacking the front audio header that retail Audigy 2's have. It was a nice card though - noticeably smooth bass.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        it runs ubuntu. will try the slot.
        in fact, its in my p3 compaq. thank god for the 3rd drive bay!
        sigpic
        • kikkoman
          • Jul 2007
          • 691
          does that problem occur only in linux or in win, too?
          this might help: link
          they only mention 10k1 cards but it should apply for 10k2 as well.
          (i assume ubuntu still runs PA on top of alsa).
          i wouldn't tell anyone that SB/audigy cards suck. in fact, they're awesome consumer grade cards. they just suck under linux (blame creative for that). but under windows, with the kx drivers, they're unbeatable. even the older SB cards.
          "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            i have no other os to test on it; i heard of xp users having the same problem.
            with had no sound under ubuntu other than the static, but i read of a fix for it.
            would fixing it be my issue?
            sigpic
            • Per Hansson
              • Jul 2005
              • 5894
              • Sweden
              Oh, they don't suck under Linux, the drivers for Windows are equally really crappy :P
              Anyway, I've had many issues like yours, try moving the card to a different PCI slot, the reason is you are looking for a PCI slot which is not shared with something else...
              And look in the BIOS if you have a PCI latency timer you can adjust, values should be in the 32 > 64 > 128 range, try modifying that and see if it helps (if your BIOS has this option)
              And if you want to see why threads on Creative always end up in a flamewar (just like Apple) just read this thread, look at the hillarious comments from that guy Donny27
              http://forums.guru3d.com/showthread.php?t=209874
              • washu
                • Jul 2009
                • 310
                What chipset does that compaq have? Anything other than Intel can be trouble with those SB cards. VIAs are the worst for that.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  via
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    but will somebody answer the original question?
                    sigpic
                    • Wizard
                      • Mar 2008
                      • 2296
                      That will be a problem. Nothing you can do about it. Seek a good mainboard with Intel chipset or different sound card (non creative).
                      Secondly, you are strictly running linux means that creative sound card is no use for you. Have to use one of non-creative sound card that linux supports best.
                      Cheers, Wizard
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        moved the slot, a bit of static on line out 1 but 2 and 3 are fine.
                        no intel- max ram 512mb for p3
                        remember i have no money for this.
                        sigpic
                        • Wizard
                          • Mar 2008
                          • 2296
                          Do you have part time job then? Or start mowing grass, etc to get bit of money?
                          Cheers, Wizard
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            no to all, all lawns covered around here and no jobs. the inly opening are are at places that are hell to work at (my mom's a merchandiser, she has seen why the toys r us is hiring--the boss is a real ass hat- when he was boss at office may he once got into a fistfight with someone.). i wish i could work at a computer shop but no opening except at the sleazy scam stores.
                            sigpic
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              besides, the computer is special to me and i dont want to replace it. i did once and the thing died in a week, so i assume it is bad luck to shitcan it.
                              sigpic
                              • weirdlookinguy
                                • Sep 2007
                                • 1638
                                ratdude, I do not mean this as a diss or anything, but that I speak to you as a fellow 17-year-old chum... you should really think about getting a job!!
                                You are never going to find a job if you don't even go out and look because you're sure that all the jobs out there are "taken". They're not. There are ALWAYS jobs in retail and fast food. Nobody's gonna pop out of the blue and offer you one though. Things like the manager at Toys R Us being an asshole suck donkey penis without a doubt, but that's life man. You're gonna deal with asswipes everywhere you go, not just at work.
                                I highly recommend getting a job ratdude. I've been working for a year now, and it's unbelievably radical. I'm saving for a car right now. I have money for junk food. I can go out and do whatever I want. Bowling? Why the hell not! Movies? Sure! Night on the town? You bet your ass! You think damn I could use an AcBel or two, well guess what, no begging mom, no sucking up to dad, no coming up with intricate bullshit for why you need it, no waiting for your allowance to build up, none of that crap. You can just bust out the check card and order one right there on the spot. I wanted a new C2D machine with a respectable graphics card... so I let a few paychecks build and I bought one. I'd still be running my 7 year old 2.53/500fsb/integrated gfx P4.
                                I love netflix, but my parents don't. It's OK though, because I have a job. I wanted contacts. My parents said no way in hell they'd pay for that. Guess what? It doesn't matter, cause I can. I like my ear-length hair, thanks, but my dad refuses to give me money for anything but a buzz cut. It don't matter, I have a job. My friends want to pitch in some cash for gas and go to Six Flags next weekend. I can totally go, cause I have a job. And the best part? At our age right now, chicks dig the fact that you work. I kid you not. They'll even come visit you at work sometimes. You feel so much more able to do things. You're not at the mercy of your parents anymore. You also get a feel for what money is worth and learn that it doesn't just grow off trees, pretty valuable lesson IMO.
                                You should really think about it dude... totally worth it IMO.
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  i still do not have time. my mom makes me do a lot. ill think about it, but trust me, i wouldnt do fast food well. id have aheat attack as i am already 270lb. ill check again, but i have standards (why i dont work at goof squad). its not that i am nor worthy as it is that we are a colledge town here and when skool is in session, no jobs.
                                  sigpic
                                  • weirdlookinguy
                                    • Sep 2007
                                    • 1638
                                    It's all good man, it's a personal call, but I'm just saying you should give it some serious thought. Plus just cause you work in fast food doesn't mean you'll get fat.
                                    Your mom won't hold you back either man - she gives you chores because she doesn't want to see you sitting around all day not doing anything productive. Believe me, if you get a job, she will stop making you do all that stuff. Will you still have to help out around the house? Sure, little things here and there, but NOTHING like what it is now. If your house is anything like my house, your mother's frustration stems from her having to keep you busy instead of you taking the initiative and going out and finding a job.
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      only computer jobs that are part time are geek squad. i have standards but i am running out of options.
                                      sigpic
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        not chores, but the kinda crap you'd make a 5-year-old do.
                                        get dragged around everywhere. not really chores, but stupid stuff.
                                        besides, i refuse to do fast food- i am better than that. its kinda like the reason why a recovering alcoholic should not be a bartender.
                                        where else to look?
                                        sigpic
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                        • FZG
                                          EVGA Nu Audio Sound Card - Not Working
                                          by FZG
                                          I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
                                          The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
                                          I found...
                                          03-07-2025, 11:44 AM
                                        • paparazzo79
                                          sound card dead after graphics card installation
                                          by paparazzo79
                                          Hi guys.I own Z690 F Strix board in one of my PCs....everything was working fine with integrated graphics card.I turned off power from it, installed graphics card from another PC, connected all the peripheral cables, optical sound cable of course when everything was switched off.Then I powered on the machine and integrated soundcard is dead.How did this manage to happen and if there is a way to diagnose and replace damaged component?
                                          The new pci-e soundcard costs here 80 euros which is half of money I spent on motherboard.
                                          I still can not believe that I am such a looser and don't know...
                                          07-23-2024, 12:22 PM
                                        • alpersen
                                          Modding, adding usb/c audio pcb to laptop with faulty sound card/chip, Lenovo L340
                                          by alpersen
                                          Hello
                                          After months of trying I gave up my laptops sound card. I plan to solder a sound card on pcb inside my laptops case, probably connecting to usb ports inside. Do anyone has an experience to recommend pcb type audio/sound card suitable installing inside a laptop? Probably should have some type of amplifier for connecting to internal speakers ( speakers ).
                                          Thank you
                                          11-19-2023, 09:34 AM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
